Old Mar 20, 2013, 12:44 PM
kristaps_r is offline
Find More Posts by kristaps_r
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
Originally Posted by Dennis Frie View Post
Year, it doesnt work above 180 degrees atm
It is not really meant to be used for aerobatic, and in generally the artificial horizon havenīt been updated since first implementation.
I am preparing to fly in clouds and at night
kristaps_r is offline Find More Posts by kristaps_r
Old Mar 20, 2013, 03:22 PM
mike_o is online now
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
At the same time? I suggest you fix the video transmitter beforehand
mike_o is online now Find More Posts by mike_o
Old Mar 20, 2013, 03:23 PM
absolute-zero is offline
Find More Posts by absolute-zero
absolute-zero's Avatar
Joined Sep 2004
I've updated the software. I've only had suggestions from Absolute_zero, so it's pretty much the feedback from him that have been fixed/improved/implemented.
  • Fixed - Barometer-altitude was hanging when starting above 100 meter (noticed this due to a mistake, surprised no-one else have noticed )
  • Added - Lowpass filter on mah/km reading, to give more stable and smooth readings (alpha-value can be set in config-file)
  • Added - New timer-options. Timer can be reset based on speed and current. Speed is the default setting
  • Summary-options have been added, to avoid summary shows before the plane have been airborne. With the default settings, itīs detected based on speed.
  • Added - The temperature readout from BMP085 can be disabled
  • Fixed - The dot in the GPS-coordinates missed a shadow.
  • Added - Support for 10Hz GPS with MKT have been added. Please note that it have not been tested (must be enabled in config)
  • Added - Option to connect a button, to a digital pin. Only used to set home-position (same routine as used when button is connected to RSSI)
  • Small change to avoid artificial horizon to mess with flight-summary
Feedback is much appreciated
http://code.google.com/p/diy-osd-max7456/downloads/list
Great update, thank you very much.
I will try 10Hz GPS next time.
Michael
absolute-zero is offline Find More Posts by absolute-zero
Old Mar 20, 2013, 03:42 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
clouds, night AND upside down? Haha
No I get your point, if you cant see anything it would be nice to know the orientation of the aircraft quite accurate.
Michael
Year i hope that helps with the some of the things you mentioned
Please let me know if you find anything now working as expected. Quite a lot have been re-arranged and changed.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Mar 23, 2013, 02:45 PM
Just another user
Joined Feb 2011
Just realized a stupid mistake in the hardware. The tantalum-caps (used to AC-couple the video-output), have mistakenly been placed with the negative connector connected to MAX7456. As MAX7456 have 1-2 volt DC-offset, this is not how they should be connected.
The error have been marked below. While the DC-offset is quite low, I really have to recommend to place them right.
Sorry...
Old Mar 23, 2013, 04:57 PM
findus4fun is offline
Find More Posts by findus4fun
Joined Mar 2013
Hello Dennis,
I read all through the thread. Great work !
I would like to know if you could provide the altium project files.
I would like to correct the ac-couple caps and add a gps adapter to the pcb and maybe some I2C Sensors.
I am willing to share the modified project if anyone is interested.
Jan
findus4fun is offline Find More Posts by findus4fun
Old Mar 23, 2013, 05:08 PM
Just another user
Joined Feb 2011
Originally Posted by findus4fun View Post
Hello Dennis,
Jan
Hi Jan
Unfortunately the Altium-project have been made with none-standard libraries, which I can't share.
I think Ascended will have an OSD-version available later this year with pressure-sensor onboard, logic-converter for I2C and another GPS-connector.
But the hardware shouldn't be that difficult if you prefer to make your own design anyway.
Old Mar 23, 2013, 05:27 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Sorry...
So on this picture with the circle is the correct position of tantalum caps?
msev is offline Find More Posts by msev
Old Mar 23, 2013, 05:32 PM
Just another user
Joined Feb 2011
No, on the pictures I have marked the error / wrong position. They need to be turned 180-degrees.
I've updated #1 with correct overview.
Sorry about the extra hassle.
Old Mar 23, 2013, 05:33 PM
msev is offline
Joined Sep 2010
No problem!
Old Mar 24, 2013, 04:41 PM
Joined Mar 2013
Hello Dennis,
ok I understand that you cannot share the Altium Project files . Meanwhile I played a little bit with gerbv and combined your gerber files with an adapter for a gps PA6C from http://www.stephanharms.de/GPS-PA6.
It is 18mm wide and fits next to your design to stay within 5x5cm at seeedstudio. If anyone is interested, I can post the files.
Jan
Old Mar 29, 2013, 02:29 AM
SupraGo is offline
Find More Posts by SupraGo
SupraGo's Avatar
Canada, AB, Vegreville
Joined Jun 2009
LED polarity indication
Dennis,
You updated the diagrams for the reversed caps, but no LED polarity indication?
Bill
SupraGo is offline Find More Posts by SupraGo
Old Mar 29, 2013, 08:42 AM
Just another user
Joined Feb 2011
Originally Posted by SupraGo View Post
Dennis,
Bill
True, I'll add that
Old Apr 01, 2013, 05:49 PM
jeffkash is offline
Find More Posts by jeffkash
Joined Feb 2013
Hello Dennis,
Jan
I'm interested. Please post.
jeffkash is offline Find More Posts by jeffkash
Old Apr 03, 2013, 01:41 PM
Spejlo is offline
Find More Posts by Spejlo
Joined Sep 2011
hi Denis
I found one nasty bug.. some GPS receivers (ublox NEO 6) sends GGA and RMC together (no delay between)
everything is OK before homepos is set.. but after that.. all the calculations are little time consuming and GGA sentence is missing 2 chars (on baud 38400) (hope you understand my english
I fix it for myself (but it's not universal)
if (homepos==1) ggapos=3; else ggapos=5;
if (GPSbuffer[ggapos+1]=='A' && GPSbuffer[ggapos] =='G') {
Spejlo is offline Find More Posts by Spejlo
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 05:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 10:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 03:50 PM
