Old Mar 15, 2013, 03:48 PM
TayNinh68 is offline
Find More Posts by TayNinh68
Mosquito 6
Joined Jun 2012
Originally Posted by msev View Post
No, I'll make a few, maybe in the first run 2 or 3 boards fully populated..And I'll sell them for an outrageous amount of money (just kiddin', the price will be right )..but of course they'll be more expensive than the bare parts since I have to account in some transportation costs and some profit for my work, and some beer for the author of the project .
Sounds Fair Enough Add me to your order que
Cheers ..
TayNinh68 is offline Find More Posts by TayNinh68
Old Mar 16, 2013, 01:03 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
A few short clips with latest version...
Ground recs 2013-03-15 (1 min 1 sec)
Dennis Frie is offline Find More Posts by Dennis Frie
Old Mar 16, 2013, 02:56 PM
RickEis is offline
Find More Posts by RickEis
United States, AZ, Prescott Valley
Joined Feb 2012
http://www.youtube.com/watch?feature...&v=wGXG8jAM3yM
Dennis,
Looks like you got it up and running really well - OSD looks very clean !!
Rick
RickEis is offline Find More Posts by RickEis
Old Mar 16, 2013, 03:04 PM
Just another user
Joined Feb 2011
Originally Posted by RickEis View Post
Dennis,
Rick
Year, it works pretty good
I've had quite a few hours in air with the latest version and haven't had any problems. Absolute_zero have around 20 hours in air with version 0.14 and 5 hours with version 0.16
Have you had the time to use it?
Old Mar 16, 2013, 04:29 PM
RickEis is offline
Joined Feb 2012
Dennis,
I was about ready to put the OSD into the Gentle Lady ~ was doing loops with the gopro and one of the wing tips blew off ~ found the tip about 2000 feet away in a neighborhood !!!! Not much damage - just "time" to rebuild -
However, my kids bought me a Sky Surfer for my b-day....putting that together right now ...... The weather is warming up... so I need to get in the air somehow real soon !!
Thanks for posting those videos.....keeps me motivated to get into those clouds !!!
Rick
Old Mar 16, 2013, 06:03 PM
RFnoise is offline
Find More Posts by RFnoise
RFnoise's Avatar
Sweden
Joined Mar 2010
If you don't mind to wait a month or 2 you can buy one from me probably
Sure! No problem, im up for one!
RFnoise is offline Find More Posts by RFnoise
Old Mar 17, 2013, 06:14 AM
kristaps_r is offline
Find More Posts by kristaps_r
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
Had test flight today
P.S. My Video transmitter is dying, I flew LOS.
DIY MAX OSD + FY-DOS (3 min 2 sec)
kristaps_r is offline Find More Posts by kristaps_r
Old Mar 17, 2013, 06:42 AM
Just another user
Joined Feb 2011
Thanks, great to see it in action
All the numbers you have all over the place, is that on purpose? Looks quite different from the default config-settings.
Old Mar 17, 2013, 06:57 AM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
Those are for debugging purposes of FY protocol. Stil need a lot of work but AH is working good.
I notticed that horizont does not roll when plane is upside down and needs some way to see where sky is.
Old Mar 17, 2013, 07:38 AM
Just another user
Joined Feb 2011
arh, FY-protocol. I just imagined you used the same GPS-stream
Looks interesting.
Old Mar 20, 2013, 11:04 AM
Just another user
Joined Feb 2011
I've updated the software. I've only had suggestions from Absolute_zero, so it's pretty much the feedback from him that have been fixed/improved/implemented.
  • Fixed - Barometer-altitude was hanging when starting above 100 meter (noticed this due to a mistake, surprised no-one else have noticed )
  • Added - Lowpass filter on mah/km reading, to give more stable and smooth readings (alpha-value can be set in config-file)
  • Added - New timer-options. Timer can be reset based on speed and current. Speed is the default setting
  • Summary-options have been added, to avoid summary shows before the plane have been airborne. With the default settings, itīs detected based on speed.
  • Added - The temperature readout from BMP085 can be disabled
  • Fixed - The dot in the GPS-coordinates missed a shadow.
  • Added - Support for 10Hz GPS with MKT have been added. Please note that it have not been tested (must be enabled in config)
  • Added - Option to connect a button, to a digital pin. Only used to set home-position (same routine as used when button is connected to RSSI)
  • Small change to avoid artificial horizon to mess with flight-summary
Feedback is much appreciated
http://code.google.com/p/diy-osd-max7456/downloads/list
Old Mar 20, 2013, 11:33 AM
RickEis is offline
Joined Feb 2012
  • Added - Lowpass filter on mah/km reading to give more stable and smooth readings (alpha-value can be set in config-file)
  • Summary-options have been added, to avoid summary from showing before plane have been airborne. With default settings, speed must have been above a certain limit
  • Added - Temperature readout from BMP085 cn now be disabled
  • Added - Support for 10Hz GPS with MKT have been added. Please note that it have been tested (must be enabled in config)
  • Option to add a button to a digital pin have been added. just enable in config and select the pin you wanna use.
  • Small change to avoid artificial horizon to flight-summary
Dennis,
Glad to see you still perfecting things Hope to be flying with it again soon !!
Not sure what this digital pin can do ? "Option to add a button to a digital pin have been added. just enable in config and select the pin you wanna use. "
Rick
Old Mar 20, 2013, 11:49 AM
Just another user
Joined Feb 2011
Dennis,
Rick
Iīve updated the description.
But it is only used to reset home-position. Absolute_zero needed both RSSI and a button to reset home-position.
Old Mar 20, 2013, 12:07 PM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
Regarding artificial horizon:
  • There is no mark where level horizon is (degree scale is even more but not critical)
  • Horizon doesn't rolls more than 180 degrees and not showing upside down state.
  • Not possible to tell where UP is when plane will be upside down if previous will be implemented.
Old Mar 20, 2013, 12:16 PM
Just another user
Joined Feb 2011
Year, it doesnt work above 180 degrees atm
It is not really meant to be used for aerobatic, and in generally the artificial horizon havenīt been updated since first implementation.
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 05:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 10:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 03:50 PM
