Old Feb 12, 2013, 02:07 PM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
J viste o que fizeram pista?
Conheces a nova de Sta Marta de Corroios?
Icewind, are you a PT guy?
jalves is offline Find More Posts by jalves
Old Feb 12, 2013, 02:20 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by jalves View Post
My flavour of DFMaxOSd.
It works pretty good to show units instead of VLT, CUR etc
Fun to see a little different layout
Dennis Frie is offline Find More Posts by Dennis Frie
Old Feb 12, 2013, 02:37 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
I like a "clean" display (spoiled by the use of Dakar OSD) that allow me to see the scenery and check the model "vitals" by a quick look to the info displayed.
I am glad you like it
Old Feb 12, 2013, 04:52 PM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Sim, ja tinha visto. Alias ainda estava em PT quando a "fecharam".
A primeira vez que experimentei FPV foi nessa pista.
A nova estive la uma ou duas vezes, mas nao me convenceu devido a localizacao.
O resto nao posso comentar, pois ainda estavam no inicio e ainda tinha muito para melhorar.
IceWind is offline Find More Posts by IceWind
Old Feb 12, 2013, 04:56 PM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
This was mentioned in the CL-OSD thread but may be something you decide to add.
Having a option to turn the OSD on/off with a radio channel. I have a ET OSD and one of the things I like about it is the fact that I can configure different layouts and change using a switch.
I'm not saying to turn it off completely but been able to change to a more minimal mode would be great.
I also prefer to see the view than having the screen crowded with numbers and text.
Some of the people I fly with they only have in the OSD a timer and the RSSI, nothing more.
Old Feb 12, 2013, 05:20 PM
msev is online now
Find More Posts by msev
Joined Sep 2010
+1, layouts to choose by a channel would be sweet
msev is online now Find More Posts by msev
Old Feb 12, 2013, 06:03 PM
Just another user
Joined Feb 2011
The idea with one of the previous updates, was to make it more flexible. More or less everything can be moved around and turned on/off. I have been using everything, to make sure there was no bugs left - but you can just set it up as you prefer
Already prepared for that, but at the moment only artificial horizon can be turned on/off. Not quite sure how to make the changeable layout-options easy to configure.
Old Feb 12, 2013, 06:09 PM
msev is online now
Joined Sep 2010
T
Hmmm, maybe a GUI :-P
Old Feb 12, 2013, 06:19 PM
Just another user
Joined Feb 2011
It have crossed my mind, especially with all the options available.
But the config-file should be pretty easy to use, and Arduino is also quite easy to use.
So that's probably not gonna happen
Old Feb 12, 2013, 07:38 PM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
I finished my OSD & powered it up...it works!
I bench tested it with BMP085 - no probs.
A few questions Dennis -
What is the figure circled on the left?
Can i remove the Thermal Bar cirlced on the right?
What starts the timer?
Oh & i love how you dont need a camera to get OSD info - could be usefull if you have a camera fail.
badlands is offline Find More Posts by badlands
Old Feb 12, 2013, 07:45 PM
Just another user
Joined Feb 2011
Congrats, very nice
Any problems, or anything that wasn't clear while assembling?
The 00 on left is satellites. It will show while home-position haven't been set, and automatic show if satellite-fix is lost.
I actually can't remember if the bar can be removed in the config-file? It will not show if you disconnect BMP085.
If I haven't added it as an option in the config-file, I'll do that in next update.
The timer runs on GPS-time, unless you have defined something else in config. It will start immediately, and reset when home-position is set (but note that a GPS must be connected).
Old Feb 12, 2013, 07:56 PM
badlands is offline
badlands's Avatar
Joined Mar 2010
Congrats, very nice
Thank you for the fast reply Dennis.
Assembly went smooth, i got stuck uploading to board using Arduino as i was used to just hitting the 'UPLOAD' button, i needed to select 'UPLOAD USING PROGRAMMER' - which you covered a few post back. :-)
I cant see an option to remove the bar in config file but if you could add it that would be excellent! (i love how configurable this OSD is you see!)
Im awaiting my Flytron GPS unit - i tried my DOSD FMP04-TLP GPS module running on 3.3v but it didnt work.
Old Feb 12, 2013, 08:08 PM
badlands is offline
badlands's Avatar
Joined Mar 2010
That GPS UNIT speed is 38400 bps/8/N/1 (Default) - could that be why it didnt work?
Old Feb 12, 2013, 08:12 PM
Just another user
Joined Feb 2011
The default is 9600, so that could explain it
Just change baud-rate to 38400 in config and see if it works.
Old Feb 12, 2013, 08:36 PM
Ascended is offline
Find More Posts by Ascended
Ascended's Avatar
Canada, AB, Calgary
Joined May 2012
If you have time, perhaps you can implement auto baud rate?
Ascended is offline Find More Posts by Ascended
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 06:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 11:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 04:50 PM
