That's weird. And you have the right board selected (Tools -> Board -> "Something with Atmega328")
Another solution is to use the bootloader. If you have successfully uploaded the bootloader, you should be able to upload with serial-communication instead. But it should be easier to use the ISP, as you will most likely have GPS connected to USART-pins later. Try to burn bootloader again and upload MAX7456_OSD after that. |
Quick update from me on my hardware. I've designed a current sensor. I got a big fright when looking up the attopilot/dragonlink resistor chips and found they are rated to 31A (62A with two resistors as some have now), when I'm pulling 90A through them - and the DIYDrones current sensor only works to 18V due to the PTH08080 on board.
As such, and so I have a current sensor that will safely work with planes like my EDF Jet, helicopter and some big unmanned aircraft I made a 90A current sensor which is happily rated for 126A, and 380A burst. The 90A would be scaled for 3.3v, so we get some overhead on the 5v chip on the OSD. Finally, a small, safe shunt style current sensor! I mount my cables inline on the cable, so the ground is provided on the back of the current sensor, and voltage on the front. No wasted space for connectors you wont use, and no cables doing a U bend which makes connections in the plane stupid. Just a pair of cables with a 13mm bump out one side. It has the DF-13 connector the same as the OSD for easy connection, and the same as the ArduPilot. The resistors in the silkscreen surrounds are removed, and the solder jumper shorted for use with the OSD, or with a DragonOSD/Similar. With the resistors in place and the jumper unshorted the board will work with the ArduPilot reporting as a Attopilot sensor. |
Joined Sep 2010
Or should I design my own if I'll ever need such a big one?
![]() Have you used an INA 13x or a normal opamp coupled as differential amplifier? The max gain on INA 13x is not that high, but it should be fine in most cases. You might have to be aware, that some current-sensors have voltage-divider mounted for v-sense (and not on the OSD). That's not a problem for this project, but if people connect 12v+ on a 3.3v ADC input... Well |
If people wanted the current sensor for anything else, the resistors would come pre-placed. If they wanted to use it for an OSD with vdivs, then they just need to pull the parts which are outlined in silk screen I have a couple of different products I'd want to use this for and its a real pain sometimes to find a sensor board which will work - hopefully this will make life a little easier for me (and others!)
| Thread Tools | |
| Help! OSD version UNKNOWN and fail to update (error) | dROb | Eagle Tree Systems | 9 | May 16, 2012 05:12 PM |
| Sold EASY OSD (Version 1.2) Brand New . $75 shipped. | LHTPlane | FPV/RPV - Equipment and Vehicles (FS/W) | 7 | Mar 20, 2012 10:45 PM |
| For Sale MAX7456 OSD Break out board. | ziomatrixacs | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Jun 18, 2011 03:50 PM |
