But I haven't tried, just doubt it will actually work |
![]() I fried my test-bench camera a while ago. The OSD was never really tested with a camera before I had the first PCB-version up and running |
![]() But as most changes is related to sensors etc. you will most likely find, that it works just fine. Have you done any specific changes to the software/hardware? As far as I remember you have the very first hardware-version with large crystals and no ISP-connector or I2C connectors. |
A new software version have been uploaded
http://code.google.com/p/diy-osd-max7456/downloads/list Main changes:
Furthermore, a LOT have been changed in the layout options. This means pretty much everything can be moved around. A lot have been changed in the code, so if you find any hanging characters etc. please let me know.
Not really anything I would normally post, but here goes anyway.
My tripod was at home and I decided to fly with my directional antenna laying on the ground (totally on purpose to train "flying through static" off course.. Okay, not really) I have a lot of nice recordings as well, but this was mainly to show something a bit different
Joined Sep 2010
Man an antibluescreen device would be nice though
, some that "emulates" how those 100$+ dvrs work that passthrough the video and don't go black...But of course cheaper ..Ok back on topic...Awesome stuff, D. I see from the video that the AH is working pretty good I guess? What about combined with the baro is that problem already fixed? Or do they still mess with each other? Btw pcbs are on the way from good ol' China
So, with the aim of telemetry and aircraft-aircraft communications, I worked with Dennis to figure out some requirements. We came up with a 868MHz radio modem, 26dBm TX (500mW), -126dB RX - see attached. This should easily give least 10KM of high speed telemetry, with a chip change we can get to -133dBm (at very low speeds obviously) but that IC s 3x the price.
By changing the L network (tuning) this can easily be switched to 900/915MHz. The aim is for a multi-aircraft radar screen and ultra long range telemetry. The RF module + host board is only 20mm wide, or just 18mm wide as just a module. The host board is required, as the RF board is only 1mm thick, 4 layers and impedance controlled. Over it's length, the solder on the frontend and RF IC's could be easily flexed off or the joints broken - so the host board is required. This makes it much stiffer and allows the mounting of the UART/I2C connectors. The boards came out much longer than I had hoped, at about 63mm for the two side facing connectors or 58mm for the two down, two side facing connectors. I'm not sure which board I want to have made. There is also a board with a FTDI chip and USB connector on it to allow interfacing with a laptop/computer. It's envisioned that these boards would work standalone with a GPS pass-through so that people not using this OSD can be displayed on screen, or receive telemetry - or so it can be used with APM/others. This OSD would talk to it over I2C, sending it data to transmit and retrieving data that has been received. With an android/windows phone or PC, it would be able to stream live ATC data to the planes to display fullsize air traffic on the OSD view. This would be a fantastic safety feature. Obviously, the software on laptop or phone would have to support the ATC for your city/area. |
If it performs just anything close to what the specifications suggest, it will make an incredible telemetry link. With he possibilities of multiple receivers and transmitters for downlink to ground-station, plane-to-plane etc. this gives a lot of new possibilities.
An arrow pointing towards another moving plane, direction to a moving car, recording and logging data on ground-station - you name it. |
The performance of the artificial horizon is still not acceptable, it was just to show, that it does work more or less, with few vibrations and low G-force. It was mounted on my plane anyway and can be turned on/off with a switch
| Thread Tools | |
| Help! OSD version UNKNOWN and fail to update (error) | dROb | Eagle Tree Systems | 9 | May 16, 2012 05:12 PM |
| Sold EASY OSD (Version 1.2) Brand New . $75 shipped. | LHTPlane | FPV/RPV - Equipment and Vehicles (FS/W) | 7 | Mar 20, 2012 10:45 PM |
| For Sale MAX7456 OSD Break out board. | ziomatrixacs | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Jun 18, 2011 03:50 PM |
