![]() My sparetime is already quite limited by studies, work and a lot of other projects, I simply don't have the time to sell and support products in a more professional way. A few test-boards have been shipped, but that's about it. The PCBs costs around 1$ per piece ordered directly from Seeedstudio (minimum order is 10 pieces). Even the shipping is minimum 2$ if I ship a PCB from Denmark. That would quickly end up being 5$ for a PCB, which is hardly worth the effort. Quote:
Board has been updated again.
Added the MS5611 baro which is much more compact and far more accurate than the BMP085. I was overthinking things with a black level and white level inserter for the VBI data - all that is required is white as the VBI is already black. This just requires a diode and resistor to do (assuming the vtx terminates the video correctly.) I still have heaps of free space on the board and not much to do with it, so i made a big heatsink for the 5v regulator with mask and solder. Solder doesnt show on the 3d view, but it will be on the lines radiating out from the vreg. This helps transfer heat across the copper and also provides extra surface area for radiating heat - not that a shiny surface like solder really radiates a great deal. The heatsink plane is only on the top as I did not wish to remove the ground plane on the bottom. The height of the connectors and vreg itself will allow for some air exchange to occur even in heatshrink. I also moved the LED away from the baro, and placed it next to the power jumper connector/camera in/out headers. This will allow it to be easily seen and not shine on the baro. The height of the caps and inductor next to the baro allows for plenty of air flow to the ports of the baro, even with heatshrink. The board is much bigger than i'd like, but I don't want to go double sided for components - just connectors. With a bunch of work i could shorten the board by 3mm, but it's not worth my time for such little gain. I think it will still be compact enough to be easily used. |
I simply don't have enough time to support software on an open source project though... too many paying clients
![]() Sorry, can't show you cool 3D components
![]() Guess we will a few new OpenSource OSD's flying around sooner or later |
Can't check myself. Will it work with some changes in code? |
If you have connected to an interrupt it should be possible to change in the code, but you will got more "noise" on the readings. I compared the two methods here: One "tick" is ½ us. But The main problem is, that USART is running in interrupt-mode and not polling. That means you will get "noise" if an USART interrupt is triggered while PPM should be read. With input capture that's not a problem, unless you miss an entire pules. |
| Thread Tools | |
| Help! OSD version UNKNOWN and fail to update (error) | dROb | Eagle Tree Systems | 9 | May 16, 2012 05:12 PM |
| Sold EASY OSD (Version 1.2) Brand New . $75 shipped. | LHTPlane | FPV/RPV - Equipment and Vehicles (FS/W) | 7 | Mar 20, 2012 10:45 PM |
| For Sale MAX7456 OSD Break out board. | ziomatrixacs | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Jun 18, 2011 03:50 PM |
