Old Jan 24, 2013, 04:17 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
So the baro must be messing with the gps somehow...some bug must be hidden somewhere
msev is offline Find More Posts by msev
Old Jan 24, 2013, 05:51 AM
Ascended is offline
Find More Posts by Ascended
Ascended's Avatar
Canada, AB, Calgary
Joined May 2012
GPS altitude is only accurate +/- 15Metres
Ascended is offline Find More Posts by Ascended
Old Jan 24, 2013, 06:31 AM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
For some reason, there was a huge offset on the home-position. I donīt know if it was bad GPS-signal, a bug, or the GPS that failed in the cold weather. But the offset was already visible before take-off.
At the moment negative altitude is not shown with a "-" sign on GPS-altitude, and you canīt tell the difference from positive or negative altitude. Off course, that made it quite difficult to use GPS-altitude. That will be fixed
Dennis Frie is offline Find More Posts by Dennis Frie
Old Jan 24, 2013, 06:33 AM
mike_o is offline
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
msev,
I'm not ready to draw that conclusion. I also had GPS locking problems before upgrading for barometric pressure. The issue seems to be related to the distance from the OSD/Camera/SBEC to GPS board.
I'll try extending the wires to the GPS unit by a few centimeters and try that out.
mike_o is offline Find More Posts by mike_o
Old Jan 24, 2013, 05:21 PM
Just another user
Joined Feb 2011
The software have been updated.
http://code.google.com/p/diy-osd-max7456/downloads/list
There's quite a few changes, but the most noticeable:
- Negative GPS-altitude supported
- Negative temperature supported
- Delay-screen removed (can be turned on again if you find QUIET_BOOT in config)
- Show satellites added, but will only work with QUIET_BOOT disabled. With QUIET_BOOT enabled, the satellites will automatic show if GPS-fix have been lost.
- GPS-altitude can be replaced by pressure-altitude
- Added some configurations for better customization
All in all not an important update, but a lot of minor changes.
Old Jan 24, 2013, 08:08 PM
Tang0au is offline
Find More Posts by Tang0au
Joined Dec 2012
its summer down here in Oz - let me know if you need any datalogging from flights for getting the gyro code stable ?
Tang0au is offline Find More Posts by Tang0au
Old Jan 26, 2013, 05:39 AM
Just another user
Joined Feb 2011
Thank you
But I think I'll put the artificial horizon on standby for a little while. I would like to make sure everything else works as expected, before adding more to the project.
But if you have the hardware available, lets see the latest firmware in air
Old Jan 26, 2013, 02:26 PM
absolute-zero is offline
Find More Posts by absolute-zero
absolute-zero's Avatar
Joined Sep 2004
So is my OSD ready to be installed ..
I can see a problem at night flights. The black bars and dots on the right side can not be seen when it is dark in the background. I suggest either a night flight mode in all white, with a longer dot/bar to indicate the center or whites edges of the black bar and dot.
absolute-zero is offline Find More Posts by absolute-zero
Old Jan 26, 2013, 02:48 PM
Just another user
Joined Feb 2011
Great to see
You are right about the thermal-bar, it's not easy visible, if you fly at night. It should be a quick fix and I'll consider to include it as an option in next release.
Old Jan 28, 2013, 11:44 AM
Joined Sep 2004
First test with my DFOSD.
Dennis Frie's OSD on quadcopter with KK2.0 LCD controller (7 min 40 sec)
The barometric altitude and vario works perfekt.
Thank you for your work Dennis.
Old Jan 28, 2013, 11:56 AM
Just another user
Joined Feb 2011
http://vimeo.com/58379559
Great to see it in action
I few things worth mentioning:
  • The altitude is replaced with barometer-altitude, which have hanging characters. My mistake, will be fixed
  • The negative-sign is barely visible. Will be replaced with another character later
  • You are using 1 hz GPS which gives quite a slow response. Furthermore, as home-position is set relative to number of GPS-updates after fix, you have to wait something like 5 times as long for home-position as intended. Can change it for timer instead of GPS-updates
Except for that, whenever someone have some feedback on the barometer, please let me know. The filter can be changed for faster response, but with a bit more noise as result. Furthermore the precision for lift/sink rate can be decreased a bit to get faster response. It's all a compromise between samples, speed, precision and noise
Old Jan 28, 2013, 11:59 AM
Just another user
Joined Feb 2011
I was out testing as well. Didn't find any problems with default settings
Old Jan 28, 2013, 12:32 PM
Joined Sep 2004
I agree. I need to program the GPS in this bird, it's a 10hz version running af 1hz.
Remark GPS coordinate flash when summery screen deactivate.
Old Jan 28, 2013, 12:39 PM
Just another user
Joined Feb 2011
It clears the entire screen between top-line and bottom-line, when summary disappears. Mainly to ensure nothing's left hanging.
Normally the GPS-coordinates would appear again 1/5 second later, but as you are using 1 hz update-rate, it's easy visible.
Old Jan 28, 2013, 12:41 PM
Joined Sep 2004
ok.
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 05:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 10:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 03:50 PM
