Old Jan 08, 2013, 07:37 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
It is Open Source, just give credit.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jan 08, 2013, 07:41 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Originally Posted by Dennis Frie View Post
Using the I2C from multiwii could be a possibility, but really don't wanna "take" any work from other people. Any idea about the license or who to contact?
It's GPL v3, feel free to take the source and expand on it as long as the result is offered back to MultiWii and the source code taken stays GPL v3 compatible.
http://www.gnu.org/licenses/quick-guide-gplv3.html
brontide is offline Find More Posts by brontide
Old Jan 08, 2013, 08:14 PM
RickEis is offline
Find More Posts by RickEis
United States, AZ, Prescott Valley
Joined Feb 2012
......The timer runs on GPS-time if you have set that in config-file.
Dennis,
Yes, I was inside...did not have satellite fix yet
#define USE_GPS_TIME 1
So change to #define USE_GPS_TIME 0 to use computer time ?
Can't think of why we would want to use GPS time when we are looking at minutes and seconds? All should zero out when we get fix anyway. Then we have another opportunity to zero timer by getting out of menu......
Rick
RickEis is offline Find More Posts by RickEis
Old Jan 08, 2013, 08:23 PM
Dennis Frie is online now
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by RickEis View Post
Dennis,
Rick
Whenever a GPS is used, I would recommend to use GPS time. It's a lot more accurate and there is not really any drawback.
You dont need GPS-fix to use GPS time, as long as the GPS is connected you should be fine.
Dennis Frie is online now Find More Posts by Dennis Frie
Old Jan 08, 2013, 10:30 PM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
Nothing will be more accurate than GPS time, unless you are looking at microsecond levels of jitter in a GPS-unreliable area.
The wire library for Arduino seems to have some problems, especially with timeouts. I just use the existing sensor library info and make my own functions for reading all of the I2C devices hooked up instead of the wire() library. Especially when you are using multiple I2C devices.
Ace4 is offline Find More Posts by Ace4
Old Jan 08, 2013, 10:48 PM
RickEis is offline
Joined Feb 2012
Dennis,
BMP085 detected
MPU6050 detected
PPM and menu working fine
For some reason when mpu6050 is connected the bmp085 went crazy ......numbers all over.
Maybe copter is noisy even with 2 filters as in post 345 ? how to test ?
Mpu6050 looks like it is working well.....I need to mount it. Appears it might not be horizontal with the board - maybe need to calibrate gyro ?
Rick
Old Jan 09, 2013, 05:31 AM
Just another user
Joined Feb 2011
Dennis,
BMP085 detected
MPU6050 detected
Rick
Sounds great. Any idea why your PPM-signal wasn't detected first time you tried?
You already got the MPU6050 hooked up as well? Amazing
I jave noticed 2 I2C devices at the same time can give some problems at the moment. I suppose it was the pressure-readings that was all over the place?
In regard to the artificial horizon not being horizontal. If it's tilt, it might be NTSC, where I haven't centered it. It have been tuned with PAL, so you might experience a little offset and to much/little variation of the horizon compared to the real horizon.
In the config you can find this:
#define TILT_OFFSET 16
#define ROLL_OFFSET 0
If you increase tilt, the artificial horizon will move down (as in have an offset). If you decrease it, or set it negative, it will move up.
When fine-tuning the offset, you can disable GPS (something like USE_GPS) to get artificial horizon show immediately and not have to wait for GPS-fix etc.
Old Jan 09, 2013, 08:55 AM
RickEis is offline
Joined Feb 2012
..... Any idea why your PPM-signal wasn't detected first time you tried?
Dennis,
Yep.......I have a real good idea why PPM was not detected. It was not connected.
And yes, it was the pressure numbers that went wild when both sensors were running.
Hope to test in the air soon .....
Rick
Old Jan 09, 2013, 04:25 PM
Just another user
Joined Feb 2011
Dennis,
Rick
Great to know about the PPM, I could have used a lot of time to find that bug . The only "problem" left is your timer. If you ever see it stop again, please let me know.
I'll update the I2C routine next time I update the code.
Old Jan 12, 2013, 03:32 PM
Just another user
Joined Feb 2011
Just tested the OSD with the new EzUHF firmware, to get RSSI and signal-quality in the PPM-stream.
It works like expected, and the scale have been set to reflect 0-100%. Will be included in next update
Old Jan 12, 2013, 05:00 PM
Just another user
Joined Feb 2011
Default I2C communication routines from MultiWii have been implemented .
Uses less space and works like a charm so far
Also eliminates the previous problem with "infinite loop" in the wire-library
Old Jan 12, 2013, 05:23 PM
RickEis is offline
Joined Feb 2012
Wow... very good Dennis,
I'm taking this time to try another quad design - ha I don't know why I just don't go buy one. I guess I enjoy building and modifying it till it does what I want....
Looking forward to more OSD testing when you are ready
Rick
Old Jan 12, 2013, 05:26 PM
Just another user
Joined Feb 2011
Rick
It's always fun to build it yourself
You will probably not notice much difference from the current version available and next version - but it should take care of the known problems with the I2C.
Old Jan 12, 2013, 08:04 PM
Just another user
Joined Feb 2011
I've uploaded the latest version:
http://code.google.com/p/diy-osd-max7456/downloads/list
Not many visible changes, but in regard to the I2C communication quite a few things have been updated.
NTSC have been fixed a bit, pressure-sensor changed a little + added lift/sink-rate as numbers (sorry, it's only in meters atm) and a quick "error check" in case of bad data from BMP085.
Oh, and all the EzUHF RSSI and Link quality have been updated and tested with the available beta-firmware
Old Jan 12, 2013, 09:33 PM
BillyJo is offline
Find More Posts by BillyJo
FpvQc
BillyJo's Avatar
Canada, QC, Quebec
Where did you take this firmware ?? on Beta page of ImmersionRC ??
thanks !
BillyJo is offline Find More Posts by BillyJo
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 05:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 10:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 03:50 PM
