Old Jan 07, 2013, 04:23 PM
mike_o is offline
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Warning: MAX7456 Ebay seller
Just ordered a 5 pcs of MAX7456 from ebay seller "polida2008" and received this mail:
"Hello,Could you kindly pay extra USD3.50 as registration fee?The parcel that shipped to Denmark may lost on the way, or it takes a long time to arrive there.What’s more,the post office may delay the regular mail.In order to track the parcel and make sure it arrive successfully, I hope you can pay it. If you don't accept it, I am afraid that it might lose.Hope you can understand. Waiting for your early reply."
I haven't met this behaviour on Ebay in any of my 400+ transactions before, and I have notified the seller that I consider this scamming. I suggest you avoid him for now.
mike_o is offline Find More Posts by mike_o
Old Jan 07, 2013, 05:20 PM
HOL is offline
HOL
Find More Posts by HOL
HOL
Danmark, Midtjylland, Galten
Joined Oct 2011
Thanks for the heads up, Mike. What a jerk. Never experienced that either.
HOL is offline Find More Posts by HOL
Old Jan 07, 2013, 05:47 PM
bob4432 is online now
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
Dennis,
I would look at how they are doing it in MultiWii as people were upset with a deviation of 3-6ft @ ~20ft or so, but multis don't go that high. MW for the most part moved to the ms561101ba03 which supposedly has an accuracy of 10cm (not sure over that much altitude), but I have never looked at the code and haven't flown the latest MW due to other life responsibilities. You may want to ask over at the MW forum and see what they see as the MW will fly fixed wing, or even how they do it in AutoQuad software. I know AQ is using a different baro, but you could see the method. Same w/ OpenPilot/CopterControl Revo - may want to look at their baro code too as they use the ms561101ba03 too.
Sorry I can't be of more assistance,
bob
Originally Posted by Dennis Frie View Post
Just did a few tests for altitude estimation with pressure sensor:
I can't really find a "light" approximation that gives an accurate result.
https://dl.dropbox.com/u/3947315/Pre...estimation.pdf
90 meters deviation at 2000 meter is quite a bit. Could be acceptable, but if anyone have some good suggestions please share
bob4432 is online now Find More Posts by bob4432
Old Jan 07, 2013, 07:23 PM
RickEis is offline
Find More Posts by RickEis
United States, AZ, Prescott Valley
Joined Feb 2012
Dennis,
Received a BMP085 today - also, apparently a MAX sample or 2? is on its way to me
Maybe you have seen this regarding the BMP085 and the MS5611 ?
Copied below are a few user comments from the Sparkfun site regarding the BMP085
https://www.sparkfun.com/products/11282
It appears the site also includes some code
RE: “accuracy down to 0.03 hPa”, from the data sheet I believe the noise is 0.03 hPa, not the accuracy. The typical absolute accuracy is given as +/– 1 hPa, or roughly 8 M altitude, the relative accuracy is +/– 0.2 hPa, or about 1.6 M altitude
This agrees with what I’ve seen in the lab; the noise in the readings is on the order of 1 meter but if you can deal with lower data rates (< 1Hz) it filters down quite nicely.
Are you are interested in working with the MS5611-01BA ? If so, I'll send you one.
And Fabs FreeIMU library - 2012/11/22 has some recent code work with the MS5611 -
http://www.varesano.net/projects/hardware/FreeIMU#0.3.5
RickEis is offline Find More Posts by RickEis
Old Jan 07, 2013, 07:50 PM
bob4432's Avatar
Joined May 2010
RIP Fabio
Old Jan 08, 2013, 03:21 AM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
Dennis,
Check this paper.
It could somehow help you.
jalves is offline Find More Posts by jalves
Old Jan 08, 2013, 05:36 AM
Tang0au is offline
Find More Posts by Tang0au
Joined Dec 2012
also, the code used by the arducopter / apm might help - different baro sensor, but at least the code is open source, and they get accuracy of 10cm ...
Tang0au is offline Find More Posts by Tang0au
Old Jan 08, 2013, 07:13 AM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Year, thanks for the hads up! I would find another seller and fill a complaint on ebay or similar, if he don't ship the items at the price advertised.
Originally Posted by bob4432 View Post
Dennis,
bob
Thanks. I'll play a bit with it myself and have a look at how it's done in other projects if I get stuck
Dennis Frie is offline Find More Posts by Dennis Frie
Old Jan 08, 2013, 07:23 AM
Just another user
Joined Feb 2011
Originally Posted by RickEis View Post
Dennis,
The measurements I've done gives quite a lot more noise than written in the comments on Sparkfun. Nevertheless, I probably have to use higher samplerate and filter the data more then first expected.
Your BMP085 will be detected when you connect it, but it's most likely quite useless until next update - sorry.
At the moment I still have plenty of testing and implementation to do, but in the future it might be interesting to compare with MS5611-01BA.
But lets start with the current hardware
RIP Fabio
Really a shame with Fabio. He was a great person and his contributions to this community have been quite impressive.
Originally Posted by jalves View Post
Dennis,
Check this paper.
ll have a look at it., thanks!
Old Jan 08, 2013, 07:33 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Whats up with Fabio??
msev is offline Find More Posts by msev
Old Jan 08, 2013, 07:36 AM
Just another user
Joined Feb 2011
He passed away...
http://www.rcgroups.com/forums/showthread.php?t=1794989
Old Jan 08, 2013, 07:41 AM
Just another user
Joined Feb 2011
Just to give you an idea of the noise on BMP085
The Y-axis is 70 pa ~= 6 meter
Old Jan 08, 2013, 07:49 AM
msev is offline
Joined Sep 2010
Wow thats a shock about Fabio...He was soo young :/..Thanks for letting me know.
Old Jan 08, 2013, 08:28 AM
Just another user
Joined Feb 2011
Oversampled (red) and digital lowpass filtered (blue)
Old Jan 08, 2013, 09:15 AM
RickEis is offline
Joined Feb 2012
Dennis,
This is so neat to be able to see these plots as you fine tune things. Do you mind taking just a few minutes explaining what you are using and how you plot this. I'm very interested !
Rick
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 05:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 10:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 03:50 PM
