Old Nov 27, 2012, 07:45 AM
John Wright is offline
Find More Posts by John Wright
United Kingdom, Harleston
Joined May 2004
How about this for an electric ducted fan Me163. I think it is 1.350m wingspan and powered by a 12s Lipo set up. Not sure of the speed, but pretty quick.
http://www.youtube.com/watch?feature...&v=GfCeEkJdM_E
There are a selection of fully moulded Me163 of various scales from Sunshine Wega
http://shop.wega-sunshine.com/index....enmodelle.html
Not sure but think this may in fact be a prop driven Me163
John
John Wright is offline Find More Posts by John Wright
Old Nov 27, 2012, 10:25 AM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
That one is fast all right ! The camera work is amazing. Really nailed it.
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Dec 02, 2012, 03:01 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Canopy
Pulling a canopy over a form is probably the only time I've built something that can be repeated, as in, I could make dozen of these in a half an hour. Kinda of nice.
It took a couple of attempts to refine the procedures and settings to get a good pull. Sadly I STARTED with the good material, .060" PET-G. Very thick. Makes a nice product but in this case, ruined. Final product was a very thin PET-G. (.020").
The first pull was apparently over heated at 350F and broke out in little air bubbles. It also had a crease in the plastic. The form needs to be raise up from the vacuum table on a base that extends all the way down to the table. Otherwise you'll get a blow out as I did with this one.
Kent
Pulling a Canopy (0 min 0 sec)
Old Dec 02, 2012, 04:34 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Nice work!
I've got to make a vac box,the canopy on mine was plastic bottle,form blocked against the neck slope,vac and heat gun.
Whats the frame,thin ply?
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Dec 03, 2012, 09:12 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
The frame is 1/8" masonite.
Old Dec 05, 2012, 11:41 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
I've found that the Pop bottle canopies are far more durable than any out of my Vac former.
Water bottles are my current favorite material, although 2 litre Pop bottles make for an indestructible canopy.. should you need it.
Ohhhh. Electronics shop fiberglass 'Perf Board' makes for a Excellent vacu former platten
Bare is offline Find More Posts by Bare
Old Dec 05, 2012, 01:01 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Thanks Bare. I've heard of the pop bottle approach, but have never seen it done. This canopy may be a little too large for a pop bottle approach, but I'd like to see the process. Do you have a link to an example somewhere?
My ruined bubbly version from .060" PET-G is quite strong. No complaints there. I doubt that it would ever break in service.
Kent
Old Dec 05, 2012, 01:14 PM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
Kent
you looking for something like this - http://www.rcgroups.com/forums/showthread.php?t=1313427
I like to form these with boiling water instead of a heat gun (because I don't HAVE a heat gun). Now that i have the CNC router, milling out a real nice form from scrap 2x4 cutoffs should make for some real nice forms. If all goes well with the POP, I would like to do a nice canopy for the new fuse. The green bottles make for a nice tinted look.
Mark
Quick61 is offline Find More Posts by Quick61
Old Dec 11, 2012, 01:34 PM
heiner is offline
Find More Posts by heiner
Joined Jun 2007
Capt. Eric 'Winkle' Brown talks about flying Messerschmitt Me 163 Komet (4 min 46 sec)
If you are flying a Me-163 you have to listen to that video!
Heiner
heiner is offline Find More Posts by heiner
Old Dec 11, 2012, 03:26 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Good one Heiner! I'll be sure to not have even a cupful of fuel remaining on board when I attempt a landing. There has got to be a price for all of that acceleration.
Kent
Old Dec 11, 2012, 07:10 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Mark
Thanks for the link Mark. That's exactly what I was looking for. I would think that no matter how hard you try, there will always be some artifacts in the surface of the plastic when using this method.
I need to get the plastic to 285F before it sags enough to vacuum form. At 212F the pop bottle approach seems unlikely to work, but of course you and others have been successful.
I look forward to seeing your POP canopy.
Kent
Old Dec 11, 2012, 09:22 PM
Bare is offline
Canada
Joined Nov 2000
Ahh someone has posted a pop bottle 'method'.. Good.
IF one can fit the wood or Plaster? form into a bottle then there's good chance of success.
PS: don't use a foam plug.. don't ask :-)
Also when vacu forming one can obtain perfect final surfaces by simply forming the "next' Canopy over the blemished First one.. which is left as a buffer on the plug... try it :-).
Old Dec 11, 2012, 11:29 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Fun to see other Komets in work.
I have been having a blast flying the little Hobby King Me-163 lately. A very nice turn of speed and a good flyer.
I have two of the old ACT Me-163 foamies that I never got around to building that would be awesome today with a modern very hot park jet outrunner and a 3S 1600 lipo, as opposed to the original Speed 400 and 8 round cells...
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Jan 19, 2013, 06:14 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Getting close.
Without trying too hard, balanced just aft of last known flyable CG. Good to go.
Kent
Old Jan 20, 2013, 03:43 AM
vincent123 is offline
Find More Posts by vincent123
InceCreations
vincent123's Avatar
Joined Jul 2009
What the total flying weight and wing loading? And cubic wing loading?
vincent123 is offline Find More Posts by vincent123
Discussion Profile 39" ME 163B Komet burkefj Pusher Prop Jet Models 30 Mar 03, 2009 09:11 PM
Discussion Construccion ME 163b Komet 1/2A emontielr Mexico 21 Aug 18, 2008 02:05 PM
Video Profile 39" ME 163B Komet 2nd flight burkefj Electric Plane Talk 0 Mar 09, 2008 03:28 PM
Video Profile Me-163b Komet youth must fly Electric Plane Talk 2 Jun 13, 2007 01:15 PM
FS: ME 163B Komet & Norvel 0.74 lw_hughes Aircraft - Fuel - Airplanes (FS/W) 1 Jun 26, 2004 11:17 AM
