Old Jan 23, 2013, 05:21 AM
charlespereira is offline
Find More Posts by charlespereira
charlespereira's Avatar
Brazil, SC, Florianopolis
Joined May 2008
Originally Posted by dougmontgomery View Post
r u going to ramp up clay or bondo to the wing leading edge since it does not look like your splitter plate is not level with the LE?
I have done that before- but the clay ramped up does not leave a very nice finish?
doug
Hi Doug!
Negative, I wonīt use clay!
The platform is 3mm beneath the centerline. I will use a 3mm sheet of MDF over it.
My idea is to use very few glue in this layer of MDF, to facilitate getting the mold out.
The platform is really strong, to support the weight over the flanges and it does not touch the plug. It is made of 9mm MDF.
Today I will work on the flanges and use epoxy to make a perfect join on the seam.
It takes a lot of job, but I am using all the techniques that I have been studying on this plane.
I donīt want to make it in a hurry and as is my intention to sell some planes to pay all the material that I am using, it must get well done.
Thanks!
charlespereira is offline Find More Posts by charlespereira
Old Jan 23, 2013, 07:35 PM
Joined May 2008
Help with the mold reinforcement
Hello!
I am finishing the steel structure that will reinforce the mold. Maybe tomorrow I will have some pictures to show.
Is it necessary to make this structure on both halves os the mold?
I imagine that if one half is reinforced, and the other one is tightly binded with bolts, it should not be a problem.
Does anyone have some experience with this and give some hints?
It been more difficult that I thought to build this steel skeleton...
Thanks!
Old Jan 25, 2013, 04:00 PM
Joined May 2008
Hello!
Today I finished the steel structure to support the mold.
Now, the only thing that lacks to do is the flange on the seam line.
I left the things on my parentīs house and returned to home.
I will have to wait several days to begin the lamination of the mold.
Charles
Old Jan 25, 2013, 04:23 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Originally Posted by charlespereira View Post
Hello folks!
This weekend I hope to finish the plug and want to clarify one thing.
Do I need to make a down e right thrust for a pylon?
I have read some topics here and I think that 2 degress down and 0 degress right will be my choice.
Any advice on this subject?
Thanks!
Most electric pylon planes do not add down thrust or right thrust. It is common in some motor-gliders or Hotliners to add down thrust (because they may have higher camber airfoils) but I have never added down-thrust to a Speed 400 size airframe up to 200+mph F5D planes. I have added right thrust only to EF-1 style pylon planes because they have short tail moments and large diameter propellers that create a lot of "P" factor on takeoff.
Troy is offline Find More Posts by Troy
Old Jan 30, 2013, 09:40 AM
Joined May 2008
Thanks Troy!
I have done the plug following what you said.
It is now finished and waxed.
I applied 5 coats of wax. I believe it is enough, because I will use PVA also.
Now will start working on the flanges.
My work schedule for February has only 40 hours of flight and I think that will be able to finish the mold.
Charles
Old Jan 31, 2013, 05:13 PM
Joined May 2008
Hello folks!
All the structure that I built to make the mold is at my parents house, about 110 km far from here. I think that I will be able to go there and finish the mold only in two weeks.
Until there, I would like to discuss the ideas to make the lamination.
To help, the tissues that I have:
- 26g/mē fiberglass
- 85g/mē fiberglass
- 200g/mē Kevlar
- 200g/mē carbon (I couldn't find a less heavy carbon here in Brazil)
Today I cut some sheets of balsa wood on the shape of the wing. THe four pieces have 29g. I don't know if it is heavy or not.
On the first layup, I want to make like this:
- one layer of 26g/mē fiberglass
- one layer of 85g/mē fiberglass
- the balsa wood
Everything cured on vacuum.
The spars made from carbon and the hinges made of Kevlar.
I appreciate any help on this issue. I don't have much experience on the layoup.
Thanks!
Charles
Old Jan 31, 2013, 08:19 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
I would put the 85 gram on the outside, then the balsa, then the 26 grams glass on the inside. You may be able to just use the 26 gram on the inside and outside. If you don't sandwich the balsa between the glass then the wing will not be structurally stable (hold the proper shape).
wyowindworks is offline Find More Posts by wyowindworks
Old Feb 01, 2013, 02:31 AM
timbuck is online now
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
+1
Lay up.... 85/balsa/25..for a light build that will be ok.
Tim
timbuck is online now Find More Posts by timbuck
Latest blog entry: More colours
Old Feb 01, 2013, 07:04 AM
Joined May 2008
Thank you Adam and Tim!
I will follow your advice! It will be fiberglass, balsa and fiberglass again, maybe a 26g/mē on the internal layer.
Between these layers, the carbon, that will be acting as a spar.
Now I ask: is it necessary to make a spar that goes trough the center of the fuselage?
Or using only carbon along the shape of the fuselage is enough.
I don't know if I made myself clear.
Thanks!
Charles
Old Feb 01, 2013, 02:44 PM
Just fly it!
Cody, WY
Joined Nov 2007
I think you will be o.k. if the carbon goes through and follows the contour of the fuse. I would add a few more layers staggered in the area.
Old Feb 05, 2013, 04:15 PM
Joined May 2008
Thanks Adam!
The flanges are now ready.
The next step it to fix them on the mold platform and fill the gap with epoxy.
Today is the last day of my vacations, but on the next week I will have some spare time and will make the mold.
Old Feb 05, 2013, 05:29 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Hey charles, why dont you want to use clay to set your plug into the mould? its much easier than epoxy and seems to give very similar results I have found. Also less chance of wrecking your plug surface being damaged on release.
josh18 is offline Find More Posts by josh18
Old Feb 06, 2013, 04:48 AM
Joined May 2008
Hi Josh!
In fact, I never used the epoxy approach! I wanted to use it to learn a new way.
It seems to me that it should take longer, but the result should be a bit better!
I never got a good seam using clay, maybe lack of experience or patience! :-)
Thanks for your consideration!
Old Feb 06, 2013, 08:17 PM
Just fly it!
Cody, WY
Joined Nov 2007
For pristine parting lines I always use thicken resin to fill the gap between the plug and the parting plane. After it cures I remove the parting plane/plug and block sand the thickened resin flush with the parting board. This makes a nice sharp corner.....although the sharp corner gets rounded out if you are using PVA. If I use PVA I just use clay to fill the gap.
Old Feb 14, 2013, 02:00 PM
Joined May 2008
The mold is done
Hello folks!
This week I was off-duty for three days and finally finished the mold!
It was about 30 hours of work in two days and a half.
Even using wax and PVA it was not easy to pull off the plug, but I am happy to say that it survived with only some minor scratches.
Thanks you all that helped in this job.
Next week I will polish the mold and make the holes for the bolts.
Hope you enjoy the photos!
PS: I will make a movie with subtitles in English next week explaining the details.
Discussion New Electrifly Rifle - All Composite "Sport Pylon" racer/mini hotliner? BTerry High Performance 5042 Jun 02, 2016 12:01 PM
Sold Optic: the original composite micro pylon racer pdawg Aircraft - Electric - Airplanes (FS/W) 3 Oct 10, 2012 06:31 PM
Question Speed 400 pylon racer wing composite construction- Complete! invertmast Composites Fabrication 6 Sep 24, 2012 12:48 PM
For Sale NIB composite pylon racer puerto rico Aircraft - Electric - Airplanes (FS/W) 3 Jul 08, 2011 11:56 AM
Fast Composites Sliver ARF 400 Pylon Racer for sale! Dave Campbell Aircraft - Electric - Airplanes (FS/W) 1 Feb 26, 2002 07:38 PM
