Old Jan 05, 2013, 07:20 PM
timbuck is online now
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
Joggle gasket....
That will work great ..
Here is a link..
http://www.rcgroups.com/forums/showthread.php?t=452100
timbuck is online now Find More Posts by timbuck
Latest blog entry: More colours
Old Jan 05, 2013, 11:36 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Here is how I make joggle tools: http://www.rcgroups.com/forums/showp...&postcount=135
wyowindworks is offline Find More Posts by wyowindworks
Old Jan 06, 2013, 06:28 PM
charlespereira is offline
Find More Posts by charlespereira
charlespereira's Avatar
Brazil, SC, Florianopolis
Joined May 2008
Thank you Tim and Adam for these links!
They are very instructive!
I have read a lot and finally I am on vacation!
Will work a lot on the next days!
Your help is being essential for this project!
charlespereira is offline Find More Posts by charlespereira
Old Jan 06, 2013, 09:49 PM
Just fly it!
Cody, WY
Joined Nov 2007
The thing that really stinks about a joggle gasket seam and a light layup is that the bonding resin can break the seal and run between the mold and the layup. The key is to paint the mold and have the paint go onto the flange about 1/4". You don't want to break this seal when prepping the flanges for bonding.
Old Jan 14, 2013, 08:15 PM
Joined May 2008
Hello!
I have been working on the fuselage plug in the last days, but I confess that the pace is not as good as I thought.
Anyway, the plug is almost done and I did two canopies of carbon fiber.
I wanted to use naked carbon.
After done, I applied some coats of poliester laquer, that is transparent.
I think that the result is quite good and the laquer added only 0,5g; The canopyīs weight is 5,0g. Fair enough!
Now I am thinking about the details before doing the main mold.
For example, should I use a big aileron and put the servos on the root of the wing or even inside the fuselage? Or is it better to make a smaller aileron near the tip of the wing and put the servo inside the wing?
Charles Pereira
www.facebook.com/charles.aeromodelista
Old Jan 16, 2013, 06:39 AM
Joined May 2008
Canopy fit
Hello folks!
Yesterday I did a little depression on the fuselage to make the fit for the canopy.
I tried a new technique (at least new for me) using the canopy as the mold. I fixed the canopy in the place with tape and drilled a hole on the top of it. The idea was to fill the canopy with poliester resin. After the cure, it demolded easily.
The exothermic reaction was strong and the tempture raised a lot, causing some cracks on the resin, but it was corrected. The next time will use less catalyst.
Although this little problem, I can say that it worked quite well and will do it again in a future project.
I painted with primmer and will sand it later.
The fit got very nice.
Charles Pereira
Old Jan 16, 2013, 08:06 AM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
very nice....keep up te great work.
doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Jan 17, 2013, 10:44 AM
KASL is offline
Find More Posts by KASL
Joined Apr 2011
Originally Posted by charlespereira View Post
Hello!
Finally i found the time to make the video tutorial showing the construction of the tail mold.
It is narrated by me in Portuguese, but I think the images speak for themselves.
Maybe I will put subtitles on it.
Hope you enjoy!
http://youtu.be/JL--s1HDr5c
hello Charles, i have a a question. What is the viscosity of the resine used in the video? and its polyester or epoxy?
KASL is offline Find More Posts by KASL
Old Jan 17, 2013, 06:33 PM
Joined May 2008
Hello!
The resin and the gelcoat used to make the mold are polyester.
I canīt tell about the viscosity, because I have always used the same products, but I think it is a medium viscosity.
On the lamination process I will use only epoxy.
Old Jan 18, 2013, 07:12 AM
Joined May 2008
Hello folks!
This weekend I hope to finish the plug and want to clarify one thing.
Do I need to make a down e right thrust for a pylon?
I have read some topics here and I think that 2 degress down and 0 degress right will be my choice.
Any advice on this subject?
Thanks!
Old Jan 18, 2013, 10:11 AM
KASL is offline
Joined Apr 2011
Hello!
Yes, i got it. I use polyester resin to make my molds with a viscosity of 400mPa.
what is the name of your epoxy resine?
thanks! kelvin.
Old Jan 19, 2013, 04:33 PM
Joined May 2008
thanks! kelvin.
The resin is Araldite LY-5052 and the hardner is Aradur 5052.
This is the data sheet of the resin: http://www.aerosol.co.il/files/artic...51066y66Ws.pdf
Old Jan 21, 2013, 07:29 PM
Joined May 2008
Plug painted
Hello folks!
This weekend was of a lot of work on the Vectus project.
I have never sanded so much, but I am glad to say that today I could finally paint the plug.
I used poliurethane paint. In others projects, I simply painted using primer, but I think that with paint the finish is better.
I am wainting the paint to dry. After that will start the polishing. Is the 2000 grit sandpaper ok?
Meanwhile, I started the steel skeleton of the mold. Made of 16mm tube in a square shape.
Maybe tomorrow it will be finished.
Old Jan 22, 2013, 08:19 PM
Joined May 2008
Hello!
Today I did the polishing of the plug.
I used dry sandpaper, grit 280, 400 and 600.
After sanded with water with 1500 and 2000 sandpaper.
Tomorrow will start to wax.
Notice that the plug has some stains on the painting. That is because I used two different tones of blue. It helps to show when it is time to stop sanding.
I also finished today the platform that will support the skeleton of the mold and the flanges.
Hope you enjoy!
Charles
Old Jan 22, 2013, 08:35 PM
Glendale,Az.
r u going to ramp up clay or bondo to the wing leading edge since it does not look like your splitter plate is not level with the LE?
I have done that before- but the clay ramped up does not leave a very nice finish?
doug
Discussion New Electrifly Rifle - All Composite "Sport Pylon" racer/mini hotliner? BTerry High Performance 5039 Sep 23, 2015 08:45 AM
Sold Optic: the original composite micro pylon racer pdawg Aircraft - Electric - Airplanes (FS/W) 3 Oct 10, 2012 07:31 PM
Question Speed 400 pylon racer wing composite construction- Complete! invertmast Composites Fabrication 6 Sep 24, 2012 01:48 PM
For Sale NIB composite pylon racer puerto rico Aircraft - Electric - Airplanes (FS/W) 3 Jul 08, 2011 12:56 PM
Fast Composites Sliver ARF 400 Pylon Racer for sale! Dave Campbell Aircraft - Electric - Airplanes (FS/W) 1 Feb 26, 2002 08:38 PM
