Old Nov 23, 2012, 11:43 AM
charlespereira is offline
Find More Posts by charlespereira
charlespereira's Avatar
Brazil, SC, Florianopolis
Joined May 2008
Build Log
Vectus Racer - All composite pylon build log
Hello everyone!
My name is Charles and I live in Brazil!
Since last march I have been working on my project, that I called Vectus Racer.
I have few experience with composites fabrication. I have done only 3 or 4 models using fiberglass.
The plug is almost done and in few weeks I will start making the molds.
My intention is to use carbon fiber, Kevlar and fiberglass on the layup process.
I hope to have some help here and also contribute somehow.
High resolution photos can be found on my Facebook page: https://www.facebook.com/vectusmodels
The construction of the plug is on this site: http://www.e-voo.com/forum/viewtopic.php?t=129627
Cheers!
Charles Pereira
charlespereira is offline Find More Posts by charlespereira
Last edited by charlespereira; Aug 30, 2013 at 09:29 PM. Reason: It is a build log
Old Nov 24, 2012, 04:09 AM
timbuck is offline
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
Sweet ship Charles..
You doing a one piece fuze and wing mold ?? With separate tails ??
Tim
timbuck is offline Find More Posts by timbuck
Old Nov 24, 2012, 04:07 PM
Joined May 2008
Tim
Thank you Tim.
Yes, it will be a single mold for the wing and fuselage.
I am not sure about the tail yeat. I will do the V shape in a separeted mold or it will be integrated with the fuselage mold.
Another doubt is about the live hinges. I have never done that. I don't know if it is a bood idea to make a groove on the place of hinges.
Charles
Old Nov 24, 2012, 07:08 PM
timbuck is offline
Nothing is easy
timbuck's Avatar
Joined Aug 2008
Cool.
But do the tail separate.. better for releasing .
Try Kevlar hinges.. Very easy. Just when you lay up , don't do any cloth on the inside of the kevlar.
This is how we do it..
cutting the Aileron's into a moulded wing. (22 min 40 sec)
Old Nov 25, 2012, 07:23 PM
Joined May 2008
Thanks Tim for the very instructive video!
I will follow it when do my first lay up.
As I work as a first officer in an airline company, a have few spare days and the construction pace is slow.
Today I worked on some refinements.
I will follow your advice and make a separate mold to the V-tail.
Soon we will have the mold.
I already did the canopy mold and a lay up test with carbon fiber and fiberglass. The carbon fiber is a little bit heavy, with 200g per square meter, but it was the only that I found here in Brazil.
English is not my first language, so please, correct me if I am writing something wrong.
Cheers!
Charles Pereira
www.facebook.com/charles.aeromodelista
Old Nov 30, 2012, 01:50 PM
Joined May 2008
Hello!
Today I have finished the tail.
Applied the primer and now it is time to cut the tail e make the mold.
I believe that it will be better this way, since that with a small mold, I can try different combinations of tissues during the layup.
Old Nov 30, 2012, 01:59 PM
timbuck is offline
Nothing is easy
timbuck's Avatar
Joined Aug 2008
Very cool looking plane , if it fly's 1/2 as good as it looks it will be amazing
Tim
Old Dec 05, 2012, 07:02 AM
Joined May 2008
Tim
Thanks Tim!
Now I am thinking about the tail linkage.
The tail is a bit small. Do you think it is a good idea to make a internal linkage to avoid drag?
Old Dec 05, 2012, 01:36 PM
timbuck is offline
Nothing is easy
timbuck's Avatar
Joined Aug 2008
Maybe if you can.
Check Sailplane set up for the best idea's.
IMO. I would cut off the fuse behind the tail... Then both control horn will be inside fuse cavity.
It will be push for up , but with a good carbon rods for linkages it will be fine.
And make a small mold for the end cap to go over them.
Old Dec 05, 2012, 04:01 PM
Joined May 2008
Maybe if you can.
Thanks Tim!
I will give it a try!
Today I took the courage and cut the tail.
I sanded with a 320, 1500 and 2000 grit sandpaper.
Tomorrow will apply the wax and begin the mold!
Old Dec 11, 2012, 06:50 PM
Joined May 2008
Hello!
In the last days, I have worked on the tail mold.
Today I cleaned the half of the mold and put gelcoat on the other half.
I hope to demould with no problems tomorrow.
I am recording everything on movie and if it gets right, on this weekend I will publish a movie!
Cheers!
Old Dec 11, 2012, 06:58 PM
timbuck is offline
Nothing is easy
timbuck's Avatar
Joined Aug 2008
Congrats Charles looks great.
Tim
Old Dec 11, 2012, 11:04 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Bom trabalho! If you can't tell, I kind of like pylon designs.
Troy is offline Find More Posts by Troy
Old Dec 12, 2012, 09:50 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Looks fantastic! If you decide to sell a few later on, i'd be interested
invertmast is offline Find More Posts by invertmast
Old Dec 13, 2012, 06:52 AM
Joined May 2008
Thank you guys for all the comments!
The tail mold has cured and it was easy to release the plug.
This weekend I will sand the mold and in a few days will do the first layup, I hope!
Discussion New Electrifly Rifle - All Composite "Sport Pylon" racer/mini hotliner? BTerry High Performance 5042 Jun 02, 2016 12:01 PM
Sold Optic: the original composite micro pylon racer pdawg Aircraft - Electric - Airplanes (FS/W) 3 Oct 10, 2012 06:31 PM
Question Speed 400 pylon racer wing composite construction- Complete! invertmast Composites Fabrication 6 Sep 24, 2012 12:48 PM
For Sale NIB composite pylon racer puerto rico Aircraft - Electric - Airplanes (FS/W) 3 Jul 08, 2011 11:56 AM
Fast Composites Sliver ARF 400 Pylon Racer for sale! Dave Campbell Aircraft - Electric - Airplanes (FS/W) 1 Feb 26, 2002 07:38 PM
