Old Nov 23, 2012, 08:27 AM
Joined Nov 2012
Servo problems. HELP!!
The sail servo on my Joysway Focus 1m RC Yacht has suddenly decided to stop working. It has gone very tight and does nothing at all. The servo for the tiller is also behaving in an odd way, twitching as if there is some interference. Has anyone got any ideas? I'm fairly new to RC yachts so any help would be greatly appreciated. Many thanks.
Gullukman is offline Find More Posts by Gullukman
Old Nov 23, 2012, 09:39 AM
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
Replace the servo. Sounds like it may have gotten wet and gone bad. Standard servo's are cheap.
Guz is offline Find More Posts by Guz
Old Nov 23, 2012, 10:28 AM
United States, CA, Alameda
Joined Nov 2010
It may be a radio issue. Pull the receiver out and plug in to a generic servo and see if it works.
If that works, start by testing your servos in the boat. Hopefully that will yield some results.
Also see if there is an RC sailing club near you and ask for help, bet there would be someone there that could help you. Ryan
Rssailor is offline Find More Posts by Rssailor
Old Nov 23, 2012, 12:54 PM
Joined Nov 2012
Many thanks for the help. I'll look into it.
Old Nov 24, 2012, 12:30 AM
Australia, TAS, Penguin
Joined Mar 2012
@Gullukman:
I believe that what you are describing is the classic symptoms of radio problems - it could be either a wet / corroded radio or radio interference as the two most likely causes.
The tight sail servo may actually be Ok - it may have been driven hard one way by the faulty radio. Test the servo separately if you have anything available to do so. Other possibility is that the servo has stripped gears or is otherwise damaged by being driven past its end point. You coupld open it and have a look or just replace it - they are cheap as chips from HobbyKing and many other suppliers.
Hope this helps....
mrpenguin is offline Find More Posts by mrpenguin
Old Nov 24, 2012, 02:20 AM
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
A bad receiver battery can also cause jitter.
SoloProFan is offline Find More Posts by SoloProFan
Old Nov 24, 2012, 06:28 AM
Blackpool, Lancs
Joined Feb 2006
And tired wiring and connections.
The standard servo working the sails on my second hand Victoria was useless in any wind stronger than "moving air" so it was replaced by a cheap hi-torque one. In use, that showed up the need for a new battery and wiring loom, due to jitter.
Assuming the sail servo does not regulate the power to the rest of the system, a quick check is to just unplug the sail servo. If the rudder servo then responds properly, the problem would be unstable battery voltage caused by the load imposed by the sail servo.
mfr02 is offline Find More Posts by mfr02
Old Dec 02, 2012, 06:08 AM
Joined Nov 2012
Many thanks for all the help gentlemen. I seem to have fixed the problem and all is now working correctly.
Old Dec 02, 2012, 06:28 AM
Joined Mar 2012
And the problem was.......????
Old Dec 25, 2012, 12:47 PM
lilleyen's Avatar
Ontario Canada
Joined Mar 2009
Yes, inquiring minds would like to know....
I had a similar problem and it turned out to be a rusty circuit board inside my sailboat servo (for instance)
My new servo got dissasembled, sprayed with Corrosion X and put back together with silicone sealant around the case joints.
Enough of that water damage nonsense!
So let us know, so we can add that knowledge to our data banks.
lilleyen is offline Find More Posts by lilleyen
Discussion new servo problem !! please help !! Ofir Radios 11 Mar 28, 2012 02:17 PM
Discussion please help !! New servo simple problem !! Ofir Electric Plane Talk 6 Mar 28, 2012 07:08 AM
Help! please help !! New servo simple problem !! Ofir 3D Flying 2 Mar 28, 2012 06:54 AM
Help! please help !! New servo simple problem !! Ofir 3D Foamies 3 Mar 26, 2012 04:41 AM
Discussion Servo problem, please help rc_newbie1991 Beginner Training Area (Aircraft-Electric) 7 Mar 24, 2012 12:45 AM
