Old Nov 23, 2012, 01:24 AM
See is offline
See
Find More Posts by See
See
Joined Mar 2012
elogger v4 very hot on 12S Setup???
hey there,
used a v4 on 6S and it was no problem.. but now i changed to 12S and it gets very hot even I did not start the engine... just when i plug in the motor-lipos it starts heating up and after 1-2 minutes it's veryyyy hot....
whats the problem?
best
Sebastian
See is offline Find More Posts by See
Old Nov 23, 2012, 03:42 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, it's normal for the eLogger to get warm under those circumstances. If the eLogger gets too warm, the voltage regulator will shut off, so no problems should be caused by it unless you are seeing a shutoff. Note that if you are using accessories with the eLogger, you should use a battery backup harness as described in the manual.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Nov 24, 2012, 04:10 AM
See is offline
See
See
Joined Mar 2012
hi,
ok. but after 1-2 flights the logger did not show up on the screen at all.. mhh
also the BatteryV gets from 45 to 52 V on the display.. ?
the backup harness is installed..
best
Old Nov 24, 2012, 12:48 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, on which screen did the logger not show up?
Site Sponsor
Old Nov 25, 2012, 05:33 AM
See is offline
See
See
Joined Mar 2012
hi
the screen of the video osd... seems for me that it gets too hot and shut down the signal for osd...
best seb
Old Nov 26, 2012, 12:42 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi See,
With the backup harness installed, that should not be possible. Are you sure the harness is installed correctly? If it is installed correctly, the LED should be blinking on the eLogger even when no main pack is connected to the eLogger.
Site Sponsor
Old Nov 27, 2012, 09:07 AM
See is offline
See
See
Joined Mar 2012
Originally Posted by billpa View Post
Hi See,
Hi,
i send the logger to the factory today...
the backup harness is installed correctly and the unit suffers from a second lipo unit across this harness.. blinking even when the main lipo is not connected to the motor... i think it's broken...
best Seb
Discussion Elogger V4, driver install not successful on Window &7 kentli22 Eagle Tree Systems 6 May 12, 2015 12:09 AM
For Sale Aero Works 35cc running on 12s setup The Duck Aircraft - Electric - Airplanes (FS/W) 6 Oct 02, 2012 11:18 AM
For Sale Aero Works 35cc running on 12s setup The Duck Aircraft - Electric - Airplanes (FS/W) 2 Oct 01, 2012 10:58 AM
Sold Eagle Tree Systems OSD Pro, GPS V4, eLogger V4, and Guardian constantmotion FPV Equipment (FS/W) 8 Apr 15, 2012 10:26 AM
Sold Eagle Tree Systems ELogger V4 150A GPS V4 Expander willy43 FPV Equipment (FS/W) 0 Mar 11, 2012 07:42 PM
