Old Feb 06, 2013, 02:06 PM
nutso is offline
Find More Posts by nutso
Joined Dec 2012
thanks! i replaced the motor arm and just put the wires, thru the 3 pin and pulled them too the sides it worked but probably not for long! now i think imma have 2 replace another arm and motor! think i might just get a new one!
nutso is offline Find More Posts by nutso
Old Mar 01, 2013, 05:37 AM
gimmemopitch is offline
Find More Posts by gimmemopitch
Germany, HE, Darmstadt
Joined Jan 2013
Originally Posted by Stenkryparen View Post
Mounted the old board from my worn out V929 (rev:01 2012/06/23) in the X200 frame.
Motor connection
Red wire from X200 motor arm connected to plus side on V929 socket.
Green wire from X200 motor arm connected to minus side on V929 socket.
LED connection
All four black wires from X200 motor arms connected to one 470ohm resistor (0,25W), other end of resistor soldered to minus on the V929 board.
The mod is done in 1/2 hour.
The X200 is after mod a great flyer, and will fulfill the task to be a stable carrier for a key chain camera.
(Transmitter used is VL toys "RTF E728" ) at 40% rate it is tame.
Weight with LiPo excluded is 69,4 gram.
Here is pictures that show my modification.
do you still fly it in this configuration? still liking it?
did the mounting holes of the v929 pcb fit the frame/battery holder of the mjx200 exactly?
the new v959 rx PCB could also be of interest to mod the frame of the mjx200.
gimmemopitch is offline Find More Posts by gimmemopitch
Old Mar 04, 2013, 11:52 AM
Stenkryparen is offline
Find More Posts by Stenkryparen
Get Airborne
Sweden, Skåne County, Hofterup
Joined May 2012
Yes the modified X200 is still alive, but I mostly fly this Quad (Crab 20).
Next plan for the X200 is to fit KK2, 4 ampere ESC and micro brush-less motors.
The frame is light weight and rigid, so this could be a agile quad.
Stenkryparen is offline Find More Posts by Stenkryparen
Old Mar 12, 2013, 01:41 AM
bob cripe is offline
Find More Posts by bob cripe
United States, NV, Laughlin
Joined Oct 2012
pinion gears
Any body know where I might be able to buy the 12T Plastic Pinion Gears for the MJX x200.
bob cripe is offline Find More Posts by bob cripe
Old Mar 30, 2013, 11:38 AM
blackd is offline
Find More Posts by blackd
Joined Mar 2013
Hello everybody, I have a question. Did anyone try to replace the remote controler with some proffesional like Futaba or JR? Any info is welcomed...
blackd is offline Find More Posts by blackd
Old Apr 23, 2013, 04:29 AM
dfxos is offline
Find More Posts by dfxos
photographer
dfxos's Avatar
Bulgaria
Joined Apr 2013
deleted
dfxos is offline Find More Posts by dfxos
Old May 22, 2013, 03:40 PM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
MJX x200-959
When I first got my x200, I disliked the programming, flight characteristics and transmitter.
A v959 pcb transplant took care of all issues for me:
regards . . . g
Video Slide Show:
x200mod (3 min 8 sec)
gordonzo is offline Find More Posts by gordonzo
Old May 30, 2013, 08:11 AM
asanovrus is online now
Find More Posts by asanovrus
asanovrus's Avatar
Ukraine, Crimea, Bakhchysarai
Joined Mar 2012
did someone compare x200 with 998? seem to have the same motor holders. does 998 have booms the same like wl toys(carbon) or like x200(aluminum)? which one is heavier?
Or are they just the same quad?
There seem to be 2 cameras: c4003(mjx x200) and NO.V001(998) or are they again the same camera?
asanovrus is online now Find More Posts by asanovrus
Old Aug 04, 2013, 10:34 AM
ikhabot is offline
Find More Posts by ikhabot
Joined Mar 2013
regards . . . g
Video Slide Show:
http://www.youtube.com/watch?v=gKaQFbqBvx0
That's pretty cool man. Were you able to bind the new board with the stock MJX X200 transmitter?
ikhabot is offline Find More Posts by ikhabot
Old Aug 04, 2013, 02:32 PM
gordonzo is offline
gordonzo's Avatar
Joined Jan 2011
No, it binds with the v959 or similar transmitter with Flysky protocol.
I did not like the x200 transmitter nor pcb firmware at all.
regards . . . g
Old Aug 19, 2013, 01:44 AM
ikhabot is offline
Joined Mar 2013
Thanks for you answer man... I was wondering if there is any chance to bind it to Spektrum TX?
Old Aug 19, 2013, 07:13 AM
Darsh is offline
Find More Posts by Darsh
Tinkerer of makeshift failures
Darsh's Avatar
Joined Jun 2012
No way Jose. Not with the stock pcb at least; you'd need to replace it with a spektrum compatible one. Many people are using the NanoQX board on this size quads now; this thread should provide you with all relevant information. Be warned thou, you'll need to fiddle with the connectors (and lose the leds).
Darsh is offline Find More Posts by Darsh
Old Sep 18, 2013, 12:19 PM
javierjafio is offline
Find More Posts by javierjafio
Joined Sep 2013
Hi, i have the x200 and now it doesn't turn on, in the main board the bobbin its disconnected, could anyone help me, i need to know how should i find a new one and how i should i weld it. Name: x200-07.jpg
Description:
javierjafio is offline Find More Posts by javierjafio
Old Jul 16, 2014, 01:06 PM
ehsancgfx is offline
Find More Posts by ehsancgfx
Joined Jul 2014
just bought the quad but now i cant conenct the controller with the quad. its just keeps blinking and doesnt conenct. what is the exact procedure ? it should be fairly simple .. isnt it ? just turn on the move the throttle a bit ..
ehsancgfx is offline Find More Posts by ehsancgfx
Old Oct 24, 2015, 05:11 AM
modelmaker56 is offline
Find More Posts by modelmaker56
modelmaker56's Avatar
Lebanon, Mt Lebanon, Kesrouane
Joined Aug 2006
Okay, latest update after fighting to get that optional cam I bought for my X200 working:
That thing won't work if you haven't formatted the memory card, so if ever you've already taken some pics or vids as it came new out of the box, you have to insert the memory card into the USB adaptor and into your computer port, open it on "My Computer", watch and remove your files, then format it and eject it..
Only then will it take pics or vids again when you insert it back into the quad camera, otherwise it won't work and the camera will stubbornly keep its green light on as if it was not receiving any order from the transmitter 5th channel top right red button... Take care to select the lowest performance on that lower power button (the upper one of the two black oval ones).
You will have to do same after every cam session (of course you should cut and paste your vids and pics into a folder on your desktop first then do the formatting).
And btw, the cam will automatically take 3 consecutive Still photo shots for every flick of the transmitter red button... Video runs indefinitely till the memory card is full...
I found that out after 2 hours tinkering and a couple Chivas Regal drinks.. cheers from Beirut !!!
modelmaker56 is offline Find More Posts by modelmaker56
Sold MJX X100 2.4G 6-Axis Quad copter Bryan's Flyin Aircraft - Electric - Multirotor (FS/W) 1 Oct 15, 2012 06:48 PM
Sold Mini & Micro Quad's---BNF--Micro $120--Mini $175 Shipped ldm1839 Aircraft - Electric - Multirotor (FS/W) 0 May 19, 2012 07:26 PM
Sold Quad Addict blue plexiglass mini-quad frame Sid3ways Aircraft - Electric - Multirotor (FS/W) 1 Apr 15, 2012 09:21 AM
