Old Nov 22, 2012, 08:30 PM
summitspur is offline
Find More Posts by summitspur
Joined Nov 2012
Help!
Electric
Does anyone happen to know where I can get an electric motor repaired in the vancouver area, it's from a vintage merry go-round and the gears are stripped
It;s been in the family for years, and brought out every xmas.so would like to pass it on It's an AC motor, 5/6 RPM
Any suggestions would be appreciated
summitspur is offline Find More Posts by summitspur
Old Nov 22, 2012, 09:09 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Summitspur;
Welcome to RCG!
Is it a human sized merry go-round?
Check your local yellow pages for an electric motor repair shop.
I had my 5000 watt gas generator rotor re-wound for $400 a few years back.
EC Company,
http://www.ecpower.com/Locations/
Just occurred to me, you may be asking about fixing a christmas decoration.
It may just require a new motor. Can you post a photo of the broken parts?
Regards
Rick
Damascus Oregon
rick.benjamin is offline Find More Posts by rick.benjamin
Old Nov 23, 2012, 02:27 PM
Joined Nov 2012
electric motor
Sorry , I guess IName: IMG_20121123_121448.jpg
Description: it is 120 v- 5/6RPM should have mentioned that is a Christmas decoration
Old Nov 23, 2012, 03:10 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I'm guessing if you removed the cover shown in the photo you will find a set of gears not unlike what you find in a RC servo. The actual motor will be under the gear set. Remove the gears and clean well then relube with light grease. I've seen some of this grease turn into "glue" that is almost impossible to remove When it is all apart plug in the motor to see it it runs. A drop or two of oil may be in order. If it is the type of motor I think it is they do not normally "go bad". They have very little torque so everything must be in top notch condition to work properly.
Good luck and keep us posted.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Nov 23, 2012, 03:32 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
That looks like a fairly common synchronous timing motor as used in a lot of small appliances, and 5/6 rpm would be about the speed used for the turntable on microwave ovens. You might search your local yellow pages for a local mom and pop appliance parts store. If not you could order one off Ebay. http://www.ebay.com/itm/Robust-Small...item23257183c7
jeffs555 is offline Find More Posts by jeffs555
Old Nov 25, 2012, 02:34 PM
Joined Nov 2012
Thank you
Thank you everyone for your suggestions, I will follow up on them and let you know
Old Nov 26, 2012, 05:07 PM
Reduce the drama...
USA, OR, Damascus
Joined Apr 2004
Found these offerings on eBay
http://www.ebay.com/sch/i.html?_nkw=...7762958&crdt=0
If not an exact match, can be a source of parts.
Old Dec 05, 2012, 09:59 PM
ergocentric is offline
Find More Posts by ergocentric
Aircraft re-kitter
ergocentric's Avatar
15NM from CYYZ on 06L
Joined Feb 2007
try an appliance parts shop, looks like an old stove click motor
ergocentric is offline Find More Posts by ergocentric
Old Dec 08, 2012, 06:41 AM
XtalHunt is offline
Find More Posts by XtalHunt
United States, TX, Austin
Joined Sep 2012
It is actually an electric clock motor, that's what it had originally been used in back to the 70's.
Find some here: http://AllElectronics.com
XtalHunt is offline Find More Posts by XtalHunt
Reply With Quote  (Disabled)
Old Dec 08, 2012, 06:50 AM
XtalHunt is offline
Joined Sep 2012
What's a stove click
Old Dec 13, 2012, 06:48 PM
Aircraft re-kitter
Joined Feb 2007
duh, typo, clock, stove clock motor
I saw a box of them at A1 Electronics last week, they would be happy to sell you one and mail it to you.
http://www.a1parts.com/index.html
Old Dec 14, 2012, 07:46 PM
Gil Gauger is offline
Find More Posts by Gil Gauger
Play loud, Fly high
Gil Gauger's Avatar
Vincennes,IN USA
Joined Apr 2007
New motor
Similar motors are use on disco mirror balls. Here is an example:
http://www.samash.com/p/American%20D...FUZgMgodjSAAwA
Gil Gauger is offline Find More Posts by Gil Gauger
Wanted Parts for either a Cox Electric Sundance or Electric Malibu ALL American Aircraft - General - Miscellaneous (FS/W) 0 Mar 28, 2012 02:58 PM
Wanted Parts for - Cox Electric Sundance or Electric Malibu ALL American Aircraft - Electric - Airplanes (FS/W) 0 Mar 28, 2012 02:57 PM
Help! NEW TO ELECTRIC ( wanting to convert to electreic) Jeffreyheslop9 Glow to Electric Conversions 6 Feb 26, 2012 07:01 AM
