Old Dec 04, 2012, 01:42 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
So after delicate surgery to remove foam to rout wires and such, I had to seatbelt in some wires and used silkspan for that. I sealed the ESC opening with a piece of wax paper also, so that no glue will get into it during assembly of the airframe. May not be needed, but insurance is cheap and light.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Dec 04, 2012, 01:48 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
My tiny hatch needed something to keep it from departing and also from pushing into the airframe when installed, so I am using some tabs. These are made from file folder card stock, and stiffened plus installed with CyA glue. They do not wigh much, but are very strong at this scale.
My airframe at 1/48th sclae seems small sometimes, yet seems large others. Go figure.
Next I glued the wng on. Everything is so small that if anything goes out, it will be lots of work and surgery to repair. That or scrafice the airframe to the gods of flight (LOL). If she flys, great, if she flys good, better. If she lasts a while, perfect! I am prepared for whatever the results bring.
Fred
Old Dec 04, 2012, 01:55 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
What would a Mirage 2000 be if it didn't have the wing strakes aft of the TE? So without adding too much weight, I have to have some of the outline details "Just Because". 3mm depron strakes pre-cut, sanded, and such. Glued in place the bottom needed a flaring piece whih was 1mm depron, thinned out no less! Sanding 1mm depron to say 0.4mm in spots was interesting. Got to love foam plates for donating parts to science!
Fred :
Old Dec 04, 2012, 02:54 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
subbed a little late... looks great!
nemoskull is offline Find More Posts by nemoskull
Old Dec 04, 2012, 04:26 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Thanks, and it is never too late.
F
Old Dec 05, 2012, 09:23 AM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Now getting ready to glue the front cockpit and nose cone assembly to the airframe. I fit the canopy and marked where to glue it on, and then made an opening for the actual cockpit. This is mainly for looks, but allows me some access to the RX as I assemble.
I used ink to blacken the inside, but after all the handling there was a second coat of sealer, a bit of silver paint under where the greenhouse goes, and some CyA for spot gluing as I worked, and it always adds a bit of weight. We now have gained another 0.1g. It is important early to try to keep weight off for these times it goes right back on! What a pain, LOL.
Fred
Old Dec 05, 2012, 09:26 AM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Tail fin added and final glued into position. Ready to finish up and get this thing into flight testing.
Fred
Old Dec 05, 2012, 09:34 AM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
I guess this puts some perspective on the build. What you are looking at is the Orange Micro Receiver, mounted on the front of the airframe, ready to button it up using the nose section. Looks huge to me! LOL.
Someday I'd like to own some of the cool super sub-micro electronics, but it seems a great RX, 2 servos, and ESC could cost in the $350-$400 USD range. Might be worth it, and I could stretch for that, but then it would make my common man's builds out of reach for the masses. I do so try to use affordable parts and make it possible for everyone.
I did glue it in place, using Bathroom adhesive caulking. I does not hurt foam, is fairly light, flexable, and holds well. I figured this to be lighter than foam tape and whatever you choose to keep the tape stuck to foam. Horizon Products use this type of glue. What I did learn by experimenting, is if you drip alcohol on the caulk, let it sit a moment, and start to rub at it with say, a toothpick, it will soften right up for removal from your parts!
Fred
Old Dec 05, 2012, 02:59 PM
nemoskull's Avatar
Joined Sep 2009
you might look into one of the DT rx's. if you can solder, you can get a .7 gram rc/esc and use the same servos for in the 50 shipped range. i usualy get mine direct from DT.
you could drop a couple grams pretty quick.
that thing is a work of art!
Old Dec 05, 2012, 04:32 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
mirage 2000 is one of my favs! looks awesome!
corsair nut is offline Find More Posts by corsair nut
Old Dec 05, 2012, 05:04 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Thanks, and I'll have to check that out after my Christmas season wallet cools off......
Thanks CN. I like your's that you fly and have on your Avitar. I am going to look for a simple Camo scheme that I might be able to mist a 'Ghostly color' effect on to keep weight down, Other than that, pushrods and horns, we are ready to fly!
Fred
Old Dec 05, 2012, 06:51 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
if he wants to use the same connectors as the 1.7 gram servos and the orange receiver he is using now, the rx-34 uses the same ones. it only weighs 0.68 grams too
derk is offline Find More Posts by derk
Old Dec 05, 2012, 07:53 PM
nemoskull's Avatar
Joined Sep 2009
i know that one, it rock! 6 ch, tho the oter two are pads, and the ESC is a pad as well. still comes in under 1g with the brushed esc connector.
Old Dec 05, 2012, 09:14 PM
jumo004 is online now
Find More Posts by jumo004
jumo004's Avatar
Joined Apr 2010
just curious, DT is who ?
Thanks.
jumo004 is online now Find More Posts by jumo004
Old Dec 05, 2012, 10:38 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Thanks.
Deltang, I'm sure. Bob Selman of BSD Micro RC has them, here is a link. http://bsdmicrorc.com/index.php?categoryID=63&offset=0 Many to choose from, most appear to be under $50.00.
I got my RX down to 2g, so the weight savings would be 1.3g(+), and I think they have the ESC onboard, or it too can be lighter than mine (Mine 1g). Got to educate myself before I plunge that direction though. Actuators, sub-micro servos, so many choices. Probably could even save a bit on the battery. I a few years, who knows what they will have...... Always thought about a 900mhz system too.......
Fred
Discussion 1/48th scale tug boat fittings...where are they? Predreadnut Scale Boats 10 Oct 17, 2012 02:12 PM
Discussion Huge pink foam Mirage 2000 90mm edf kingkyle Foamies (Scratchbuilt) 2 Aug 27, 2012 03:59 PM
Build Log mirage 2000 C (2000-5) wora Scratchbuilt EDFs 10 Jul 28, 2011 09:12 AM
Discussion big "GRAUPNER" Mirage 2000 955mm wingspan Pippin Foamy EDFs 30 Oct 29, 2007 12:08 PM
