Old Nov 24, 2012, 11:56 PM
MustangAce17 is offline
Find More Posts by MustangAce17
EDF Addicted
MustangAce17's Avatar
United States, FL, High Springs
Joined Sep 2005
Fred, I could make up a bl 22mm just as easily. I'm tempted to mold one of my plastic models and i wish i still had my nice 1/48 mirage, can't seem to find it
MustangAce17 is offline Find More Posts by MustangAce17
Old Nov 25, 2012, 08:16 AM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Wow Fred! Your very good at cutting those foam formers with integrated ducting. Seems like a good construction method at this small scale. Watching with interest!
pdawg is offline Find More Posts by pdawg
Old Nov 25, 2012, 09:48 AM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Thanks for sharing that thought. The molding of a Mirage would be cool, but I think a 22mm system needs to be kept very light. I will guess my airframe is going to push 6g, maybe 7g? And if painted???? With my standard micro gear (2g RX, 2g servos, 1g ESC, 3g battery, and all related wire, rods, etc) it may be too heavy???? Any idea how much a molded airframe might weigh? Of course if depron was heated and formed into a shell that would be something also????????
Got my thinking cap on anyway. I have a 1/48th scale Convair Delta Dart model. That is cool and very similar, yet has some interesting shapes going on. Might have to pull that down again someday and look it over. Thanks again. Any work on that idea please do share.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Nov 25, 2012, 10:00 AM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Thanks Bret,
I don't know for sure so some of you guys can chime in, but it seems that by cutting the airframe to have everything intregrated is very light? 3.1g bare foam, and not much more filled and sealed. Wing and fin will add at least 3g. It is not Durobatics, but when I weigh Depron sheets it almost seems heavy?
I want to try a 40mm jet in this fashon (yes 40mm, I;m ashamed) but I put togeteher a custom cut down unit using a Hyperion 5800kv motor that is itching to be used. I would think wieght wouldn't be too much either, and the 3 dimensional shapes really add strength because of all their curves. Will have to do it soon.
Fred
I'll get some progress photos up later.
Old Nov 26, 2012, 12:21 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Fred, I'd love to have a partial kit, just so happen to have a gp 30mm fan we could snug in there if anything
Had to take this photo after your post. This is why we can not fit a 30mm into this 1/48th scale Mirage. LOL, this gives a good idea how small it really is. That is a super lightweight Air Hogs 30mm EDF BTW. However I'll be posting soon a new rotor I made for the BIM 22mm EDF is giving equal output as the AH 30mm EDF. . .
Fred
Old Nov 26, 2012, 12:29 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
I posted the other night and as promised I took a photo of the 1/48th scale Mirage profile chuck glider I made. It is pretty cool as I weighted it down with coins and a watch battery to check the glide and flight envelope with a proposed final weight of my full fuselage version.
Interesting and educational. The CG range is pretty close to calculations, and I am guessing some reflex might be in order when we get power to it. Depending on how I throw it makes a huge differance on it flying on rails, or doing a steep angled glide like a lawn dart (Lawn dart on rails). However get the CG too far back and it starts to go high alpha and stall about 20 feet out?????
Got to love scratch building!
Fred
Old Nov 26, 2012, 01:15 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
1/14th or 1/48th? This is the same size as the build right?
Knife Liddle is online now Find More Posts by Knife Liddle
Old Nov 26, 2012, 01:16 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
That thing is tiny!
Old Nov 26, 2012, 01:42 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Opps, my bad, I corrected the typo, 1/48th scale. Most often I have trouble typing and have to edit many mistakes. It has nothing to do with my spelling! LOL.
That thing is tiny!
Funny it was looking kinda big to me in person, but maybe that is because I'm used to it. LOL
Fred
Old Nov 26, 2012, 01:55 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
The wing was 3.2g as a rough cut blank. Cut a channel to mount the fuselage, sanded some airfoil shape to it, and it came down 1g to 2.2g AUW. This is good because sealing and paint will put the weight back on!
Then for a referance, the roughed fuselage sections were piled on and we have 5.2g. I will do another weigh-in after sealing and sanding. Wish I was OK with ink finishes, but I am not.
Fred
Old Nov 26, 2012, 02:07 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
I got around to drawng up the wing in my Airfoil program, Comp-U-Foil. It calculates the CG, and gives me specifics including wing area. So the results are in we have approximately 24.82 Square Inches of wing area. We will use 25 SqIn for all practical purpose.
This is my caculations if I am correct, then if I end up at 22g (lucky, but heavy), I would have 4.4699 Ounces to SqFt wing loading, not counting the fuselage sections outside the wing. No lightweight, but within reason I think. At this small scale that seems like a lot!
Fred
Old Nov 26, 2012, 06:45 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
After I sealed the wing using Polycrylic and some tinting to give a blackish-gray tint to the foam. This added 0.5g, or less than 25% of the exsiting weight of the wing (ouch), but should keep paint needed to cover to a minimum.
I also printed out a wing planform from Comp-U-Foil and used a sewing pin to poke a hole where my forward CG will be located.
Fred
Old Nov 27, 2012, 12:53 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
I tried to save some weight with the receiver. 2.1g to start, and I removed the white insulation from the antenna, and the orange heat shrink, plus the ID sticker. Replaced with thin clear heatshrink, liquid electrical tape on antenna, and Sharpie plus paint dots to replace ID tag. Saved 0.2g, but I'll take what I can get.
The orange RX 4 channel micro weighs about the same as an AR6300 6 channel from Spectrum. Differance is the AR6300 is $40.00 more, ouch. I have one but I only need 3 channels on this bird so why waste the better RX.
Fred
Old Nov 27, 2012, 01:11 PM
hanzie is offline
Find More Posts by hanzie
Fear me, I'm a space-duck.
hanzie's Avatar
Joined Nov 2011
Maybe you could lose some more weight by removing the connectors and soldering the servos directly to the board. Might save you another few 0.1 grams.
hanzie is offline Find More Posts by hanzie
Old Nov 27, 2012, 01:25 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Thanks and that is a great idea actually. This time I must take that extra weight penalty because I don't order from HK anymore so if I mess it up I am , LOL. What I should do is order one of those .xx miligram RX's from Bob Selman, but that will be when I have some extra money! If I had a $100.00 bill, I'd really lighten this thing up, but I hope a 22mm can push it along, that was my plan to use stuff everyone can afford and find easy.
Fred
Discussion 1/48th scale tug boat fittings...where are they? Predreadnut Scale Boats 10 Oct 17, 2012 02:12 PM
Discussion Huge pink foam Mirage 2000 90mm edf kingkyle Foamies (Scratchbuilt) 2 Aug 27, 2012 03:59 PM
Build Log mirage 2000 C (2000-5) wora Scratchbuilt EDFs 10 Jul 28, 2011 09:12 AM
Discussion big "GRAUPNER" Mirage 2000 955mm wingspan Pippin Foamy EDFs 30 Oct 29, 2007 12:08 PM
