Old Jan 20, 2013, 06:39 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
It works but just think how much better it wouuld work if the ducting was better!!!!
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Jan 21, 2013, 12:24 PM
Liebrein is offline
Find More Posts by Liebrein
Weidenbach, Bavaria
Joined May 2007
Hi,
made a testrun today installed thrust was about 7 kg, plane sitting on the ground with a scale at the back and a nyloncord over the mainstruts.
For example, F 15 installed thrust is about 5,8 kg
So i think that ducting is not bad at all, 10- 15% thrustloss from Teststand results to installed results is the norm.
BR
Reinhard
Liebrein is offline Find More Posts by Liebrein
Old Feb 04, 2013, 12:26 PM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
50mm and 55mm fans would be great! Do you guys make them in that size?
gooniac33 is offline Find More Posts by gooniac33
Old Mar 14, 2013, 04:13 AM
LASER TECH is offline
Find More Posts by LASER TECH
Joined Feb 2013
if it is possible send a drawing mount size for the micro fan- 50mm and 55mm ?
LASER TECH is offline Find More Posts by LASER TECH
Old Mar 14, 2013, 01:22 PM
Liebrein is offline
Weidenbach, Bavaria
Joined May 2007
Hi again,
here is the Video from the Skyemaster F18 with the Taiwan Tornado 120/ 880 kv Motor on 12S 6200 mAh Chinahobbyline 30 C cells. Attached is the flight log from the first flight.
Skyemaster F18 Taiwan Tornado 880 kv 05.03.2013 (5 min 35 sec)
BR
Reinhard
Old Mar 14, 2013, 02:41 PM
Jacques.Eloff is online now
Find More Posts by Jacques.Eloff
Jacques.Eloff's Avatar
United Kingdom, England, Cobham
Joined Oct 2007
I think that is THE best EDF sound I have ever heard! Performance looks good too, topped off with some good pilot skills. I'm in the market for my first 120mm edf and seriously considering one of these.
Jacques
Jacques.Eloff is online now Find More Posts by Jacques.Eloff
Old Mar 14, 2013, 03:22 PM
Pepperpete is online now
Find More Posts by Pepperpete
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
I am terrible at reading those graphs. Is it saying that your max amps was 165? And that was on 12s? How much time do you have on your TX timer?
Pepperpete is online now Find More Posts by Pepperpete
Old Mar 14, 2013, 03:46 PM
Liebrein is offline
Weidenbach, Bavaria
Joined May 2007
@Jacques.Eloff,
thank you
@Pepperpete, the peak amp was 173 A and near 8 KW
well, i know a bit much amp but makes fun to fly
Timer is Set to 4:00, flight time is over 5 min
BR
Reinhard
Old Mar 14, 2013, 03:56 PM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
Originally Posted by Liebrein View Post
@Jacques.Eloff,
thank you
BR
Reinhard
I just looked up those chinahobbyline batteries. I can't believe how low cost they are!!! I'm going to pick a few up seeing as you seem to like them. Having said that...they arn't going to last long running that kind of power through them. It seems a bit extreme but the performance looks stunning.
Old Mar 14, 2013, 04:33 PM
Liebrein is offline
Weidenbach, Bavaria
Joined May 2007
@Pepperpete,
for now, i canīt say much from them, only a few cycles on it, but in the testruns and first flight they looked good, second flight was with 5300 GA, 10 A less and watts also dropped and low voltage peeps from the ESC, remember, the temp where at about 9° celsius. I hope the cyclelife is also good but we will see, time will tell.
Soon i try another Motor in the Taiwan Tornado, if tests done, i will share
Any response frm Vasa?
BR
Reinhard
Old Mar 14, 2013, 04:44 PM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
@Pepperpete,
BR
Reinhard
That doesn't surprise me. That kind of Amp through 5300mah packs would be just too much. And the flight time would be dust. I want to go fast but I need decent time in the air as well. The Vasa I'm going to be running pulls about 116 at WOT. But obviously not at that crazy thrust range.
Yup got in contact with Vasa! Vasa 120 14 blade with a HET 700-98-780 installed is on the way. I know I won't have your thrust but I will have much less weight installed as my ESC is over 145 grams lighter. Combined with the lighter 12s 5300 batteries and thats a fair bit. Hopefully the results will be at least close to what I see your plane doing now.
Having said that...this Tornado fan sounds like a million bucks in the air. I am VERY impressed.
Old Mar 14, 2013, 06:14 PM
Liebrein is offline
Weidenbach, Bavaria
Joined May 2007
Hey Pepperpete,
i have this Vasafan Setup in my F15 and i know the result. Also my friends red F15 uses the same
BR
Reinhard
Old Mar 14, 2013, 06:16 PM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
Hey Pepperpete,
BR
Reinhard
Is it satisfactory or kinda meh? If you could only choose one which would you go with?
Old Mar 14, 2013, 08:00 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
That's puttin an a## whoopin on batteries...
What were the temperature of the batteries when they came down?
Tia
erh7771 is online now Find More Posts by erh7771
Old Mar 15, 2013, 01:53 AM
Liebrein is offline
Weidenbach, Bavaria
Joined May 2007
@Pepperpete,
hmmm, hard to say, but now that i know how smooth and well balanced the Taiwan Tornado is, is this a way to go. The difference from booth is the complete weight, but itīs not the Fan itself, itīs the big Motor that used.
@erh7771,
as i remember they where 45- 50° celsius.
BR
Reinhard
Discussion TAIWAN TORNADO (7012) 70EDF Blades YUSENWANG Electric Ducted Fan Jet Talk 74 Sep 19, 2013 10:45 PM
Discussion TAIWAN TORNADO EDF Development of new aircraft Tom yu Electric Ducted Fan Jet Talk 4 Oct 16, 2012 02:34 AM
Sold Change SUN 12 blade 120mm EDF fan NIB sherlockshah Aircraft - Electric - Jets (FS/W) 2 Apr 09, 2012 04:25 AM
Wanted lander 120mm edf the big g Aircraft - Electric - Jets (FS/W) 0 Mar 30, 2012 04:37 PM
Discussion good deal on 120mm edf! JetMang Electric Ducted Fan Jet Talk 1 Mar 05, 2012 01:25 PM
