Old Dec 16, 2012, 11:44 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
there are perhaps some other fan vendors that don't like competition...
Self promotion doesn't seem to get others blocked.
4stripes is offline Find More Posts by 4stripes
Old Jan 10, 2013, 02:41 PM
Liebrein is offline
Find More Posts by Liebrein
Weidenbach, Bavaria
Joined May 2007
Taiwan Tornado 120/12/ 950kv
Hi,
here is a video from the first testrun with 12S 6200 mAh Chinahobbyline lipos.
Attached are the live log and the min/max datas
The 950kv motor is a Monster, itīs rated up to 12000 watts and of course on the heavy side. The Fan with motor is 1150 gr. without and 1350 gr. with thrusttube.
The Fan runs absolutly smooth with no vibrations at all and had a nice sound.
Testlauf Taiwan Tornado Amaxrc 120mm Fan (2 min 22 sec)
Liebrein is offline Find More Posts by Liebrein
Old Jan 16, 2013, 04:33 AM
Benovitch is offline
Find More Posts by Benovitch
BelgiŽ, Vlaams Gewest, Temse
Joined Dec 2004
What is the max size of motor that can be mounted in the fan?
Ben
Benovitch is offline Find More Posts by Benovitch
Old Jan 16, 2013, 07:19 AM
Liebrein is offline
Weidenbach, Bavaria
Joined May 2007
Hi,
here are some other Testruns with different Motors and cellcount.
@Ben, this Motors are at about 58mm dia. and i think this is the max.
Testlauf Taiwan Tornado Amaxrc 880kv 12 S (1 min 33 sec)
Testlauf Taiwan Tornado Amaxrc 800 kv 14 S (2 min 12 sec)
Old Jan 16, 2013, 07:57 AM
Joined Dec 2004
I’m looking to put one in a Fly eagle F-15, first I want to go with a twin Vasa 110 setup with open duct. But this will save some weight.
Ben
Old Jan 16, 2013, 04:18 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
What batteries were being used on 14s? It looks like 180 amps at WOT?
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jan 17, 2013, 05:44 AM
Liebrein is offline
Weidenbach, Bavaria
Joined May 2007
Hi Extreme_RC,
like decribed in the Video Chinahobbyline 6200 mAh 30 C
no, peak was about 155 amps.
BR
Reinhard
Old Jan 17, 2013, 01:08 PM
Joined Dec 2004
I saw on the Tornado site the dimensions from the shroud, they say the motor mount has a diameter of 56mm, shroud, and the TP Power motors are 58mm in diameter. Anyone to explain this.
Motor: http://www.tppower.com/sort.asp?class_id=4&news=21
Shroud: http://shop.tw-tornado.com/goods.php?id=15
Old Jan 17, 2013, 03:56 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Originally Posted by Liebrein View Post
Hi Extreme_RC,
BR
Reinhard
The graph is confusing me then, as red appears to be amps, which is showing 180 range, with volts dropping down close to 40 under full load?
Old Jan 17, 2013, 04:45 PM
Air-Jon is offline
Find More Posts by Air-Jon
world's slowest builder
Air-Jon's Avatar
CA
Joined Oct 2006
I read the graph the same...big amps and big voltage sag...motor is too high a KV for that fan.
Air-Jon is offline Find More Posts by Air-Jon
Old Jan 17, 2013, 04:49 PM
Air-Jon is offline
Air-Jon's Avatar
CA
Joined Oct 2006
...also...there are 2 different runs...a 12s at 180A peak and a 14s run at 150ish Amps peak.
Old Jan 17, 2013, 04:51 PM
Air-Jon is offline
Air-Jon's Avatar
CA
Joined Oct 2006
ok 3 runs...and i see the 880 kv motor on 12s is 155 amps. that is better
Old Jan 17, 2013, 04:52 PM
Air-Jon is offline
Air-Jon's Avatar
CA
Joined Oct 2006
the 950kv on 12s is a battery killer!
Old Jan 17, 2013, 05:43 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
not really
You just need bigger batteries!
turbonut is online now Find More Posts by turbonut
Old Jan 17, 2013, 06:04 PM
Air-Jon is offline
Air-Jon's Avatar
CA
Joined Oct 2006
Yeah...i guess if you like heavy planes. those are 6200s already and dropping the batts below 3.3v/cell. 180x40=7200 watts for 19 lbs thrust That is 378W/lb of thrust...and the recorded amps from the ESC could be lower than reality...might be more like 190 or 200 amps with a clamp on meter. I like the 145 amp average of the 880kv and 3.4v minimum voltage. 41.5v x 145A = 6017 watts for 17.6 lbs thrust is 340 watts/lb thrust...much better in my opinion. OF course efflux will be higher on the 950kv for the speed freaks.
Discussion TAIWAN TORNADO (7012) 70EDF Blades YUSENWANG Electric Ducted Fan Jet Talk 74 Sep 19, 2013 09:45 PM
Discussion TAIWAN TORNADO EDF Development of new aircraft Tom yu Electric Ducted Fan Jet Talk 4 Oct 16, 2012 01:34 AM
Sold Change SUN 12 blade 120mm EDF fan NIB sherlockshah Aircraft - Electric - Jets (FS/W) 2 Apr 09, 2012 03:25 AM
Wanted lander 120mm edf the big g Aircraft - Electric - Jets (FS/W) 0 Mar 30, 2012 03:37 PM
Discussion good deal on 120mm edf! JetMang Electric Ducted Fan Jet Talk 1 Mar 05, 2012 12:25 PM
