Old Nov 22, 2012, 07:13 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
So even worse....
bri6672 is offline Find More Posts by bri6672
Old Nov 22, 2012, 07:14 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by bri6672 View Post
Absolutely! 12s 135amps 19lbs of thrust 225mph with 3 3/8 diameter thrust tube...
With what motor?
Regards
erh7771 is offline Find More Posts by erh7771
Old Nov 22, 2012, 07:16 PM
erh7771 is offline
Joined Nov 2005
Originally Posted by PikeStaff View Post
19 lbs on 12S?
I've not seen one doing such under 160 amps
Old Nov 22, 2012, 07:25 PM
PikeStaff is online now
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
120mm's, to be honest and candid, are out of my league. Originally thought that the concern was the ability of batts to keep up with 170a. draws - which really isn't difficult to conceive, as I saw it. Plus, airframe size for a 120 seem to provide lots of room for big - i.e., 5000++ mAh size - batts, hence why it wasn't a biggie.
Cost would have to figure into this equation, too. Big Schubelers are a long way from economical. But I suppose you get what you pay for too.
PikeStaff is online now Find More Posts by PikeStaff
Old Nov 22, 2012, 07:29 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Thats cause your busy playing with the cheap stuff...
Het 800 680 dynamax, you saw it in the Falcon thread.
Old Nov 22, 2012, 07:32 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
You will need about 10'000 mah to get any real flight time at 170 amps unless you had it in something like an electra.
Old Nov 22, 2012, 07:48 PM
erh7771 is offline
Joined Nov 2005
lol, I've been getting > 2oz of thrust per amp on the "cheap" stuff for a long long time..... or whatever uninformed claim that you made up thread on thrust to amps output.
BTW: It's thrust to watts ....cause amps can come in many flavors due to cell count...
Back on to the thread...
Jack, you should get a known thrust to watt fan and baseline your sled... 180 amps is up there in the amps pull
regards
Old Nov 22, 2012, 07:59 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Uninformed... Whatever...... amps are a direct result of flight time I don't care what volts you use... I stated on 12s with a 120 fan you should be getting 2oz per amp to keep up with other high powered "12s" setups!!!
If this guy Jack wants to sell fans he needs to get his amps down!!!
Old Nov 22, 2012, 08:10 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
180amps+ is a bit high and this was without a reduced thrust tube, which can cause another 10% increase in current draw. All is not lost, just go to a lower kV motor to run on 12s . The setup that is shown is probably a 10S setup at best and that would be 140+ amps.
Kevin Cox is offline Find More Posts by Kevin Cox
Last edited by Kevin Cox; Nov 22, 2012 at 08:41 PM. Reason: replaced lots with lost
Old Nov 22, 2012, 08:25 PM
Air-Jon is offline
Find More Posts by Air-Jon
world's slowest builder
Air-Jon's Avatar
CA
Joined Oct 2006
Yeah... at least the motor only weighs 1.8 lbs. My het motor and dynamax fan only weighs about 2 more ounces than just their motor! And makes the same thrust at only 6000 watts instead of 7900 watts this thing is pulling!!!!!
Air-Jon is offline Find More Posts by Air-Jon
Old Nov 22, 2012, 08:37 PM
erh7771 is offline
Joined Nov 2005
Yeap...id start with checking the sled..
Old Nov 22, 2012, 10:02 PM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
regards
You do know how to calculate watts right?
SteveC68 is offline Find More Posts by SteveC68
Old Nov 23, 2012, 09:32 AM
Gorilla Glue Expert
PikeStaff's Avatar
Joined Sep 2010
8600g thrust, divided by 6000 watts = 1.43 g/w. That's a really good output; what is the setup, motor/fan?
Old Nov 23, 2012, 10:38 AM
Pepperpete is offline
Find More Posts by Pepperpete
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
I'm curious as well.
Pepperpete is offline Find More Posts by Pepperpete
Old Nov 23, 2012, 11:04 AM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
My 1915 1y nue motor does 16 lbs thrust at 115 amps , 5100 watts in the dynamax fan on 12s 35c 6500mah packs.... installed in the plane with a 3 1/2 inch tail pipe amps went up to 132 amps 6200 watts and over 15 lbs installed thrust. My installed thrust number is from a fish scale with a string around the tail... so it's just a rough number. If you factor in wheel resistance with a 22 pound plane I'm sure it's higher
plane flies like a bat out of hell...it's a 1/6 scale jet legend hawk. very hard to beat a dynamax...it was designed by General Electric
Ron-E-Max (6 min 35 sec)
Ron101 is offline Find More Posts by Ron101
Discussion TAIWAN TORNADO (7012) 70EDF Blades YUSENWANG Electric Ducted Fan Jet Talk 74 Sep 19, 2013 09:45 PM
Discussion TAIWAN TORNADO EDF Development of new aircraft Tom yu Electric Ducted Fan Jet Talk 4 Oct 16, 2012 01:34 AM
Sold Change SUN 12 blade 120mm EDF fan NIB sherlockshah Aircraft - Electric - Jets (FS/W) 2 Apr 09, 2012 03:25 AM
Wanted lander 120mm edf the big g Aircraft - Electric - Jets (FS/W) 0 Mar 30, 2012 03:37 PM
Discussion good deal on 120mm edf! JetMang Electric Ducted Fan Jet Talk 1 Mar 05, 2012 12:25 PM
