Old Nov 22, 2012, 06:03 PM
Tornado Jack is offline
Find More Posts by Tornado Jack
Joined Nov 2012
Taiwan Tornado 120mm EDF /8600g Thrust
Hi Guys,
Happy Turkey day!
Our new All METAL 120 mm High Performance EDF unit features a 950 KV motor,Please have a look it as showcase belows:
Power: 12S
MAX RPM:72,000r/min
Thrust: 18.96 lb / 8.6kg
Shaft adaptor:1*8mm
Impeller: 12 blades
Motor:950KV
The screws' ear and shroud are completely CNC-machined from high-grade alloy, immensely strong and light,easy install and easy uninstall
The fan has built-in safety, with safety guard mechanism to prevent from blade flying out.
Our CNC EDFs and blades have turbine effect and dynamic balance effect. You could assemble our EDF system with any other motors without losing dynamic balance effect.
950KV motor
Thrust data from accuracy EDF/JET testing platform
120mmEDF 8600G (0 min 35 sec)
Gryphon con ventola Taiwan Tornado 120mm - Jonathan Italy
Gryphon con ventola Taiwan Tornado 120mm - Jonathan (1 min 3 sec)
Tornado Jack is offline Find More Posts by Tornado Jack
Old Nov 22, 2012, 06:10 PM
PikeStaff is online now
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Awesome...
Beautiful craftsmanship, screaming power... When? / where? / how much? Looking forward to this!
PikeStaff is online now Find More Posts by PikeStaff
Old Nov 22, 2012, 06:20 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
How much for the rotor parts without the shroud?
Regards
erh7771 is offline Find More Posts by erh7771
Old Nov 22, 2012, 06:27 PM
Joined Nov 2012
Regards
Thanks, Please email me for the price, jack@tw-tornado.com
Old Nov 22, 2012, 07:02 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Did i just see 170 plus amps???
bri6672 is offline Find More Posts by bri6672
Old Nov 22, 2012, 07:12 PM
Gorilla Glue Expert
PikeStaff's Avatar
Joined Sep 2010
2 pairs, paralleled, then series'ed, gets about 43 amps / pack for 170 total. For a 120mm sized fan, not a biggie at all.
Old Nov 22, 2012, 07:17 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
It is a big deal, Dynamax produces 19lbs of thrust at only 135 amps. That thing better have 300mph efflux..... how many mah do you think you would need to carry to have any flight time....
Old Nov 22, 2012, 07:19 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
If your not getting 2oz of thrust or better per amp, you need to go back to the drawing board.
Old Nov 22, 2012, 07:32 PM
Gorilla Glue Expert
PikeStaff's Avatar
Joined Sep 2010
Dynamax..
19 lbs on 12S?
Old Nov 22, 2012, 07:37 PM
Gorilla Glue Expert
PikeStaff's Avatar
Joined Sep 2010
So a 70mm with, say, an MB-1 pulling 54 or 55 amps on 4S better be making 108oz. of thrust, minimum? 6 -3/4 lbs, or 3+kg? Wish mine would do that. Let's see.... 3062 grams divided by about 900 watts = 3.4 grams / watt.
Yeah, that would be an awesome setup.
Old Nov 22, 2012, 07:38 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Originally Posted by PikeStaff View Post
19 lbs on 12S?
Absolutely! 12s 135amps 19lbs of thrust 225mph with 3 3/8 diameter thrust tube.
The DS-94 hst does 22lbs at 155 amps on 12s.
Old Nov 22, 2012, 07:39 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Im talking 120mm fans..
Old Nov 22, 2012, 07:41 PM
Gorilla Glue Expert
PikeStaff's Avatar
Joined Sep 2010
Ok
It would appear maybe there's more to be looked at in here.
Old Nov 22, 2012, 07:44 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Yeah this thing needs to go back to Taiwan for an overhaul, ridiculously inefficient.
Old Nov 22, 2012, 08:12 PM
erh7771 is offline
Joined Nov 2005
I saw 180 amps peak,
Hey Jack, have you base lined your sled?
regards
Discussion TAIWAN TORNADO (7012) 70EDF Blades YUSENWANG Electric Ducted Fan Jet Talk 74 Sep 19, 2013 10:45 PM
Discussion TAIWAN TORNADO EDF Development of new aircraft Tom yu Electric Ducted Fan Jet Talk 4 Oct 16, 2012 02:34 AM
Sold Change SUN 12 blade 120mm EDF fan NIB sherlockshah Aircraft - Electric - Jets (FS/W) 2 Apr 09, 2012 04:25 AM
Wanted lander 120mm edf the big g Aircraft - Electric - Jets (FS/W) 0 Mar 30, 2012 04:37 PM
Discussion good deal on 120mm edf! JetMang Electric Ducted Fan Jet Talk 1 Mar 05, 2012 01:25 PM
