Old Nov 25, 2012, 04:40 PM
carrerars is offline
Find More Posts by carrerars
carrerars's Avatar
Joined Aug 2008
Wow Andre,
that is a real neat plane !!!
My 319 is a bit larger, but yours is comming out much more nicer...
Cant wait to see it finished and maidened.
Good luck with ths projects!
Markus
carrerars is offline Find More Posts by carrerars
Old Nov 25, 2012, 05:28 PM
Andre Kochanski is offline
Find More Posts by Andre Kochanski
The Depronizer
Andre Kochanski's Avatar
Germany, NRW, Dortmund
Joined Aug 2012
Thanks Markus,
how big is your A319? Do you have a build thread here or do you have pictures? How does yours fly?
And we are feeling the same...I canŽt wait either...the glassing will be a huge mess but i think itŽll be worth it!
I have another big build parallel to the A319 - a Robbe BAe 146 which i rebuild and modify...maybe iŽll write something about it next year who knows.
To everyone else:
I just redesigned the layout of my plan. Now its better and no parts are missing So feel free to download, share, build and enjoy
@ Eddy: youŽre very welcome
Andre Kochanski is offline Find More Posts by Andre Kochanski
Old Nov 25, 2012, 05:35 PM
Doushiyou12 is offline
Find More Posts by Doushiyou12
Winter Is Coming
Doushiyou12's Avatar
Joined Feb 2010
Wow, awesome plans. Thanks a lot
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Nov 25, 2012, 06:10 PM
Flexserve is offline
Find More Posts by Flexserve
Avoid The Ground!
Flexserve's Avatar
United States, FL, Tampa
Joined Sep 2008
Originally Posted by Andre Kochanski View Post
Thanks Markus,
To everyone else:
Community WIN! Thanks!
Flexserve is offline Find More Posts by Flexserve
Old Nov 25, 2012, 06:17 PM
The Depronizer
Joined Aug 2012
You are very welcome! I have read oooohhh so many great build threads and if i can give a tiny bit back it feels great
Old Nov 25, 2012, 06:20 PM
Avoid The Ground!
Flexserve's Avatar
Joined Sep 2008
Any template for the Balsa wood spars in the wings? (I'm just lazy)
Old Nov 26, 2012, 01:52 AM
The Depronizer
Joined Aug 2012
Right now iŽd like to leave the decision to the builder. Some may be adding flaps and other things, so that the wing layout may change.
The supporting spars for the landing gear may also change position.
Maybe in the near future i will rework the wing in CAD and make proper plans but for now - if you plan my initial version add the spar at the ribs max. thickness. When building the wing with a flat underside, the height will be determined by the ribs and its very easy to cut and sand it after glueing.
Old Nov 26, 2012, 02:32 AM
carrerars's Avatar
Joined Aug 2008
Hi Andre,
here you are:
http://www.rcgroups.com/forums/showthread.php?t=1683403
Flies nice, handles easy and is almost as slow as the real one
I like your approaches: A319, Dash-8, and now a Jumbolino (where the hell did you get that kit???)
Ans also a big thank you for providing your excellent plans.
It seems to me that all of us are getting better and better in here -
... so watch out Neffwaffe
Markus
Old Nov 26, 2012, 03:34 AM
The Depronizer
Joined Aug 2012
markus,
i know your plane as i was browsing for RC A319 vids on yt i watched the superb landing. Really nice job and great model!!!
You can be proud!
I just hope mine flies that great!
The Jumbolino i got was not a kit any more. It was already built and i had to separate the parts and change them. The model was a bit expensive but i think that for this kind of model the price is somewhat OK.
About my approaches: I also have an 1:16 ATR72-500 i didnt mention. Build log follows soon as the model is close to maiden
Old Nov 26, 2012, 01:56 PM
The Depronizer
Joined Aug 2012
Today was not cybermonday (i managed to resist HK ), but "Nacelle Day"
Not much to see right now. Just like the first one i sanded the second, then glued the engine mount (4mm poplar ply) in a slot i cut. After that i soldered and isolated the extension cables (2,5mmČ). To hide them and to get a scale shape of the engine mounts i will add 6mm depron to both sides after attaching them to the wing. I am planning to do so during next weekend.
Stay tuned
Old Nov 26, 2012, 03:08 PM
Avoid The Ground!
Flexserve's Avatar
Joined Sep 2008
Looks good can't wait to see the glassing technique you use. This will be my first time glassing in prep for the B-1B. I will use this model as a experience builder since you have laid it out so nicely!
Old Nov 26, 2012, 03:48 PM
Winter Is Coming
Joined Feb 2010
Self made lightweight spackle
Those nacelles are killer!!! Nice job
Old Nov 26, 2012, 04:41 PM
The Depronizer
Joined Aug 2012
flexserve,
i can tell you this directly: I use lightweight spackle to even everything out and get a closed, flat surface. After sanding i wipe away the dust with damp cloth. Then i mix the resin (L285+H285) and get it on the part with a brush. After that i apply the glassfiber and let it soak. If i used too much resin i take a paper towel, let it soak too and take the excess resin away.
After the resin has cured i sand, fill, sand, clean and paint. But youŽll get the whole thing again in pictures soon
By the way your B-1 will be ravishing i am convinced!
Doushiyou,
thanks! They made some work after all even if it looks that simple... I canŽt wait to see them glassed and finished in glossy
Old Nov 26, 2012, 04:44 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Your A319 Nacels Look GREAT Andre!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Joe Nall 2016
Old Nov 28, 2012, 01:14 PM
w747 is offline
Find More Posts by w747
747-400
alaska
Joined Mar 2007
Very nice work!
w747 is offline Find More Posts by w747
Build Log Bird of Time scratch build from plans ourbluehorizon Electric Sailplanes 19 Nov 30, 2013 12:36 PM
Build Log Airbus A319 | 1:20 Scale | EDF | Dollar Tree Foam preelude RC Airliners (Commercial, Cargo, Troop Carrier) 23 Dec 22, 2012 02:36 PM
Sold $100 for my 56" A10 Warthog. Scratch built from plans! LPU SW LOWER MICHIGAN! flyinjrc74 Aircraft - Electric - Airplanes (FS/W) 7 Nov 10, 2012 05:27 PM
Video Bird of Time, electric, scratch build from plans ourbluehorizon Sailplane Talk 2 Nov 02, 2012 02:50 PM
German foam Airbus A319 - any experience or info available? Ben_E Electric Ducted Fan Jet Talk 5 Feb 21, 2003 05:07 PM
