Airbus A319-100 1:25th from own plans - half scratched ;)
Hello everyone,
a month ago i posted some pics of my A319 in Sergioīs fantastic build log. http://www.rcgroups.com/forums/showthread.php?t=1420129 He does a wonderful job and i got a lot of inspiration from that. So merci beaucoup mon ami ![]() Our two builds are almost the same scale. His is in 1:22, mine is 1:25. This leads to the following technical specifications: wingspan: 1394 mm length: 1326 mm wing area: 25,46 dmē horizontal stabilizer area: 5,05 dmē I always design the planes in this size for a previously determined wing loading of 50g/dmē. With this the model can be operated safely and i feel comfortable flying it in normal flying weather with light to medium winds. By multiplying the wing loading with the wing area (note: the elevator doesnīt count as its producing drag, not lift!) i get the design maximum takeoff weight. MTOW= desired wing loading* wing area = 50g/dmē*25,46dmē = 1273g Alright. Then time is right to chose the components for the model: servos: 9g HXT900-ish, 5g HXT500-ish for each aileron receiver: Corona RP6S1 6CH (as i am still flying 35MHz) Now the interesting parts: EDF: 2x 55mm AEO fan with ADH300 motor ESC: 2x Mystery 30A blue series Battery: 3S 2200mAh 25C Every fan runs smoothly at about 25A (measurement=done) and the battery will juuuuust be able to handle the full current for takeoff and short passages. But this is an airliner so it should do the trick. The fans are said to produce around 500g each, so this should be sufficient as well. For paved-runway-operations i am adding the micro pneumatic retract system HK is selling (i was kinda curious when buying )Adding up all the weight of the components (900g) this leaves 500g just for the bare airframe. A manageable thing to do iīd say! For the finish i am planning to glass the whole plane with 25 to 49g/mē glass. If the weight is already too high i will stick to paper and WBPU. Now all the CAD work has to be done. I did just the fuse in detail because i originally planned to hot-wire cut the wings. Then afterwards i changed my mind and did the wing partly from scratch - thats why the title
Joined Oct 2012
Viele Grüße aus EDDT
I'm with LH Great work Andre!. . .. Sub me up!
Latest blog entry: Joe Nall 2013!
Looking Superb Andre. .. . Your work looks outstanding! Bravisimo!
WOW! Very cool!
![]() There is No photo Limit here on RCG Andre. . .only the size of the photo. |
| Thread Tools | |
| Build Log Bird of Time scratch build from plans | ourbluehorizon | Electric Sailplanes | 16 | Mar 02, 2013 01:41 AM |
| Build Log Airbus A319 | 1:20 Scale | EDF | Dollar Tree Foam | preelude | RC Airliners (Commercial, Cargo, Troop Carrier) | 23 | Dec 22, 2012 02:36 PM |
| Sold $100 for my 56" A10 Warthog. Scratch built from plans! LPU SW LOWER MICHIGAN! | flyinjrc74 | Aircraft - Electric - Airplanes (FS/W) | 7 | Nov 10, 2012 05:27 PM |
| Video Bird of Time, electric, scratch build from plans | ourbluehorizon | Sailplane Talk | 2 | Nov 02, 2012 02:50 PM |
| German foam Airbus A319 - any experience or info available? | Ben_E | Electric Ducted Fan Jet Talk | 5 | Feb 21, 2003 05:07 PM |
