Old Nov 22, 2012, 08:40 AM
Hkubota is offline
Find More Posts by Hkubota
Hkubota's Avatar
Japan, Tokyo
Joined Mar 2012
Flying field size for 450 size heli?
I usually fly quad and it's great fun and cheap to fix. I am curious about CP heli's though as flying inverted looks like fun to do. I do that a lot on the RealFlight sim I own. Mostly because the only quad in that sim is...well...either very different to what I fly in reality, or just badly programmed. The heli on the other hand are a lot of fun.
Living in a city takes its toll though, so I wonder what amount of space is needed to fly a 450 size heli.
I know in theory 3m x 3m is sufficient, but not fun. My small quad (330mm) is happy with half a soccer field. Better with a full soccer field. Trees and fence around it, so it's just soccer field size plus maybe 3m extra to all sides.
Is that a lot for a 450 size heli? Just ok (and thus 500/600 size needs more space)? Not enough at all?
My plan is to do not speed flying. My quad can do that. But 3D. Since I am a beginner in that area, light 3D first :-)
Harald
Hkubota is offline Find More Posts by Hkubota
Old Nov 23, 2012, 07:20 PM
finguz is offline
Find More Posts by finguz
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
Well the whole point is to learn to control the heli so you could fly in any given space. But there is safety to consider for yourself (or potentially anyone else around you), if you or anyone gets hit by it they're going to get hurt bad. A soccer field should be more than enough room providing nobody's around, take it slow, and don't try tricks too far from your comfortable control level. You might also consider a micro cp heli... they can still be pretty fast and need some room, but they are also at lot more sensitive (harder to fly) than a 450 or bigger size. 450 isn't a bad size though and as soccer field should be good... again, take it slow.
finguz is offline Find More Posts by finguz
Old Feb 09, 2013, 12:52 AM
Hkubota is offline
Hkubota's Avatar
Japan, Tokyo
Joined Mar 2012
According to RealFlight...
For those who have the same question as I had: a soccer field size is fine for a 450 heli. 500 is ok, but barely. 600 or 700: they need more space.
For me that means, if I get a larger heli, I first need to have a better playground.
Old Feb 11, 2013, 12:32 PM
rhodesengr is offline
Find More Posts by rhodesengr
This is your brain on heli's
rhodesengr's Avatar
United States, CA, Livermore
Joined Jan 2012
an EMPTY soccer filed is fine for a 450. But there are some choices to consider. If you have access to a larger indoor space like a school gym, consider the Blade Nano. It will do reasonable 3D, certainly flips and rolls.
For outside consider the new mCPx BL. It has a much stronger tail than the mCPx V2 and is much more park friendly than 450. Easy and cheap to fix. Often can crash on grass with no damage. Will no 3D and fly in some wind. You don't need a big helicopter to start doing 3D.
rhodesengr is offline Find More Posts by rhodesengr
Old Feb 11, 2013, 11:03 PM
Jersey Crewmax is offline
Find More Posts by Jersey Crewmax
RC Basher
United States, NJ, Union
Joined Sep 2012
Good info. How do people typically go about finding out if you can fly a heli in a park or similar surroundings?
Jersey Crewmax is offline Find More Posts by Jersey Crewmax
Old Feb 11, 2013, 11:17 PM
rhodesengr's Avatar
Joined Jan 2012
You can look in you city code and you can look around your parks for signs with posted rules. Our parks all have small metal signs with posted prohibited activities which includes any sort of RC device. But there appears to be some tolerance so I have not been kicked out yet. Most people are interested which can also be a bad thing if a little kid runs up. You have to use common sense with something like a 450 because they are very dangerous. If it is prohibited in your parks, you may get away with flying but you'd be totally liable if you hit somone or damaged property. I only go when the fields are destered.
You can also join a club with a legit flying field. You can search for clubs in your area here
http://www.modelaircraft.org/clubsearch.aspx
Old Feb 12, 2013, 07:46 AM
Hkubota is offline
Hkubota's Avatar
Japan, Tokyo
Joined Mar 2012
Blades are hard to get here. I'm not in US
And no indoor space available either. Beside at the company I work at maybe, but no way I'll fly something as destructive as a 450 heli there. The Genius CP I have is ok, but it's pushing it.
The main point why I wanted to find out whether I can even think about getting a 700 class heli, and the answer is a clear "No way"
500/550 is pushing it I'd say from my limited experience with the flight simulator.
Old Feb 12, 2013, 09:58 AM
rhodesengr's Avatar
Joined Jan 2012
Which simulator are you using. I suggest you don't use the simulator to compare models for buying. I have Phoenix and have found you just can't use it that way. Its nice they have so many models but the don't fly anything at all like the real thing and it varies model to model. The reall mCPx is much harder to piro than the sim would have you believe. In the sim you can piro all day with no cyclic input. Not so with the real deal. Its pretty hard to piro at all. On the other hand, my TREX 550 is easier in real life than the sim. I suppose i could spend hours tweaking the sim but it is much more sensitive than the real deal. The 550 is a great size and my TREX 550 has been extremely reliable. You do need an adequate space to fly though. A soccer field is ok but not with anyone around.
Old Feb 12, 2013, 10:38 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Maybe this is for you:
Curtis Youngblood 3D Quad Night Flight (1 min 46 sec)
Balr14 is offline Find More Posts by Balr14
Old Feb 12, 2013, 07:00 PM
Hkubota is offline
Hkubota's Avatar
Japan, Tokyo
Joined Mar 2012
I use RealFlight and I like it, but I do not expect models to be 1:1 identical to real life. I expect them to be similar to the real stuff, but not 100% identical.
The relative sizes on the other hand should be comparable, especially in a limited environment like a soccer field.
Discussion Flying Field Size for Micros and Park flyers? TedD60 Beginner Training Area (Aircraft-Electric) 8 May 21, 2012 04:41 PM
For Sale 450 size heli for sale - Dragonus kouger Aircraft - Electric - Helis (FS/W) 2 May 09, 2012 05:44 AM
For Sale 6s cell setup for 450 size heli align jenna Aircraft - Electric - Helis (FS/W) 2 Apr 22, 2012 09:26 PM
Discussion Batteries for 450 size heli danman_83 Electric Heli Talk 6 Mar 30, 2012 01:37 PM
Help! Suggestions for 450 size heli, for leisure flying and AP twinturbostang Aerial Photography 10 Jun 05, 2007 10:15 PM
