Old Nov 22, 2012, 08:07 AM
bigmd is offline
Find More Posts by bigmd
Joined Apr 2004
MK2 bottom cowl question
im rebuilding an MK1 Honda.It has all the body parts except the bottom cowl.Ithink I red tthat the new one will fit so I ordered it.Is this true and will it need modification?
bigmd is offline Find More Posts by bigmd
Old Nov 22, 2012, 10:17 AM
bigmd is offline
Joined Apr 2004
actually after a test fit it looks like the bottom cowl and front ferring from the HOR will fit.maybe i will just use them both.
Old Nov 23, 2012, 07:39 AM
Lukey B is offline
Find More Posts by Lukey B
Me Likee Motorbikee
Lukey B's Avatar
Melbourne Australia
Joined Nov 2009
Yeah the HOR front and lower fairings will fit the MK1 together as you said, but I don't think the lower cowl will fit the older top section... With the MK1 Yamaha the lower fairing actually locates on the frame aswell as the top fairing... Making for a real tight fit, much better than the HOR set up...
But the 4 mounting screw holes line up between all the different bikes and fairings... So you can mix and match a bit, just as long as lower cowl has something to locate on all should be fine...
While we're on the subject... Does anyone out there have any fairings for the MK1 bikes they'd be willing to part with..? Any condition... Any shape..?
Lukey B is offline Find More Posts by Lukey B
Old Nov 23, 2012, 10:28 AM
bigmd is offline
Joined Apr 2004
Lukey B you can have my front fairing.its in perfect shape no winshield.i did cut out one out of a plastic bottle though that came out good.
Old Nov 23, 2012, 02:55 PM
bigmd is offline
Joined Apr 2004
just give me address
Discussion Top Flite P-47 Cowl question Capt. Kelso Fuel Warbirds 1 Feb 23, 2012 09:28 PM
Question Beginners Questions on Honey Bee MK2 jocatch Micro Helis 14 Jun 22, 2006 01:25 PM
Question...lipolys and the bottom line. Munch Batteries and Chargers 4 May 31, 2005 03:06 PM
Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom) WarpdSpazm Modeling Science 10 Jan 29, 2005 09:39 PM
