Old Nov 22, 2012, 05:02 AM
morgans is online now
Find More Posts by morgans
Australia, NSW, Annandale
Joined Oct 2010
Question
takeoff torque roll
I experieced what I think was severe torque roll on the maiden flight of my pilatus porter.... see the short video.
Fortunately by quickly shutting off power and correcting the roll (and a bit of luck) only minor undercarriage damage occurred which is now fixed.
Out of curiosity to try and analyse the problem I sat the port wheel on a scale and revved the motor to about half throttle... it showed a momentary force of about 100 grams (1 newton) on the scale when I did this.
The force was acting about 145mm from the centreline of the model so the rolling force was about 0.145 newton /metres which in a model weighing 1.2 kg was about 1/10 of the models mass.
Since the rolling torque occurs due to change of throttle, if the plane was held still while the throttle increased and only released at a constant RPM for takeoff it should not induce torque roll. I know that there will be propwash hitting the tail but that will yaw it but not roll it.
Is this assumption correct?
Hobbyking Pilatus PC-6 Porter EP Balsa ARF (1300mm) maiden (0 min 13 sec)
morgans is online now Find More Posts by morgans
Old Nov 22, 2012, 06:38 AM
Brandano is offline
Find More Posts by Brandano
There will be torque reaction as long as the prop has to fight against drag to turn. Essentially, the motor has to push against something to get the prop to turn in the otehr direction, and that something is the fuselage. You can only trim for it at a set speed and rpm, though since the plane has dihedral it can also be partly compensated by adding side thrust to the motor.
Brandano is offline Find More Posts by Brandano
Old Nov 22, 2012, 09:15 AM
villapilote is offline
Find More Posts by villapilote
Wilson, NC
Joined Aug 2009
Hi morgans
If you wait a little longer before you pull up the take off will be better. It looks to me that your plane stalled at take off. Try giving it just a little up elevator when you believe you are at take off speed. Let the plane rise on its own rather than ripping it off the ground.
villapilote is offline Find More Posts by villapilote
Old Nov 22, 2012, 10:41 AM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
I'd go with the stalled wing theory as well. That and perhaps a trifle of a cross wind takeoff.
I like to hold a little up as the throttle is first applied so the drag of the wheels doesn't try to bury the nose on the grass field that I typicaly fly from. As the speed comes up I ease off the up elevator so it comes back to darn near neutral well before the model reaches takeoff speed. In your case it seriously looks like you simply held too much up so when it lifted off the tail stayed low and the model stalled the wing. The only roll the torque would have in such a case is to aid a little in deciding which way the model is going to then roll towards. But the primary issue is that the wing was stalled.
The other option, silly though it seems, is to ensure that the ailerons are going the right way. In this age of easily switched programmable transmitters it's all too easy to just wiggle the controls and not remember to double check that they are moving the correct way. Not saying you did this for sure but it's worth checking before EVERY flight
BMatthews is offline Find More Posts by BMatthews
Old Nov 22, 2012, 11:56 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
I vote on it being a roll from aileron deflection
also I saw no rudder correction at all.
On this kind of model - getting a straight line FIRST then setup trim for take off (slight up) is always best
I saw no sign of 'torque roll There is a fair bit of torque on any of these motors but the idea is to get plane going at flying speed before increasing AOA more than absolutely necessary
The torque and or precession then becomes of little importance .
Takes practice but really not that difficult to learn.
richard hanson is online now Find More Posts by richard hanson
Old Nov 22, 2012, 10:53 PM
Foambird is offline
Find More Posts by Foambird
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
I agree with these other posts. The airplane was pulled into the air going too slow and nowhere near straight. There appeared to be no rudder correction in the take-off roll and this correction is mandatory for a smooth take-off.
Having the rudder of ailerons reversed would also cause this. Torque roll is a factor but not at the level seen in the video.
Foambird is offline Find More Posts by Foambird
Old Nov 23, 2012, 04:49 AM
Joined Oct 2010
Thanks to all who replied.
I did check the ailerons, they were operating correctly.
I hadnt considered it was just a stall, as this is a heavier model than I am used to it is probable that I didnt allow a long enough takeoff run to build up sufficient airspeed prior to lifting off.
Next flight I will try the technique that BMathews described and see how that goes.
Old Nov 23, 2012, 01:09 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
I forgot to add in my post that the idea behind easing back to just a hair of up being held is that the model will then simply lift off when it has the proper flying speed.
I should also note that I've seen a lot of guys that horse the model off prematurely and get away with it. But that's due more to our ability to GROSSLY overpower our models compared to the more modest power to weight ratios found in full size aircraft. But while such flying style doesn't result in a crash, at least not EVERY time, those folks are getting away with it by good luck more than good flying skills. And typically the results from these premature leaps into the air seldom looks good either.
So now you know the "how" and "why". Hopefully the next video has a happier ending.
Old Jul 19, 2016, 04:15 AM
ageorge is offline
Find More Posts by ageorge
Joined Jul 2016
hey guys,I am new here and i had just tested my R.C plane a day ago.As soon as i tried to take off my plane flipped to the left on the ground and i destroyed my wing and the rudder as it snapped.The plane would not take off but would simply flip and roll.I was flying into the wind but i suspect my firewall was tilted.Is this the reason?Or is it because i may have had a larger polyhyderal on one side?The plane was a ft old speedster and i am very eager to improve myself ad get it in the air.I am a begginner and i know my question may sound dumb but please try help.Thanks guys.
ageorge is offline Find More Posts by ageorge
Old Jul 19, 2016, 05:08 AM
Pile It is offline
Find More Posts by Pile It
Joined Feb 2014
see same post in "Flying wing with split drag surface on tower for pitch control?" thread
Originally Posted by Pile It View Post
I have re-posted your question here http://www.rcgroups.com/forums/showthread.php?t=2704184
in this forum http://www.rcgroups.com/beginner-tra...ft-electric-8/
check there for a series of Q/A to help determine what happened and why and how to fix and avoid that in the future
Pile It is offline Find More Posts by Pile It
Old Jul 19, 2016, 01:32 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
It would need a lot more information on the plane, and preferably a photo(s) before the crash.
Otherwise it just becomes a guessing game for that particular plane.
eflightray is offline Find More Posts by eflightray
Discussion Torque-induced roll w/ HK Tuff Trainer doughpat Beginner Training Area (Aircraft-Electric) 18 Dec 10, 2013 08:17 AM
Discussion Controlling torque roll HiTekCub1 Yard Bird RC 7 Sep 08, 2012 08:02 PM
Question YB-22 Jet Torque Roll HiTekCub1 Pusher Prop Jet Models 19 May 23, 2012 10:14 AM
Discussion rc phoenix +torque Roll smiley007 Simulators 1 Mar 28, 2012 10:17 AM
Discussion torque roll - not torque roll , but a rookie mistake post 12 Blackrat FPV Talk 15 Jul 01, 2011 10:44 AM
