Old Nov 21, 2012, 09:08 PM
saltpepper is offline
Find More Posts by saltpepper
Lake marion
Joined May 2012
Question
covering (bonding two peices together)
Is it possible to join two different colors of ultracote, before adhering it to the plane, without making a mess? been unsuccessful finding info
Thanks; Tom
saltpepper is offline Find More Posts by saltpepper
Old Nov 29, 2012, 10:02 PM
BluIIs is offline
Find More Posts by BluIIs
O'Fallon, Mo.
Joined Apr 2010
I have done it successfully a couple of times. Photos show the results.
I cut patterns from poster-board with a 3/8" overlap of darker colors over lighter. Then I traced to the backing paper, and cut the pieces. You have to loosen the backing on the top piece, but not remove it entirely; I used a Popsicle stick to release the backing about 3/4" from the edge. Next, you insert the lower piece between the upper piece and it's backing. Get things aligned properly and use tabs of painter tape to hold things that way. I laid the two pieces on a piece of window glass and started "stitching" the two together with my trim iron set to about 225F, hot enough to activate the adhesive but below the shrink temperature. The still-intact backing paper keeps you from gluing the works to the glass. Take your time and be sure to get the two pieces firmly glued together.
Once the pattern is stitched together you can treat it as a single piece of covering when you attach it to the aircraft and shrink just like you would with a piece of just one color.
Go ahead and try it out with some scraps and maybe a test frame of balsa. It works and can be worth the effort.
BluIIs is offline Find More Posts by BluIIs
Discussion Bolting two wing halves together for Hangar 9 150 size P51D DavidHarrison Electric Warbirds 7 May 12, 2012 08:19 PM
How do you bond two sheets of blue foam? randall1959 Foamies (Kits) 5 Feb 16, 2004 01:36 PM
best glue to use to bond foam together? burgan Foamies (Kits) 9 Mar 24, 2002 08:25 AM
zagi ultracote cover? full lenght or peices? engr Foamies (Kits) 3 Mar 05, 2002 01:40 PM
