This thread is privately moderated by Bud Morrison, who may elect to delete unwanted replies.
Old Aug 26, 2005, 11:49 PM
Joined Dec 2003
That is the density rating of the foam, it comes in different densitys of 15,25,40, up to 100Lb. Of course with greater density comes greater weight...
thojo is offline Find More Posts by thojo
Old Aug 27, 2005, 01:22 PM
Alexey Gorbunov
Lyoha's Avatar
Moscow, Russia
Joined Apr 2004
My weapon.
Lyoha is offline Find More Posts by Lyoha
Old Aug 28, 2005, 04:58 PM
Alexey Gorbunov
Lyoha's Avatar
Moscow, Russia
Joined Apr 2004
Russia. N. Novgorod. Open combat.
Old Nov 19, 2005, 07:58 AM
Caen Normandy FRANCE
Joined Nov 2003
Hello,
2 Spitfires from France:
one for 1/12 Scale Combat and the other is a FSK kit.
regards
PAscal
http://img507.imageshack.us/img507/4...its32df.th.png
http://img502.imageshack.us/img502/8...its41mj.th.png
pacalou is offline Find More Posts by pacalou
Old Nov 23, 2005, 07:53 AM
javierospina's Avatar
Joined Apr 2005
Komet 36ws, OS25fx
javierospina is offline Find More Posts by javierospina
Old Dec 09, 2005, 05:51 PM
Joined Dec 2005
Here is one of my RC airplanes I would like to sell. 47" wing span combat airplane. It has an OS40LA engine I will sell it with or without the engine. The engine has only been used a few times so its not broke in yet. I will take $150.00 for the airplane, transmitter, receiver, servos without the engine. $225.00 with the engine. Top side of the airplane is RED the bottom side is BLUE. With a 4 pitch prop it will fly about 55 mph. Every time you increase the prop pitch by 1 the speed increases by about 10 mph. It will do 75 mph with a 6 pitch prop and about 105 mph with a 9 pitch prop. Glide ratio is very good it will fly 1/4 mile dead stick. It has a bladder fuel tank it will hold 8 to 10 minutes of fuel. It will do loops in about 8 foot diameter circles. The airplane weighs about 8 ounces without the engine, servos, and receiver. If you are interested in this or know anyone that might be interested let me know I am going to post this on one of the RC forums tonight. I am not a member of any RC forum so I will have to register that might take a while will try to get that all done tonight if I have time. I need to leave I will be home again about 8pm tonight. I also have a used OS46LA I would swap out with the OS40 engine for $10.00 less.
I don't see any option to upload the pictures. This is my first time on this forum I don't know how it works.
http://home.earthlink.net/~gary350/bat01.jpg
http://home.earthlink.net/~gary350/bat03.jpg
Isaac Neuton is offline Find More Posts by Isaac Neuton
Old Jan 08, 2006, 11:37 PM
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Here are my Foam Fighters.
Here are pictures of my foamfighters, All these planes are made out of 1/4 inch bluecore foam and are designed to be flown with basic GWS hardware the new Hellcat plane was made out of 6mm depron foam. nasic setup for all kits is:
Setup for brushed motors:
I use the GWS EPS-350 motor and gearbox with ball bearings. The best ratio is 4.43 to 1 or “B” or 5.33 to 1 “C”
8060 slowfly props on the “B” drive.
9070 slowfly props on the “C” drive.
Speed Control: Use one that delivers up to 10amps. I like the GWSISC300
Batteries: Use High Discharge Lipoly 350 ma, 700ma, 900ma, to 1000ma. Avoid using a battery over 1000ma. It will add too much weight. Lighter is better with electrics.
Receiver: GWS GW/R4PII72/H/F, 4 Channel Receiver
Servos (2 required) GWS/NR/STD/F, Naro Standard Servo
Transmitter A good computer radio works best but this planes will fly using a simple 3 channel radio planes are only setup with Ailerons/Elevator/throttle
All Flatfoam Fighter kits include:
paper decal sheets
carbon rod wing brace
1 set of control rods
wire for control services
Motor mount for EPS type motor.
Building materials required:
foam safe glue ( I found that using 5 minute epoxy works the best) (30 minutes also if you need more time)
A xacto knife with # 11 blades.
packing tape ( the kind with fibergalss strings in it) and one roll of standard clear packing tape.
I paint all my planes with Delta Ceramcoat Acrylic paint from Michaels craft store comes in 100's of colors
goes on great with a spong brush or can be thinned for airbrushing.
glue stick for applying paper decals
Kits can be built under 3 hours.
Contact me about these kits and others.
website comming soon!
tallflyer is online now Find More Posts by tallflyer
Old Jan 11, 2006, 02:48 PM
Somerset UK
Joined Feb 2004
Me 262, 1/12 scale combat model
Hi
Here is my scratch built Me262 built to 1/12 scale from blue foam with brown paper covering and enamel paint finish. Power is provided by two OS15LA engines each with a 4oz fuel tank. Total weight, dry, is just under 3lb. Currently waiting its first flight....... and fight.
LYNXACE is offline Find More Posts by LYNXACE
Old Jan 11, 2006, 03:18 PM
Somerset UK
Joined Feb 2004
Dornier Do335
Here is another combat model from my 1/12th scale collection of Luftwaffe fighters.
Construction is blue foam with brown paper covering. Twin OS15CVA engines provide the urge.
The lower fin is held in place by a short, dome headed, locating dowel and a strong magnet.......this ensures a safe departure on harder landings.
Pulls away from a self hand launch without any problems and the rear propeller easily clears the launching hand.
This model has completed several flights and turns well. Total weight is 3lb 12oz including 6oz of nose ballast to move the CG forward.
Should hopefully compete this year in the UK.
Old Apr 02, 2006, 10:50 AM
Canard Driver
R.A.P.'s Avatar
san diego, ca.
Joined Nov 2002
combat
Want a change of pace? try this, more fun than you think, if you can
stop laughing long enough to fly, we fly three at a time.(IFO's)
Dick
R.A.P. is offline Find More Posts by R.A.P.
Old Apr 02, 2006, 04:49 PM
Love is like Pi: Irrational
ronmeister's Avatar
USA, ND, Grand Forks
Joined Jan 2005
two engines power two props on your plane?
I'd like to see more of it, I haven't seen anything like that before.
P.S. that's awesome!
ronmeister is offline Find More Posts by ronmeister
Old Apr 02, 2006, 04:52 PM
ronmeister's Avatar
Joined Jan 2005
Originally Posted by Lyoha
My weapon.
How does the prop not get demolished?
On my electric flying wings the prop does line up with the wing, but wouldn't the engine keep running on a landing with yours?
Old Apr 03, 2006, 02:26 PM
Somerset UK
Joined Feb 2004
Thanks for your comments......I agree that the model is an unusual choice of subject . I made it to prove a point with my fellow combat pilots here in the UK.....some said it wouldn't work and that I'd have all kinds of engine thrust line problems etc etc. A little down thrust on the rear engine is all that was required to make a great model. Here are a few construction shots showing the foam and brown paper construction. I was lucky enough to visit Maryland earlier this year and see the original Dornier Do335 at the museum at Dulles .
Old Apr 05, 2006, 05:28 PM
ronmeister's Avatar
Joined Jan 2005
Yeah I have actually been volunteering at Dulles for the National Space Day programs, sponsored by NASA and Lockheed Martin.
Old Apr 09, 2006, 11:07 AM View Post
ShayRC
A moderator felt this post violated the following rule: Excessive Advertising (Spam). Show it to me anyway.
Yippee! Post your F5B ship pictures here ohadvr Electric Sailplanes 14 Dec 23, 2004 01:35 PM
Post your Fanfold plane pictures here! 68Strat Foamies (Kits) 8 Oct 26, 2004 07:11 PM
Alert *post Your Gws Plane Videos Here!* Zachary Parkflyers 0 Aug 23, 2004 06:40 AM
Post Your 3d Machine Pictures Here RickNick Foamies (Kits) 0 Apr 05, 2004 08:41 PM
Post your inverted chopper pictures here for a kick !!! gmamo Electric Heli Talk 19 Apr 09, 2002 03:13 PM
