This thread is privately moderated by Bud Morrison, who may elect to delete unwanted replies.
Old Jan 29, 2013, 12:31 AM
Mig Man is offline
Find More Posts by Mig Man
David Drowns
Mig Man's Avatar
Southern California
Joined Nov 2010
Originally Posted by draftman1 View Post
MigMan can testify that I did a coro corsair for SSC combat, in fact I did about 7 others also, I also did a coro p-40, me152 and a H-61 for the 2548 scale class for combat.
its all doable, get the 3 views and start cutting and folding
the problem with some of the scale planes is, especialy on the radial engine ones, the fuse gets pretty big and the prop that is specified doesnt stick out past the fuse very much and there hard to handle and launch, especially the 2548 class
in-lines make better planes for combat
Here is one pic that has three of your creations. Front and center with Sheepdog next to you. I have the corostang and the MiG-7 in the back. Pete Terry and Glen to round off the group. Terry had the latest creation from Area 52, an all foam Spitfire.
You always had one or two new creations at each event.
2010 was a good year.
Dang, I just realized. That Mig there is one of the first I built back around 2002.
Mig Man is offline Find More Posts by Mig Man
Old Jan 29, 2013, 09:07 AM
draftman1 is offline
Find More Posts by draftman1
draftman1's Avatar
central CA
Joined Aug 2002
ah yes, those were the days!!!!! the hi-61 and the the 152 are still flyable, The p-40 had some issues but it did have a good maiden
that event was alot of fun!!
draftman1 is offline Find More Posts by draftman1
Old Feb 01, 2013, 03:52 PM
B17G Yankee-Lady is offline
Find More Posts by B17G Yankee-Lady
Master of Combat
B17G Yankee-Lady's Avatar
Lüneburg, Nethersaxon,Germany
Joined Sep 2006
Mitsubishi A7M Reppu
For the new season my new standard combat fighter. Engine OS MAX 25 FX, Wingspan 1200 mm, weight 1250g.
B17G Yankee-Lady is offline Find More Posts by B17G Yankee-Lady
Old Feb 02, 2013, 08:35 AM
draftman1's Avatar
central CA
Joined Aug 2002
those are awesome!!!! im assuming that there balsa and paper covering.
do you have plans for those and any others? 1/12 scale combat planes
Old Feb 02, 2013, 05:06 PM
Master of Combat
Joined Sep 2006
Hello Draftman. These are made by Slowakian Pilot and Constructor Jozef Barat. They do have a normal composite fuselage , balsa elevator and Abachi covered foam-core wings. The quality ist seddled very high, the price ist per piece about 85 Euro + shipping from Slowakia. If you like, I can provide contact via privat message to you.
Best regards
Klaus
ACES Germany Aircombat Group Contact North
More detrails to the Reppu in our German Aircombat forum
http://www.rc-network.de/forum/showt...ishi-A7M-Reppu
Old Feb 02, 2013, 05:21 PM
Master of Combat
Joined Sep 2006
This Heinkel He 100 is made complete from PU Foam in aluminium forms. Like a Revell or Airfix static model.
Old Feb 03, 2013, 07:42 AM
Tango Juliet is offline
Find More Posts by Tango Juliet
Returning From Hiatus
Tango Juliet's Avatar
Mobile, AL
Joined Aug 2006
That is really neat! I've never seen an R/C Model designed that way.
Tango Juliet is offline Find More Posts by Tango Juliet
Old Mar 07, 2013, 05:27 AM
Recce is offline
Find More Posts by Recce
Recce's Avatar
Estonia, Harju, Tallinn
Joined Aug 2012
1/12 ACES Ki-61 for 0.10 to 0.15 class made by local builder. Wingspan 980mm. Will make a cowling after I find the optimum spinner and propeller setup.
Recce is offline Find More Posts by Recce
Old Mar 07, 2013, 04:12 PM
Teambarger is offline
Find More Posts by Teambarger
Teambarger's Avatar
USA, MA, Townsend
Is that foam or molded ? It looks like a quick build.
Teambarger is offline Find More Posts by Teambarger
Old Mar 08, 2013, 06:05 AM
Recce is offline
Recce's Avatar
Joined Aug 2012
The ki-61 has a composite fuselage with veneer covered foam wing. Flying weight with 3S 20C 2200mAh lipo battery is around 700g.
Edit:
Eventually I chose a 3S1P 3000mAh 20C LiPo, 40A ESC and a 1300kv outrunner for the model. The flying weight is 821g.
More info here:
http://aircombat.modelarji.com/viewtopic.php?f=9&t=795
Old Mar 26, 2013, 04:13 PM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
No one is posting here any more so I'll add a couple pics. They really don't fall into any rules as they are a .15 c/l and a .40.
aspeed is offline Find More Posts by aspeed
Old Apr 01, 2013, 10:00 AM
Master of Combat
Joined Sep 2006
Raf se5a
For our 1/8 scale WW I class a Royal Aircraft Factory SE5A made from a Timo Starkloff plan. Very simple and durable construction, powered with a OS Max FS30 Surpass
Old Apr 06, 2013, 03:46 PM
Rczorro is offline
Find More Posts by Rczorro
Joined Dec 2012
Nice planes I'm gonna build a mig7 combat plane
And if you want to see it look here
http://westaero.wingedshadow.com/
The plan sais that it uses a .20 to .26 cu. in. Engine
Ca anybody recomend me a good cheap engine
Rczorro is offline Find More Posts by Rczorro
Old Apr 07, 2013, 02:15 AM
Recce is offline
Recce's Avatar
Joined Aug 2012
I could give you a few engine suggestions if you post your question in another thread. This avoids the picture thread turning into discussion thread.
Old Apr 13, 2013, 04:08 PM
SKYPILEIT is offline
Find More Posts by SKYPILEIT
Minekraft & RCG for me
SKYPILEIT's Avatar
Novi, Michigan
Joined Nov 2002
although It's not done...I'm nearing completion of my JK Aerotech Corsair.I still must install ailerons,throttle servo & switch.
I'll be flying this as a general sport plane..so it's powered by Saito 30 fs.The mount also fits various other engines.so I expect to be testing OS 25 FX...OS 32 F and also the Saito 40a fs.
Wgt. just under 2.5 lbs.It should be fun.
SKYPILEIT is offline Find More Posts by SKYPILEIT
Yippee! Post your F5B ship pictures here ohadvr Electric Sailplanes 14 Dec 23, 2004 01:35 PM
Post your Fanfold plane pictures here! 68Strat Foamies (Kits) 8 Oct 26, 2004 07:11 PM
Alert *post Your Gws Plane Videos Here!* Zachary Parkflyers 0 Aug 23, 2004 06:40 AM
Post Your 3d Machine Pictures Here RickNick Foamies (Kits) 0 Apr 05, 2004 08:41 PM
Post your inverted chopper pictures here for a kick !!! gmamo Electric Heli Talk 19 Apr 09, 2002 03:13 PM
