Joined Nov 2012
I unplugged, checked the connector replugged it, but still does not work. I contacted Century Heli where I bought it from but got no answer yet...
United States, CA, Baldwin Park
Joined Jun 2004
Looks like I fix my problem with the compass error. I took the Phantom apart thinking something a wire might have been loose. Nope. Another member suggested the compass might have went bad. I think this was it. Well since the compass wasn't working anyways I decided to put the same screw driver I used to build the Phantom next to the compass. Well what do you know the light stops blinking red/yellow. When I move the screw driver away I get the compass error lights again. So I took the same screw driver and moved it around the compass to see if I can fix it and now the compass works! Just finished flying in the dark and all is good. I finally get the green GPS light and now it actually locks in one spot in the air.
A bad compass caused so many issue today. First the Phantom flew all weird like it wouldn't self level at times. Sometimes it felt like the gains was low. Sometimes when in forward flight, the Phantom would gain momentum and I had to give full opposite correction and it took a long time to correct. Some scary moments at the field today. Glad I got it fix and working correctly now. I think I have something in the trunk of my car that might have cause the compass to change. Thanks all for the help |
I was planning on some silcone tape to wrap the compass, hanging out on the landing gear...got some white self sealing silcone tape to add some protection, maybe heat shrink too? The compas is about 15$, some soft cover might save some troubles.
Still im going to get a tool demaginizer from harbor freight before my order arrives. |
Joined Jan 2013
Tough day but I think I finally have it
1 - you really need to do a smooth, fairly aggressive, lift or else it's gonna crash on you
2 - let it warm up - let the quick yellow flashes at the end of the cycle stop 3 - recalibrate the controller (instructions are in the advanced manual) 4 - when turning on the unit, have the left control switch set to 'off' and the right stick set to the manual (the bottom position) 5 - i think the go pro was causing the constant red/yellow. it went away when i took off 6 - the lights take some getting used to 7 - you can freak out your neighbors with this thing at night
United States, CA, West Hollywood
But it is always worth to understand why ND works. basically jello is a straight line recorded from top to bottom of the sensor with some time-delay. with just the right frequency of vibration, the camera manage to vibrate one or more times in the time it takes to scan the sensor. you see that as bending jello flag-poles or vertical lines (can also apply to horisontal lines) the most used fix is shooting 60fps or more, now then scan time is reduced enough that mostly the scan happens fast enough that the distorsion do not happen. but it is imaginable that between frames the entire image may shift right left for over all reduced details. The second fix is increasing the shutter-speed, either manually or forcing the automatic camera with a device like a ND filter. unlike the fast frame rate, slower shutter-speed mask the vibration, by scanning the sensor so slow that the camera have time to vibrate multiple times per scan, this may result in reduced detail in the image naturally. second side effect is that reducing the light to the sensor, also reduce the dynamic range, resulting in less technically pleasing images. I am pointing out some of the side-effects because I don't want to distract from the important point that there is no substitute for a perfectly smooth camera. a while ago I linked to the video I did with a GoPro on my Zenmuse gimbal, the GoPro on the Zenmuse delivered a stunning clarity which I am not seeing matched yet on the Phantom, likely because the camera vibrate enough to shift multiple pixels at any time. Design features like the battery-tray on the gimbal Tony is putting together, can significantly reduce camera vibration, by ganging the weight of the camera and battery together in the suspended part of the system. my guess is that Tony's gimbal design will deliver very clean jello free images even with scuffed props probably. |
Just be cause one can, do not always mean its a good idea, yet could not help myself from drafting a gimbal for my ReplayXD camera I wanted something more compact and slick to stick under the Phantom. anyone suggest a high-resolution servo for direct drive.? guess high-resolution and high-speed 400hz kind of thing.?
Joined Jan 2013
Canada, ON, Toronto
Joined Dec 2012
That's the beauty of this forum, together we have a lot of knowledge to share and we are all willing to take time to share! Glad to hear the good news! |
| Thread Tools | |
| Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA | Lucidity47 | Multirotor Talk | 5 | Jun 07, 2012 12:31 AM |
| Video Multiwii Quadcopter Dji F-450 frame Updated Video | Anda Inc. | Electric Heli Talk | 1 | May 23, 2012 02:51 PM |
| Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters | QuadcoptersUk | Multirotor Talk | 8 | May 14, 2012 01:27 PM |
| Discussion DJI Quadcopter Frame BUILD Thread | Quad_Addict | Multirotor Talk | 77 | Apr 19, 2012 01:26 PM |
