Old Jan 12, 2013, 11:22 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Originally Posted by sampdoria View Post
In the Assistant is shows ATTI mode but on the TX I have it set to GPS...
Is there any way to change it in the assistant?
Check to make sure that the compass is plugged in correctly. It sounds like the GPS/COMPASS is not being recognized by Assistant.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Jan 12, 2013, 11:25 PM
sampdoria is offline
Find More Posts by sampdoria
Joined Nov 2012
Thanks for the information tomorrow morning I will try it.
Couple questions:
When you say NEXT: Push the two switch up. what exactly are you referring to? The two sticks? The ATTI/GPS switch?
4)one yellow: The GPS is not working. Check the compass cable and repower phantom.
Where is the compass cable?
Originally Posted by DJI INNOVATIONS View Post
About the compass calibration:
First: You need to confirm the GPS is working. Follow my steps.
1step: Go outside and put phantom on a broad field where no houses no iron materials and open.
2 step:
Pull down your throttle stick if needed.
NEXT:Power on your transmitter.
(Remember don't touch any sticks when you power on the transmitter. Otherwise phantom will fly to a side when you take it off. )
NEXT:Power on phantom and wait for maybe 2 minutes, the fast flashing yellow LED disappears. After that you will see:
1)one green: It is in GPS mode and the satellites is good enough.
2)red leds after one green: It is in GPS mode but the satellites is not good enough.
3)yellow+red yellow red...:Never mind before you calibrate the compass. If the leds disappears when you lift your phantom up, there maybe iron materials around. Move to another place till it disappear.
Both of these tell you the GPS is working.
5)fast flashing green: you need connect to the assistant and see page "tools". Put phantom level and stable. Check the value of gyroscope and accleration: Gyroscope should be near 0,0,0 and acceleration should be near 0,0,-1. Do basic cali following the instruction of the assistant. After that the fast flashing green will disappears. (If you move phantom before take off, you will get fast flashing green. It is OK.) Redo the above sequense.
6)red-green-yellow: error! Don't fly and contact your shop.
Second: On condition of GPS is working, toggle the GPS/ATTI switch six to ten times.
Not too fast!
If the constant yellow led comes out, you can calibrate the compass. If not, try toggle again.
sampdoria is offline Find More Posts by sampdoria
Old Jan 12, 2013, 11:28 PM
Joined Nov 2012
Can I ask you which one is the compass cable?
Old Jan 12, 2013, 11:30 PM
Joined Nov 2012
I think it is the cable that is connected to the landing gear
Old Jan 13, 2013, 12:17 AM
HGT is offline
HGT
Find More Posts by HGT
HGT
United States, CO, Parker
Joined Jan 2013
There is a reason why they print this...
http://download.dji-innovations.com/..._Manual_en.pdf
HGT is offline Find More Posts by HGT
Old Jan 13, 2013, 01:16 AM
Discharger is offline
Find More Posts by Discharger
Perth, Western Australia
Joined Sep 2003
To those of you in the know and are perhaps drinking buddies and on a first name basis with CEO Colin, is there any rumour that there might be an ARF version Phantom less radio RX and TX?
I would like to use Spektrum system to comply with my local club rules.
He did suggest on one of the videos that more good stuff was to come!
Discharger is offline Find More Posts by Discharger
Old Jan 13, 2013, 01:36 AM
chinahbeng is offline
Find More Posts by chinahbeng
Joined Jul 2006
Damper mount for DJI Phantom
Here's how I mod my Phantom.
The stock mount in my opinion isn't good as it produce jello and vibrations using my hero3 Black and CamOne Infinity.
These 2 mods worked very well with no visible vibes and jello
I will post unprocessed video soon
chinahbeng is offline Find More Posts by chinahbeng
Old Jan 13, 2013, 01:50 AM
Joined Jul 2006
And here's the video shot with CamOne mounted on rubber ball damper platform
Phantom 1st Flight Video Test (3 min 7 sec)
Pls note that this video is unedited and raw, no post processing involved.
Old Jan 13, 2013, 01:57 AM
Joined Jul 2006
Here's another vid. It's shot at 720p 60fps using Hero3 Black using oil damper (ie camera mounted upside down), then converted to 480p 30fps so that I can quickly upload to Youtube.
Temple final A (2 min 1 sec)
Old Jan 13, 2013, 02:02 AM
mattyp2013 is offline
Find More Posts by mattyp2013
Joined Jan 2013
Originally Posted by HighGainTuning View Post
Have you already made adjustments with the Naza assistant?
This is what I see and hear in the video.... any one else agree?
I hear NO start-up. It goes straight to an aggressive lift off which is possible in (Immediate throttle cut off type) rather than (intelligent cut off type) I also hear at 07 seconds the aggressive throttle shutter of manual mode. ATTI/GPS and ATTI are much smoother then that. The tilt angles are also aggressive as in manual mode flight.
Hi,
No adjustments were made I the assistant software other than turning IOC on. I cut the first few mins of video which had the start up before uploading.
It was set to intelligent cut off and I took off aggressively as it just tipped over if I didn't. Camera was in waterproof case which may distort the sound.
It was set to GPS mode and I had waited for the lights to confirm a fix.
How do you even put it in manual mode?
mattyp2013 is offline Find More Posts by mattyp2013
Old Jan 13, 2013, 03:33 AM
DJ41 is offline
Find More Posts by DJ41
DJ41's Avatar
The Netherlands, ZH, Nieuwerkerk aan den IJssel
Joined Jan 2013
Excellent results! Did you create this yourself, or can you buy this in a shop? Could you please describe how you build it, if it was customly made?
DJ41 is offline Find More Posts by DJ41
Old Jan 13, 2013, 04:50 AM
xpower180 is offline
Find More Posts by xpower180
xpower180's Avatar
Joined Feb 2008
She Flies....!
Just maidened my quad (at last) before the snow started again; a few observations:
1. Damn this thing is stable!
2, I need more lipo's!! - can anyone tell me if the Turnigy 2200 3s fits the bay ok?
Whilst on the subject, are there likely to be any issues if the battery leads are shortened right down for the Phantom?
3. I noticed, even when above the tree line with an open view of the skies, that the GPS fluctuates in relation to the amount of satellites it is seeing (sometimes it changes to less than 5, others more than 6). Have others seen this behaviour?
4. The supplied go pro mount seems very good, i've balanced the props and made sure the mount screws are nice and tight and i'm getting (so I think) nice quality video - uploading...
5. I completed a 7min 'flight' - it was really just high hovering to be fair - and i've put back 1279 so I'm good for around 9 mins.
I've been tweaking FPV cables this morning so i'll do some signal testing next time.
Overall, i'm very excited about this platform!
Happy flying
xpower180 is offline Find More Posts by xpower180
Old Jan 13, 2013, 04:53 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Shortening the lipo leads is not a problem, just be careful when you do so not to short them together. And never cut bot hat once which will lead to a short and a bit flash :-)
Also one thing to note about flight time, in cold weather the time will be reduced due to the impact of the cold on the lipo. So just keep that in mind if you are timing your flights as it will vary based on temp.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jan 13, 2013, 05:32 AM
DJ41 is offline
DJ41's Avatar
Joined Jan 2013
I have a question. Yesterday I had an unfortunate landing and I came in too fast and the Phantom tipped over and crashed. The damage is very minimal. I did change 2 props that probably didn't even need changing, but they were dirty so I thought i'd change them anyway.
Now the Phantom has a slight, but noticable tilt to the right side. It's very light, but it annoys me. How can I correct this? There is no other visible damage to it.
I recalibrated the compass already.
NVM. I solved it by running an advanced calibration in the NAZA software tool. Which is a brilliant piece of software btw.
Old Jan 13, 2013, 06:02 AM
Joined Jan 2013
Phantom/Hero Black for sale
Hi,
I have decided to sell my Phantom..
See attached pics, the only damage is to the plastic gopro connector and you can use a standard gopro mount as a replacement. The included gopro case itself has not been used as I just attached the waterproof case directly. Small scuff marks on the case where the props made contact (see pic) but other than that its fine.
All boxed etc with a spare battery (less than a week old). I have only flown it three times and am not very good/don't have enough patience.
I have also attached a screen shot of the Naza assistant showing the status.
Will consider any sensible offers before it goes on Ebay. I'm based in the UK.
I may also sell the Hero 3 Black with any sensible offers, again, only a week old, boxed with all accessories and comes with a 16gb class 10 card.
PM me if interested, looking to sort in the next couple of days.
Name: Untitled picture.jpg
Description:
Description:
Description:
Description:
Description:
Description:
Discussion DJI Quadcopter Frame BUILD Thread Quad_Addict Multirotor Talk 78 Mar 17, 2014 10:20 PM
Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA Lucidity47 Multirotor Talk 5 Jun 07, 2012 12:31 AM
Video Multiwii Quadcopter Dji F-450 frame Updated Video Anda Inc. Electric Heli Talk 1 May 23, 2012 02:51 PM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
