Old Jan 12, 2013, 04:36 PM
Joined Nov 2012
I am trying to recalibrate the unit. As DJI showed it on their site, I turn on the TX put in the battery and connect it, it is in GPS mode. There are 3-4 green lights flashing and a yellow. Anyone knows what that means?
I tried to do the calibration by switching bw GPS and ATT but it does not seem to happen. I get a blinking yellow light. Any suggestions?
sampdoria is offline Find More Posts by sampdoria
Old Jan 12, 2013, 04:43 PM
Joined Jan 2013
I've had the same issue out of the box tried everything except opening it up and physically checking the connectors. All switches are working in the assistant theres just nothing on gps.
Has your GPS worked at all?
IanAstles is offline Find More Posts by IanAstles
Old Jan 12, 2013, 04:47 PM
Joined Nov 2012
Before I crashed yes it worked...
Old Jan 12, 2013, 04:50 PM
Joined Jun 2012
Lurk /off
Saving up for a Phantom, but I'm beginning to think one of these might be handy too: http://www.loc8tor.com/uk/loc8tor-li...__store=ukview
Lurk /on
Brandigan is offline Find More Posts by Brandigan
Old Jan 12, 2013, 04:52 PM
United States, CA, Baldwin Park
Joined Jun 2004
To calibrate the GPS and compass you have to toggle the switch fast 10 times up and down. I forgot how the lights go but its in the manual. Its also the same process as the Naza M manual in case you could find info on how to do it. Also DJI posted a video on to calibrate it.
TonyTypeS is offline Find More Posts by TonyTypeS
Old Jan 12, 2013, 04:55 PM
Joined Nov 2012
I tried it but it does not go to the constant yellow light after the 10 switches...
Old Jan 12, 2013, 05:10 PM
Fly High - Lake Tahoe
Las Vegas/Lake Tahoe
Joined Feb 2010
Colin, CEO DJI NA, did a great intro to the Phantom. I would start there. Watch all 5 videos. You do not have to get into Assistant to start flying. You do however, have to go there to activate the IOC controls. Download the Assistant and the drivers and install according to the instructions. If you have problems, here is a link that addresses the most common problems.
http://www.rcgroups.com/forums/showthread.php?t=1600967
Remember to take the props off, then power the Tx, your Phantom and then plug the usb cable into your computer with assistant running. The first thing that you will get is a prompt to register your product and then Assistant will check for updates. If your version of the software matches the upgrade you are done.
If you are unfamiliar with tuning gains, setting up battery warning, etc. I would ignore those tabs. It appears that just connecting the Phantom to the Assistant activates the IOC. When I opened the tab it was turned on already.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Old Jan 12, 2013, 05:14 PM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
Prototype PhantoMount GoPro 1-Axis GoPro mount video
It has been rainy here all day so just shot a super short vid in the garage.
Hopefully I can get some better video Sun.
It has tilt and can tilt straight down but I forgot to tilt it when filming
Next week we will post pics of the 2-axis mount
Pics are here shown in G10 but final version will be Carbon Fiber
http://www.z06tony.com/Other/PhantoM...2377&k=c6nBqGg
Video:
Rc-Drones PhantoMount 1-Axis Stabilized FPV GoPro Camera Mount For The DJI Phantom Quad/Quadcopter (0 min 47 sec)
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Jan 12, 2013, 05:28 PM
Joined Nov 2012
Thanks! I have watched the 5 videos several times, they are very helpful.
As for the IOC control, how can I tell from the assistant if my GPS is working correctly?
Old Jan 12, 2013, 05:36 PM
Joined Jan 2013
Well mine has done exactly the same flash sequence as that from out of the box and after checking it in the assistant it seems either the compass or GPS is dead as nothing gets picked up at all. Im waiting on a call from the shop I got it from tomorrow so I will share what I find out as soon as I know. Thinking im just going to return mine.
Old Jan 12, 2013, 05:37 PM
Joined Nov 2012
Can you explain this?: " You do however, have to go there to activate the IOC controls."
I have it right now as OFF. My understanding was that I should not use CL or HL.
Also I think something happened to my GPS because even in GPS mode it shows mode: ATTI. Anyone knows how to fix it?
Old Jan 12, 2013, 05:58 PM
Joined Jan 2013
OK guys had a little idea(put lightbulb here) nearly all other sport quads have there landing gear on the end of the arms, due to the way the phantom is set up quite high on its landing skids and the skids not extending to the length of the quad then its quite easy to topple on take off and landing (I've done it myself) so I'm thinking get something like this
http://www.ebay.co.uk/itm/TIC-Racing...item3f20b028dd
and simply tie wrap it to the skids so that it extends the length of the skids to the same as the quad arms, could even be heated and bent to follow the direction of the arms, this i'm sure would help stop from toppling over, especially newbs, same idea as training undercarriage for heli's..
thoughts???
rudeboy78 is offline Find More Posts by rudeboy78
Old Jan 12, 2013, 06:08 PM
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
thoughts???
It would no doubt help. Aluminum tube or even small wooden dowel would work as well.
The Phantom skids are high and narrow to keep them out of camera view I suspect was the design decision.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jan 12, 2013, 06:11 PM
Joined Jan 2013
Just set up my new Phantom. Only 3 blades turn with power most times I arm it. I can get all 4 blades to turn with power about 1 out of ten tries and it is always the same blade that turns slowly. When they do all come on, it works fine. Any ideas on what could cause this? Thanks for your help.
KirbyLewis is offline Find More Posts by KirbyLewis
Old Jan 12, 2013, 06:16 PM
Joined Jan 2013
could be a lazy esc, try going into the assistant software and turning up the motor arming speed to between recommended and high then try again, if this doesnt work then return it as you have a dodgy esc or motor!!
in fact probably best to return it as it shouldnt really need adjusting being a RTF model
Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA Lucidity47 Multirotor Talk 5 Jun 07, 2012 12:31 AM
Video Multiwii Quadcopter Dji F-450 frame Updated Video Anda Inc. Electric Heli Talk 1 May 23, 2012 02:51 PM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion DJI Quadcopter Frame BUILD Thread Quad_Addict Multirotor Talk 77 Apr 19, 2012 01:26 PM
