Old Jan 12, 2013, 10:45 AM
mattyp2013 is offline
Find More Posts by mattyp2013
Joined Jan 2013
Originally Posted by Z06 Tony View Post
Are you sure the flight mode switch was set to GPS and not ATT when you shut off the TX?
I would not recomend shutting the TX off unless it is absolutely neccessary.
Hi,
It was definitely set to GPS and I did not shut off the TX at any point.
mattyp2013 is offline Find More Posts by mattyp2013
Old Jan 12, 2013, 10:48 AM
daskim is offline
Find More Posts by daskim
Videographer/Product Reviews
daskim's Avatar
United States, WA, Spokane
Joined Oct 2012
Originally Posted by Zbip57 View Post
Thanks! I'm trying to learn as much as possible.
The problem is many of those mean something completely different to me.
For example:
RTF - rich text file, a document format.
ATF - automatic transmission fluid.
ESC - electronic stability control, more automotive stuff.
-Ferdinand-
RTF - Ready To Fly - usually includes a completed multi rotor with battery, transmitter and receiver. Power up and fly.
ATF - Almost To Fly - can mean some or all assembly required. Must add transmitter, battery, receiver, and build the multi rotor. Sometimes includes all electronics, motors and ESCs.
ESC - Electronic Speed Controller - see http://en.wikipedia.org/wiki/Electronic_speed_control
daskim is offline Find More Posts by daskim
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Originally Posted by mattyp2013 View Post
Just found it as it was then getting dark!
Camera mount had smashed off, the landing gear is bent in half and the props are all bent, just about to upload the vid so will try and work out what happened.
Waited for lights, increased throttle only and started to go towards the neighbours house so had to increase it further to clear the fence and tried to steer it back. Was in HL mode so expected it to be relative to where I was. Started to go further away and let go of sticks as was in GPS mode but kept flying further. Tried to take control and bring it back but kept heading in one direction and then it appears to crash with no attempt to either return home or land itself when it would have been out of range.
Maybe I am just not experienced enough but either way I now have a broken Phantom
You should not fly in HL.
Thats only if you lose orientation and you should never take off in HL.
If you lose orientation you flip to HL and once you get close to see the orientation flip it off
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Jan 12, 2013, 10:53 AM
Z06 Tony is offline
Z06 Tony's Avatar
Joined Sep 2008
Hi,
Oh I thought you did because you posted this
"So much for return to home GPS !!"
I thought you shut the TX off and then it took off.
Glad you got it back.
Site Sponsor
Old Jan 12, 2013, 10:56 AM
Joined Jan 2013
Oh right, from what I had read in the manual it doesn't say anything like that, just that it kicks in automatically once you are more than 10m away.
Got a sweet crash video once it finishes uploading!
Old Jan 12, 2013, 11:02 AM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
matty,
1) I thought you said it flew away .... (yes or no)
2) then you found it? (yes or no)
3) How far away did you find it? (approximate distance)
4) what was the LED color sequence before you took off.? (yellow, green, red)
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Jan 12, 2013, 11:08 AM
Joined Jan 2013
Originally Posted by sidneyw View Post
matty,
Hi,
1) Yes, it was heading away from me when I was only increasing the throttle (to clear the tree line that it was heading towards).
2) Yes
3) 248 metres (using the google maps distance calc)
4) was green, yellow which I understood to indicate the HL mode.
Old Jan 12, 2013, 11:16 AM
DJI INNOVATIONS is offline
Find More Posts by DJI INNOVATIONS
Joined Jul 2011
Some advices:
1. As a beginner, the first thing is to fly in a broad filed not around houses.
2. You have to get familiar with the system, read the instructions carefully.
3. Try to control the throtle, pitch and roll with the range of 5 meters. Never let it fly away. Pull down throtle and let it land slowly when you can't control it. You will only get some small damage, not fly away.
DJI INNOVATIONS is offline Find More Posts by DJI INNOVATIONS
Site Sponsor
Old Jan 12, 2013, 11:28 AM
sidneyw is offline
Like Tony said .....
Site Sponsor
Old Jan 12, 2013, 11:32 AM
Joined Jul 2011
Hi,
2) Yes
1)Did you tilt the pitch stick when you power on the transmitter or phantom?
3)the NAZA-M will enter go-home mode when the signal bad. 248m should be a good signal range.
I guess you pull down your throttle after phantom fly away, then phantom flied down and hit ground.
Site Sponsor
Old Jan 12, 2013, 11:34 AM
kyle925 is offline
Find More Posts by kyle925
Joined Jun 2012
In my opinion, the HL mode was the reason that you lost control. Unless you have a full understanding of what the HL mode does, this will happen.It happened to me too , where I lost control of my Quad due to the HL mode. But once I totally understood the diff modes and uses, i'm enjoying my DJI since.
kyle925 is offline Find More Posts by kyle925
Old Jan 12, 2013, 11:35 AM
Joined Jan 2013
I must have misunderstood the manual then as it says it does it automatically if you already have it set?
Name: Untitled picture.jpg
Description:
Old Jan 12, 2013, 11:36 AM
kosem is offline
Find More Posts by kosem
Former IAF pilot. Retired
kosem's Avatar
France, IdF, Paris
Joined Apr 2012
Matty, glad you got it back, even with some damages.. .
NEVER fly in HL unless you are in an emergency situation an even though be very careful because the GPS can always loose contact with one or more satellites, meaning you'll have to suddenly fly her manually which is not an easy task..
What happened to your GoPro?
Was it naked or protected?
kosem is offline Find More Posts by kosem
Old Jan 12, 2013, 11:37 AM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Matty,
I would also look at using Course Lock and GPS until you get used to flying in different orientations. It will make it easier for you. DJI is correct, baby steps first, stay in a 5M box until you feel comfortable with the controls. Find a large field with no power lines around. When you get there recalibrate your compass. When in GPS if you loose orientation, let go of the sticks, it will hover in place. It is a lot of fun, but get to know the craft a little bit first.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Jan 12, 2013, 11:39 AM
Joined Jan 2013
Here is the crash.
Guess I am not cut out for flying these things. If I took off too slowly it just tips over and damages the props, if I give it more power, this happens and I lose control (still not sure why as I only gave it throttle to start with).
Are spares available yet? Will fix it then sell it on I think.
Crash :( (0 min 38 sec)
Discussion DJI Quadcopter Frame BUILD Thread Quad_Addict Multirotor Talk 78 Mar 17, 2014 10:20 PM
Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA Lucidity47 Multirotor Talk 5 Jun 07, 2012 12:31 AM
Video Multiwii Quadcopter Dji F-450 frame Updated Video Anda Inc. Electric Heli Talk 1 May 23, 2012 02:51 PM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
