Old Mar 31, 2013, 03:25 AM
HGT is offline
HGT
Find More Posts by HGT
HGT
United States, CO, Parker
Joined Jan 2013
Happy Easter Guys
What did the Easter egg say to the boiling water?
It might take me a few minutes to get hard... I just got laid not to long ago and it was really cold in that refrigerator...
HGT is offline Find More Posts by HGT
Old Mar 31, 2013, 04:02 AM
Yes_Papa is offline
Find More Posts by Yes_Papa
Joined Dec 2012
Originally Posted by skipper1 View Post
Using my caliper, 39.6mm center to center.
Thx.
I search for a 3D print model but no luck i can find one.
Yes_Papa is offline Find More Posts by Yes_Papa
Old Mar 31, 2013, 05:15 AM
molkanen is offline
Find More Posts by molkanen
Niger, Diffa
Joined Mar 2013
Gentlemen .. oil your engines.
Success.
Engines oiled with Remington teflon based lubricant , same as used with firearms.
Noice is down, vibration is down , phantom flying like different machine.
Took wifes garmin forerunner 110 GPS watch to fly around , my own Suunto Ambit is too expensive to flyway :-)
Attached picture is showing my safe distances.
molkanen is offline Find More Posts by molkanen
Old Mar 31, 2013, 05:36 AM
RallyPilot is offline
Find More Posts by RallyPilot
Turkey, Istanbul
Joined Jan 2013
OSD in Phantom
I am attaching a Cyclops Breeze OSD to my Fatshark Predator V2, mainly to let me know how far I am and where the home position is as well as proper battery monitoring while flying FPV.
There are 3 connections for video feed, labelled s, +, -.
+ = video (in or out)
- = ground
s = ? (sound?)
The manual says nothing about "s".
Does anybody know what "s" stands for?
RallyPilot is offline Find More Posts by RallyPilot
Old Mar 31, 2013, 06:44 AM
skipper1 is online now
Find More Posts by skipper1
United States, TX, Dallas
Joined Jan 2012
- = ground
s = ? (sound?)
Signal?
skipper1 is online now Find More Posts by skipper1
Old Mar 31, 2013, 06:51 AM
Turkey, Istanbul
Joined Jan 2013
Sh**. I have probably fried both the GoPro and the Fatshark. The "video out" was written across the + sign, but it was meant for the port not that pin! "s" must be signal as skipper1 says. Just a few minutes too late! Thanks anyway skipper1, appreciate the help.
Update: GoPro totally fried!
Fatshark lives on.
Old Mar 31, 2013, 07:36 AM
mkalika is offline
Find More Posts by mkalika
Joined Feb 2010
Hey Guys,
I have some issues with Phantom Motors that maybe you can help me with:
1) When I fly my Phantom, I hear high pitched whistling sound from the motors
2) When I rotate my props by hand, two motors are relatively smooth, but two other vibrate (tick)
What can I do to fix this? Replace motors, bearings, or maybe oil motors?
I made a quick video to show what I mean
DJI Phantom Motor Issue (1 min 6 sec)
Thanks!
mkalika is offline Find More Posts by mkalika
Old Mar 31, 2013, 08:16 AM
gnolivos is offline
Find More Posts by gnolivos
gnolivos's Avatar
United States, OH
Joined May 2008
All my motors jump like that from factory. I think it is the magnets doing their thing. I'd be worried about the ones that do not 'jump'.
gnolivos is offline Find More Posts by gnolivos
Old Mar 31, 2013, 09:39 AM
Zbip57 is offline
Find More Posts by Zbip57
Zbip57's Avatar
Canada, ON, Ottawa
Joined Jan 2013
I haven't opened one up yet, but gotta ask about oiling bearings. Aren't they packed with grease?
If you soak them in acetone to clean them, does that dissolve the grease? Then oil them instead of grease? What kind of oil? What kind of grease?
I've seen one YouTube video where the guy just adds a dab of white lithium grease. I'm confused again.
Zbip57 is offline Find More Posts by Zbip57
Old Mar 31, 2013, 09:55 AM
Doug D is offline
Find More Posts by Doug D
Joined Mar 2012
Originally Posted by mkalika View Post
Hey Guys,
http://www.youtube.com/watch?v=YQAZmbntnRs
Thanks!
mkalika - Nothing sounds out of the ordinary to me, there will be motor pitch changes when flying. How were the flight characteristics? Was it holding altitude, dipping to one point without stick input, etc?
The "ticking" you showed on the video is totally normal and is from the magnetic pull. Balancing the props and motor bells will make all rotors consistent. I'd recommend take your motors apart and thoroughly clean the bearings and use a high grade bearing lube, you will notice a difference just by doing this.
Doug D is offline Find More Posts by Doug D
Old Mar 31, 2013, 10:17 AM
Doug D is offline
Joined Mar 2012
Originally Posted by branflakes View Post
Other side
branflakes - How are you powering the FPV system and cameras? If it's off the main battery, what kind of flight time are you getting?
Thanks.
Old Mar 31, 2013, 10:27 AM
branflakes is online now
Find More Posts by branflakes
branflakes's Avatar
Joined Jan 2011
Hi Doug
I chose to wire in a spare 3s flight battery hidden in the fuse near one esc
Its a rhino 320 mah
Flight times are normal, i just mentally come back early out of fear before low batt
i have not used a timer on it yet but I'm sure its the 8-10 mins thanks for checking it out.
I would have to rate the 1080 filming of this hundred dollar cam as just about as good as a go pro seeing both footage online
It may not have the stability or light sensitivity but for a third of the price i don't regret the purchase
branflakes is online now Find More Posts by branflakes
Old Mar 31, 2013, 10:39 AM
eirlink is offline
Find More Posts by eirlink
click HERE 2 C my BLOG
eirlink's Avatar
Ireland
Joined Mar 2013
Branflakes, sorry i missed the model of that cam. Can you advise. thanks
eirlink is offline Find More Posts by eirlink
Old Mar 31, 2013, 10:40 AM
Doug D is offline
Joined Mar 2012
Hi Doug
Its a rhino 320 mah
Thanks, do have any 1080 footage posted yet?
Old Mar 31, 2013, 10:44 AM
branflakes's Avatar
Joined Jan 2011
No i have some but its too jello I'll try to keep getting better stuff eventually
Check YouTube though, hobbyking wing camera 2 1080 there are a few with quad use
Discussion DJI Quadcopter Frame BUILD Thread Quad_Addict Multirotor Talk 78 Mar 17, 2014 10:20 PM
Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA Lucidity47 Multirotor Talk 5 Jun 07, 2012 12:31 AM
Video Multiwii Quadcopter Dji F-450 frame Updated Video Anda Inc. Electric Heli Talk 1 May 23, 2012 02:51 PM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
