Old Feb 07, 2013, 08:04 AM
The Devil Is In The Details...
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Loctite
Originally Posted by FITandFUEL View Post
I just use a regular nut and able some new loctite from time-to-time, has worked great so far. I did have one of the original prop nut come off after a tip over while landing.
Be careful with Loctite.
It's thin, runny, and wicks into confined areas (on purpose).
It will attack and soften some plastics.
Most pilots use it judiciously or not at all for fear of damaging a prop.
T J Gilbert is online now Find More Posts by T J Gilbert
Old Feb 07, 2013, 08:09 AM
http://fitandfuel.com/blog/
Joined Jan 2013
Thanks for the tip! I just put a tiny dab of thread lock blue in the nut.
FITandFUEL is offline Find More Posts by FITandFUEL
Old Feb 07, 2013, 08:24 AM
Jerk
R Hudson's Avatar
Waukesha, WI
Joined Dec 2002
When I got my first F450 I did not realize that Loctite reacts with the props. I just assumed that it would be good to make sure that the nut stayed on. Well, on my first flight I had 2 props totally grenade on me. Fortunately for me I was not hit by them and I was only 2 feet off the ground. From then on I decided that I would just check tightness in pre-flight.
Edit: Ed was actually the one who informed me about loctite and props after my blunder. I believe that most of the "mysterious breaking DJI props" was a direct result of using loctite. Major no-no!
R Hudson is offline Find More Posts by R Hudson
Old Feb 07, 2013, 08:31 AM
Fly High - Lake Tahoe
Las Vegas/Lake Tahoe
Joined Feb 2010
Please do not use loctite it will damage the plastic on the prop and cause it to fail. Part of your preflight check is to tighten the prop nuts. If you are doing that you won't have a problem.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Old Feb 07, 2013, 08:34 AM
Jerk
R Hudson's Avatar
Waukesha, WI
Joined Dec 2002
Originally Posted by Bo Lorentzen View Post
Thinking out loud.
Tried some too small tri blade props. 7x4
It do not work..! so don't try.
But.. they have very little angle to the air and spin fast and smooth. I touched the phantom to get a feeling for the smoothness compared to how it normally feels while flying. incredible smooth.
Learned one more thing I have not given enough though to so far, control moves cause a lot of vibration in the phantom, flying the small props made it very clear to feel the effect of control moves, when pushing on the landing gear the props on one side would counter, everytime there is a minute change in prop speed, each change cause a brief vibration in the rig as motors change speed, which could easily explain why I repeatedly have seen clear video and then suddenly a brief flash of jello.
Either way. these did not work and I ordered some bigger ones for kicks.
OH.. did not work, as in, they are too small, and the phantom barely climb with them.. other than that, it flew remarkable well and smooth, and the sound was something completely different too.
Anxious to see results Bo. Back when Gary Goodrum was testing the gimbal for the F450 he recommended GWS 3-blade props to me. He said that he was getting good results with them so I tried them.
On my 450 I would get a bit less flight time (tri-blade props are less efficient) than the stock props but it flew way smoother and it seemed to hold better in wind and not oscillate during descents as much as the stock props did. They were cheap too.
Getting the right size 3-bladers will be the trick here. On my F450 I switched from the stock 10" props on 3S to the 9x5x3 on 3S and that worked well.
Finding a proper conversion size from the 8" props on the Phantom may be tricky. I might try 8x4x3 to see how it works. I can tell you that 9x5x3 won't work (I didn't think it would). I tried for a very short flight. Too much amp draw.
Old Feb 07, 2013, 09:13 AM
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
The GWS 3 blade props are much more floaty due to the added blade area, they also have a wider flatter blade. So they can be good for AP/AV use but they also have a lot of flex too I have found.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Feb 07, 2013, 09:14 AM
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Exactly. Simplest is to check nuts each flight. If not that use nylon locknuts. loctite is a no no with plastic.
Site Sponsor
Old Feb 07, 2013, 09:36 AM
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Balancing and coning (where the prop flexes and looks like a cone) are the two biggest problems.
MCrites is offline Find More Posts by MCrites
Old Feb 07, 2013, 09:38 AM
Jerk
R Hudson's Avatar
Waukesha, WI
Joined Dec 2002
There is good and bad in that. I think that one of the reasons they handle wind better is due to the flexibility. The blades flex as wind hits so they absorb some of the energy allowing the multi to hold position better. However, that same flex adds to the inefficiency reducing flight time.
I used mine to inadvertently cut cat tails on a few occasions and they would bend instead of break. I would straighten the blade or blades and I'd be back in business.
Although the GWS are fun, smooth, cheap, and a different sound (kinda cool), once I tried the Graupners I was sold and the GWS sat after that.
Wheels_UK's Avatar
United Kingdom, England, Birkenhead
Joined Dec 2012
Here is my Futaba T8J fail safe test flying the phantom
DJI Phantom Fail Safe test using Futaba T8J (4 min 57 sec)
Wheels_UK is offline Find More Posts by Wheels_UK
Old Feb 07, 2013, 09:43 AM
Joined Jan 2012
NEVER EVER EVER EVER EVER TURN OFF YOUR TRANSMITTER!
Really...Never.
Old Feb 07, 2013, 09:55 AM
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Has to be done to test the failsafe you know. I do it on every copter I setup and also on other things. Now, obviously, I do it while holding it down just to be safe.
WiseDuck is offline Find More Posts by WiseDuck
Old Feb 07, 2013, 10:17 AM
Joined Jan 2012
Put the failsafe on a switch. If you can't do that then test in the assistant and hope you have done everything right or you never need it.
I have Naza + GPS on my $3k F550 and the RTH Fail safe set... never tested and never needed.
Old Feb 07, 2013, 10:21 AM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
http://www.youtube.com/watch?v=YoUDkDMzSRg
You are very helpfull and have taken alot of time with your videos but its never a good idea to encourage pilots tot turn off there TX.
Plus you can easily setup the FS on a switch to demo how FS works.
Thats the advantage of using a better TX like you are.
You can setup a switch for FS
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Feb 07, 2013, 10:44 AM
United States, CA, West Hollywood
Well, the result is
1. barely climbing with what I had in house 7x4's no point in testing these further
2. incredible smooth when I touched it in flight.
3. these were master airscrews, not flexible at all, feel almost like wood in terms of stiffness and also pretty fat cores.
4. very very cool sound...
I ordered some 8 and 9 inchers to see how it plays. the smoothness with the first flight was to the point I considered hard-mounting the GoPro this morning for kicks.
Bo Lorentzen is offline Find More Posts by Bo Lorentzen
Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA Lucidity47 Multirotor Talk 5 Jun 07, 2012 12:31 AM
Video Multiwii Quadcopter Dji F-450 frame Updated Video Anda Inc. Electric Heli Talk 1 May 23, 2012 02:51 PM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion DJI Quadcopter Frame BUILD Thread Quad_Addict Multirotor Talk 77 Apr 19, 2012 01:26 PM
