Old Feb 06, 2013, 10:12 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
You guys might consider just mounting the ClikIt somehow to Phantom. Guaranteed to rid you of Jello issues.
http://www.rcgroups.com/forums/showp...06&postcount=1
Sid3ways is offline Find More Posts by Sid3ways
Old Feb 06, 2013, 10:16 AM
HGT is offline
HGT
Find More Posts by HGT
HGT
United States, CO, Parker
Joined Jan 2013
Originally Posted by T J Gilbert View Post
HighGainTuning, since you're training technicians for a living, pick up the ball here and give us a lesson...
"What do you want to know?"
I thought it was obvious, but I'll be more specific.
(And I apologize to you guys that prefer we keep technical conversations elsewhere...)
With 3S:
avg. max current (I saw) on video: 7.19 amps
captured max current: 8.48 amps
snap current: 21.16 amps (captured)
With 4S:
avg. max current (I saw) on video: 10.32 amps
captured max current: 13.6 amps
snap current: 31.84 amps (captured)
I expected the current draw to decrease with a voltage increase because theoretically the same amount of power was required to spin the prop.
The 4S currents were all higher than the 3S currents.
What I'd like to know is your opinion as to why this occurred...
Sorry TJ.. I didn't see the question in your last reply.
When I got to work today I put your question up on the screen for the class to read. Since they are 2 days from finishing this class and we just talked about this I had the students write me their response. Everyone did very well and I will sum it up.
If the resistance stays the same and the voltage is increased the current flow will increase. You could hear the results of that in the video. I often relate electron flow to water in class. If you increase the pressure (voltage) and you do not change the size of the hose (conductor) or spray nozzle (motor) that the water (current) flows through, you will flow more water (current). It is the same in an electrical circuit.
One thing I didn't point out but you may have assumed is I ran only 1 motor so the battery was dedicated to just a single device. With 4 motors in parallel to the battery there will be a greater voltage drop causing a lower current flow then you saw in the video so the video current flows were most definetely at their maximum. When flying with 3S batteries my hover is achieved at mid stick. With 4S batteries the exact same prop speed and hover is achieved with the throttle stick just below center.
I am mainly looking for longer flight times when the GoPro is mounted but the extra acceleration in manual mode for sport flying is a blast. If I have an ESC fail I will post that but I do not expect that to occur as I will also be attaching a heatsink to the MOSFET array.
Another place to gain flight time would be to disconnect the outer most LED. Each set of 3 are in series and disconnecting the outer will shut all 3 down. They apear to be 3 watt CREE LED's so there's 36 watts of savings if you don't need them.
I totally understand that electronics isn't everyone's bag and I am by no means trying to push the use of 4S batteries. Based on what I tested, I have no fear in using 4S batteries to extend flying time on the Phantom.
HGT is offline Find More Posts by HGT
Old Feb 06, 2013, 10:54 AM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
@HighGainTuning
Good answers for the newbies!
(And for old farts too!)
I was wondering if you were going to introduce e=iR....
And I wasn't trying to trick you.
I was trying to ask you what a newcomer would say...
I've seen pilots who were maxing out their ESCs think that they could go to higher voltages, enjoy higher RPMs, and not have to size up their ESC.
The uninitiated might have benefited from a tach on the prop...
I still think the currents you've measured are within acceptable ranges.
And it's neat that you were able to use our tinkerings in your class.
Way to go!
T J Gilbert is offline Find More Posts by T J Gilbert
Old Feb 06, 2013, 10:58 AM
daskim is offline
Find More Posts by daskim
Videographer/Product Reviews
daskim's Avatar
United States, WA, Spokane
Joined Oct 2012
Originally Posted by flitelab View Post
Took some captures from the video.
Looking at it I would guess it is Sorbothane just based on how it looks and how it is cut a bit jagged as Sorbothane is very hard to cut smoothly.
I have some here, I'll see if I can try attaching it with double sided tape. I need to test my current mount first where I use rubber grommets and Align Gel to isolate the screws/frame.
Question becomes whether this mount is a DJI product, or a third party's.
The video from the Phantom's view is quite good -- probably the best I've seen, and there is high production value in the overall presentation.
Is DJI thinking of introducing its own dampening system - I'd certainly like to know.
daskim is offline Find More Posts by daskim
Old Feb 06, 2013, 11:00 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
I would say no as it looks little more than a piece of sorobothane glued on. if it were production quality I would suspect it would be more uniform in shape. This to me looks like a quick DIY fix they did while shooting. In some scenes it has the normal mount.
I suspect that video has a lot of post production done so hard to really say how stable the raw video is.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Feb 06, 2013, 11:05 AM
FITandFUEL is offline
Find More Posts by FITandFUEL
Joined Jan 2013
Here is the raw video shot at 2.7k. Its a test with sorbothane and a mount I've been playing around with. I crashed half way through the flight and this is the second half with unbalance, freshly crashed blades. I think the results are pretty good for that!
I won't have a prop balanced until Friday so I'll have plenty of time testing just the mounts isolated ability.
Lighting sucks right now but you get the idea.
DJI Phantom and Hero3 at 2.7k (Raw footage with sorbothane mount) (1 min 56 sec)
FITandFUEL is offline Find More Posts by FITandFUEL
Old Feb 06, 2013, 11:14 AM
HGT is offline
HGT
HGT
Joined Jan 2013
Way to go!
Yeah, I'm not sure many here understand Ohm laws and Kirchoff's theories which is also why I did the video showing only a digital readout ammeter. I have the scope hooked up in the background with an inductive clamp if you really want to open up a can of worms. It shows every current pulse including the warning beeps.
I have a photo tach I could use if that interests anyone.
Yeah... the class just went through FET's, MOSFETS, SCR's, NPN and PNP transistors yesterday so that had better be able to answer your question.
Old Feb 06, 2013, 11:23 AM
epicdream is offline
Find More Posts by epicdream
United Kingdom, England, Cambridge
Joined Jan 2013
http://www.youtube.com/watch?v=-eKSZ...ature=youtu.be
Looking good!
epicdream is offline Find More Posts by epicdream
Old Feb 06, 2013, 11:33 AM
saskya is offline
Find More Posts by saskya
DR , EVIL
saskya's Avatar
Canada, QC, Montreal
Joined Apr 2012
Anyone know if parts are finally available,?
saskya is offline Find More Posts by saskya
Old Feb 06, 2013, 11:35 AM
R Hudson is offline
Find More Posts by R Hudson
R Hudson's Avatar
United States, CO, Denver
Joined Dec 2002
This looks good but I am only able to watch in 1080P max. Is the original available?
R Hudson is offline Find More Posts by R Hudson
Old Feb 06, 2013, 11:42 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
youtube doesnt support higher than 1080p
MCrites is offline Find More Posts by MCrites
Old Feb 06, 2013, 11:45 AM
Sid3ways is offline
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
It actually does, on some videos you'll see an option called "Original" which will offer resolutions higher than 1080p.
For example:
NFS Shift Gameplay 2560 x 1600 video test (1 min 11 sec)
Old Feb 06, 2013, 11:49 AM
MCrites is offline
Joined Jan 2012
Interesting... I still don't see that option. Maybe its a firefox issue. Good to see YT stepping up to higher quality.
Old Feb 06, 2013, 12:04 PM
R Hudson is offline
R Hudson's Avatar
Joined Dec 2002
I didn't even know until more recently myself. Tony (TonyTypeS) posted a 2.7K vid of the Phantom in this thread (I don't remember which page) in which the "original" was available in the "change quality" icon on the bottom of the viewing screen.
Side note: Ditch Firefox and move to Chrome. Life is good with Chrome
Old Feb 06, 2013, 12:06 PM
MCrites is offline
Joined Jan 2012
Chrome and firefox are like boxers versus briefs... just a personal preference thing.
IE on the other hand is a thong made of barbed wire.
Discussion DJI Quadcopter Frame BUILD Thread Quad_Addict Multirotor Talk 78 Mar 17, 2014 10:20 PM
Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA Lucidity47 Multirotor Talk 5 Jun 07, 2012 12:31 AM
Video Multiwii Quadcopter Dji F-450 frame Updated Video Anda Inc. Electric Heli Talk 1 May 23, 2012 02:51 PM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
