Old Jan 20, 2013, 06:00 PM
ArtSteinhauser is online now
Find More Posts by ArtSteinhauser
www.videocopter.nz
ArtSteinhauser's Avatar
New Zealand, Southland, Invercargill
Joined Jan 2013
Originally Posted by HighGainTuning View Post
Why wouldn't it... Mini USB type b has a industry standard pin-out. It is using just 3 of the 5 pins. Ground, 5v and video out. Audio left and right isn't used.
With that said, it is coming from Hong Kong which is why I only ordered one.
I am not shure this might not work, because the GoPro 3 hast not the standard 5Pin USB port, it has a 10Pin USB port!
Here you can find a solution and the pin structure:
http://flitetest.com/articles/GoPro3...ideo_Cable_DIY
Good Luck
Arthur
ArtSteinhauser is online now Find More Posts by ArtSteinhauser
Old Jan 20, 2013, 06:02 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Believe the GoPro cable also has a resistor across certain pins to trigger the video out. Not any cable will work.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jan 20, 2013, 06:27 PM
Zbip57 is offline
Find More Posts by Zbip57
Zbip57's Avatar
Canada, ON, Ottawa
Joined Jan 2013
Originally Posted by flitelab View Post
One of the things that I don't like with the Phantom is how and wear they had to relocate the compass. I know it was done to resolve interference but it is rather exposed and open to the elements especially since it is so low on the landing gear. If you are flying in snow or wet areas its bound to get water into the connector.
To help protect and seal mine I used the following silicone tape wrap. Protects it and not overly noticeable since it is white.
The landing gear is an open gutter shape. If you just wrapped silicone tape around it and the compass, how did you seal the open upper and lower ends?
Zbip57 is offline Find More Posts by Zbip57
Old Jan 20, 2013, 06:45 PM
Zbip57 is offline
Zbip57's Avatar
Canada, ON, Ottawa
Joined Jan 2013
First flight!
I finally managed to get my first flight completed successfully.
This was shot at our Motorsport Club of Ottawa winter driving training track. (N45.24043 W75.98877)
It was cold, -10°C, which is just within the -10°C ~ 50°C acceptable temperature range listed in the Phantom spec sheet. Still it took a whole six minutes before the LED stopped flashing yellow to indicate the ESCs had warmed up enough for takeoff.
I'm using a Hero2 in its waterproof GoPro case, 1080 - 30fps, no stabilization, GPS mode throughout.
I'm still learning how to fly the thing, so smoothness is not yet my forte. It'll come eventually.
First flight with DJI Phantom. (4 min 27 sec)
Old Jan 20, 2013, 06:50 PM
HGT is offline
HGT
Find More Posts by HGT
HGT
United States, CO, Parker
Joined Jan 2013
Good Luck
Arthur
Thanks for the link. I needed some camera lenses from that supplier so that isn't a big loss if it doesn't work. Have these coming just in case.
http://www.ebay.com/itm/2-x-Mini-USB...item3cadcd1f9f
HGT is offline Find More Posts by HGT
Old Jan 20, 2013, 07:41 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
I didn't for now, this was just to protect it somewhat, however any moisture should be kept out of the connector like this at least. Ill redo with sugru when it arrives to totally seal it. Or coils just seal the ends with a dab of hot glue or silicone caulking, etc.
Site Sponsor
Old Jan 20, 2013, 09:46 PM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
The National Airspace
Originally Posted by richardtheboffin View Post
Hi All,
Today I maxed out the range on my Phantom in altitude. I am assuming this as it went into 'go home' mode and landed itself.
I read that the maximum range is 300M, which is pretty high.
I could still see the aircraft so I don't believe it was that high.
Is 300M regarded as the maximum safe range for an RC aircraft?
Do FPV flyers use increased range tx and rx units?
This thread will get very long quickly if RC altitude and distance become topics.
They are thoroughly covered in other RCG threads.
For USA newcomers, the privilege to fly RC craft in the National Airspace is under scrutiny by the FAA.
There are federal guidelines in effect that limit RC altitudes near airports or air traffic lanes.
I don't think DJI ever intended the Phantom to be an FPV or high altitude AV/AP aircraft.
That is probably why the trans/rec range is limited.
Do some research and be aware of your responsibility flying past LOS.
Also think about your responsibility flying over people and property.
Please be careful.
T J Gilbert is online now Find More Posts by T J Gilbert
Old Jan 20, 2013, 10:19 PM
Jumanoc is offline
Find More Posts by Jumanoc
Plus Pilot
Jumanoc's Avatar
Joined Jan 2013
Thanks for your replies. All working !. Just turned on, lights remains 1 green, 3 red, 4 green. No documentation about that sequence, but I did CSC, then start motors and lights changed OK. Ready to fly. I calibrate compass in open field (horizontal 360 an vertical 360 turns). all is ok.
Also I installed Diagnostic Software. I think it is agood idea (I did it), to save (export) original settings configured at DJI, for future restore in error issues.
Jumanoc is offline Find More Posts by Jumanoc
Old Jan 20, 2013, 10:28 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
The single green means you are in GPS mode, the three reds mean that you do not have GPS lock, the 4 greens means you moved the craft on start up and is requesting that you do an Advanced IMU calibration. You can fly but it will not be ideal. Check page 11 and 15 of the manual.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Jan 21, 2013, 12:25 AM
Bo Lorentzen is offline
Find More Posts by Bo Lorentzen
FPVpilots do it remotely
United States, CA, West Hollywood
@Ed - revisit that for a moment -
Normally when I see 4 green, repowering do the trick, but are you saying once its been moved on start up, the thing is all fouled up and I should redo the advanced IMU calibration.?
Bo Lorentzen is offline Find More Posts by Bo Lorentzen
Old Jan 21, 2013, 12:39 AM
poprocz is offline
Find More Posts by poprocz
United States, GA, Flowery Branch
Joined Apr 2012
I don't recall seeing a save or import to Naza setting in the Assistant software when I turned on the IOC feature, I just pulled the usb plug and powered down copter and TX.
Was I supposed to import and/or save this new set-up?
poprocz is offline Find More Posts by poprocz
Old Jan 21, 2013, 12:51 AM
DJI INNOVATIONS is offline
Find More Posts by DJI INNOVATIONS
Joined Jul 2011
Originally Posted by camera_man View Post
As Bo says it's a moldable self-setting rubber/plastic.
https://sugru.com/
http://en.wikipedia.org/wiki/Sugru
That should be work.
You can get a try.
DJI INNOVATIONS is offline Find More Posts by DJI INNOVATIONS
Site Sponsor
Old Jan 21, 2013, 02:19 AM
rudeboy78 is offline
Find More Posts by rudeboy78
rudeboy78's Avatar
Joined Jan 2013
i think its in the tools section, you can export your settings and save them on file so should you change them and forget the originals you can simply import the file back into Naza and it puts all settings back to stock set up!!
rudeboy78 is offline Find More Posts by rudeboy78
Old Jan 21, 2013, 02:34 AM
kosem is offline
Find More Posts by kosem
Former IAF pilot. Retired
kosem's Avatar
France, IdF, Paris
Joined Apr 2012
Normally when I see 4 green, repowering do the trick, but are you saying once its been moved on start up, the thing is all fouled up and I should redo the advanced IMU calibration?
I'd be interested to know the answer as well.
Any input from DJI maybe?
kosem is offline Find More Posts by kosem
Old Jan 21, 2013, 06:34 AM
richardtheboffin is offline
Find More Posts by richardtheboffin
Joined Mar 2012
Please be careful.
Indeed. Have you seen some of the vids people shoot with this thing???
I suspect these will be banned in the UK as soon as someone looses a prop or the IMU goes haywire in a public/built up area and there is a serious accident...
I am fortunate in being out the country, my flying area is sparsely populated.
I have read the CAA pamphlet of RC flying and for models under 7kg there seems to be no actual limit, only that of keeping the model in sight. It also recommends all FPV flyers have co-pilots with buddy boxes... (who does that?)
It is interesting to know that the vertical range is significantly less that the visual range so people should be prepared for auto landings when going up high.
It's also interesting that the auto return home seems to be un-interruptable.
richardtheboffin is offline Find More Posts by richardtheboffin
Discussion DJI Quadcopter Frame BUILD Thread Quad_Addict Multirotor Talk 78 Mar 17, 2014 10:20 PM
Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA Lucidity47 Multirotor Talk 5 Jun 07, 2012 12:31 AM
Video Multiwii Quadcopter Dji F-450 frame Updated Video Anda Inc. Electric Heli Talk 1 May 23, 2012 02:51 PM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
