Old Jan 17, 2013, 09:15 AM
Teezer's Avatar
Pagosa Springs, CO
Joined Jul 2007
For anyone else who runs across the "fast flashing green" problem, this was posted a while back by one of the DJI techs:
Fast flashing green: you need connect to the assistant and see page "tools".
Put the Phantom level and stable. Check the value of gyroscope and acceleration:
Gyroscope should be near 0,0,0 and acceleration should be near 0,0,-1.
Do basic calibration following the instructions of the assistant. After that the fast
flashing green will disappear. (If you move the Phantom before take off, you will
get fast flashing green. It is OK.)
Teezer is offline Find More Posts by Teezer
Old Jan 17, 2013, 10:29 AM
Joined Apr 2012
Phantom with Graupner e-props 8x5 and video downlink.
Fritz
fritz99 is offline Find More Posts by fritz99
Old Jan 17, 2013, 10:30 AM
Joined Mar 2012
Interesting.
Sees to keep coming back on my unit. I've re calibrated half a dozen times so far.
I'm not 100% sure but it may be related to the battery as I think it only happens with the standard battery and not with the Zippy spare battery I got.
It is very cold today, but no colder than some places I've seen the Phantom flying... it's about 4 degrees C outside today.
I will keep playing and see if I can find any reason for it having problems with the IMU calibration.
richardtheboffin is offline Find More Posts by richardtheboffin
Old Jan 17, 2013, 10:34 AM
Denmark, Central Denmark Region, Karup
Joined Aug 2012
Fritz
Whats is the lift and stability compared to stock props? Do you think it could handle graupner 9x5
Im in the market for graupner to replace stock props but would like youre appinion
vartaz is offline Find More Posts by vartaz
Old Jan 17, 2013, 10:40 AM
Joined Apr 2012
Lift is the same.
Stability is much better, but you have to balance them.
Wobbling in the video has gone.
I do not know if 9x5 are too long.
Fritz
Old Jan 17, 2013, 10:59 AM
Joined May 2007
Lift is the same.
Fritz
Do you mind me asking, how do you go about balancing them? Im totaly new to this.
SimonJohnson is offline Find More Posts by SimonJohnson
Old Jan 17, 2013, 11:01 AM
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
HorizonHobby.com How To - Prop Balancing (13 min 41 sec)
Flite Test - Ways To Balance Your Props - FAST TIP (1 min 37 sec)
For 3 bladed props the process can be a bit more involved. This PDF explains the procedure well:
http://www.phprc.net/images/RC_Aero_..._Technique.pdf
flitelab is offline Find More Posts by flitelab
Site Sponsor
United States, WA, Spokane
Joined Oct 2012
Here's a start:
http://hobby.dubro.com/videos/tech-t...-balancer-1_17
daskim is online now Find More Posts by daskim
Old Jan 17, 2013, 11:04 AM
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Originally Posted by daskim View Post
Another great link and a good balancer, I use the DU_BRO one as well.
Site Sponsor
Old Jan 17, 2013, 11:09 AM
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Did google close down? People keep asking questions over and over that if plugged into google gives them 1.6 million results with the first 100 all being sufficient.
MCrites is offline Find More Posts by MCrites
Old Jan 17, 2013, 11:14 AM
Joined Jan 2013
I bought this one as well, but just a quick note. The stock DJI props have the notch built to keep them from rotating on the motor shaft, and the pointed cones on the balancer hit the notches before bedding completely on the outer diameter of the hole. It just means they may not perfectly center the props on the balancing shaft (if that makes sense). It will hold it for sure, but it could be easy to misalign and decenter the prop - just takes some notice when you are doing it. I was going to ream out my stock props before balancing so that the cones are bedded perfectly. On a side note...hand reaming the Graupners takes longer than you think! lol
kazkioken is online now Find More Posts by kazkioken
DSLR's flip too!
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
We dont have google in sweden
ecks is online now Find More Posts by ecks
Latest blog entry: The hecks flies well
Old Jan 17, 2013, 11:18 AM
Joined May 2007
Very interesting, thanks chaps, i have a chunk missing from one of my rotors which is probably responsible for some judder im getting.
Old Jan 17, 2013, 11:23 AM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
I use Dubro also and we sell them-> http://rc-drones.com/dub-balancer.php
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Jan 17, 2013, 11:43 AM
Joined May 2007
TBH I Googled "DJI Phantom Balance Props" but although people were talking about doing it there were no explanations on how to do it, i thought it was a software thing so was expecting it to be in the DJI Assistant somewhere and specific to each flight controller.
Obv no seeing the above videos i completley understand now that balancing props is a generic process across the board. Learn sumit new every day!
Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA Lucidity47 Multirotor Talk 5 Jun 07, 2012 12:31 AM
Video Multiwii Quadcopter Dji F-450 frame Updated Video Anda Inc. Electric Heli Talk 1 May 23, 2012 02:51 PM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion DJI Quadcopter Frame BUILD Thread Quad_Addict Multirotor Talk 77 Apr 19, 2012 01:26 PM
