Old Jan 08, 2013, 09:19 AM
tominjax is offline
Find More Posts by tominjax
tominjax's Avatar
United States, FL, Jacksonville
Joined Dec 2012
Originally Posted by DismayingObservation View Post
Good question; I would assume they'll soon be at Helizone's main site. Amazon has the regular V911 canopies and blades.
I know that Helizone is stocking up on parts as we speak, so getting the lightning motif either for this model or an older V911 should be no problem.
Halley has replacement parts available, but not online yet. Call them at 323-225-2928 Pacific time (10am-5pm, Mon-Fri.)
tominjax is offline Find More Posts by tominjax
Old Jan 08, 2013, 10:08 PM
Smchugh is offline
Find More Posts by Smchugh
Joined Dec 2012
So I've been trying to get the answer to this question since I received my Lightning Bird on 12/28. So far I've exchanged several emails with Helizone directly and the last email I got from them (today), they provided me a direct link to an online retailer's V911 part page that only sells parts for the orange/black WL Toys V911. My last email back to them was asking whether or not the all black replacement parts for the Lightning Bird are or will be available. I will post as soon as I hear back and if anyone else finds them please let me know.
Smchugh is offline Find More Posts by Smchugh
Old Jan 11, 2013, 03:45 PM
needsomethin is offline
Find More Posts by needsomethin
United States, CA, Redwood City
Joined May 2009
Sounds as if your swashplate isn't level. I'd center the trims and then mechanically adjust it at the links.
How do I do that?
needsomethin is offline Find More Posts by needsomethin
Old Jan 11, 2013, 05:54 PM
DismayingObservation is offline
Find More Posts by DismayingObservation
Pronoun trouble...
DismayingObservation's Avatar
Southern California
Joined Feb 2006
Originally Posted by needsomethin View Post
How do I do that?
No problem.
Turn on the transmitter and make sure the trims are centered. You'll see the settings on the display and then it's a simple matter of adjusting the transmitter trims with the trim tabs.
Next, power up the helicopter and wait for it to finish initializing. Then, unplug the battery and look at the swashplate. If it isn't level, carefully pop the pushrod links off the ball links on the swashplate and screw the links in or out in order to adjust them. There's a tool just for the task of separating ball links which your hobby shop either stocks or can order from Align/Horizon Hobby, but it isn't absolutely necessary.
Once you're certain the links are properly adjusted, pop them back in place and give the helicopter a try. Good luck!
DismayingObservation is offline Find More Posts by DismayingObservation
Old Jan 13, 2013, 11:00 AM
dferrey is offline
Find More Posts by dferrey
United States, CO, Longmont
Joined Jan 2013
No problem.
I happen to have broke a ball off one of my swashplates Would you happen to know the name of the tool to safely remove the links? Maybe this?
dferrey is offline Find More Posts by dferrey
Old Jan 13, 2013, 03:48 PM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
a tool like that would work wonderfully but i have never seen one in micro size. sry, that one is much too big and would never work.
pmerritt is online now Find More Posts by pmerritt
Old Jan 14, 2013, 12:55 PM
Smchugh is offline
Joined Dec 2012
Ok, finally got a direct answer.... Replacement canopy, main blades and tail rotor for the Lightning Bird are not available at this time. They claim they will be notifying me when they do become available.
Old Jan 14, 2013, 06:39 PM View Post
uiyewiusdfo
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Old Jan 18, 2013, 02:24 PM
Joined May 2009
No problem.
Thanks for the help. I will try that.
Old Jan 30, 2013, 11:33 PM
Smchugh is offline
Joined Dec 2012
No email but I did stumble across some parts. No canopy yet but its a start...
http://www.amazon.com/Helizone-Light...&keywords=v911
Old Feb 22, 2013, 04:42 AM
ITS ME DAVID is offline
Find More Posts by ITS ME DAVID
ITS ME DAVID's Avatar
Joined Apr 2011
No replacement canopies for this or the h911 warbirds.
Btw doesn't the helizone come with 180mah batteries not 200mah as in this review I'm just wondering ?
TC531131 = 120mah, 37x12x6mm 3.94g
UC531136 = 130mah, 42x12x6mm, 4.4g, new plug
TC551136V = 145mah, 42x12x6mm, 4.38g
UC551148 = 200 mah, 52xx12x6mm, 6g, new plug
ITS ME DAVID is offline Find More Posts by ITS ME DAVID
Old Feb 22, 2013, 09:51 AM
Arr0wHead is offline
Find More Posts by Arr0wHead
United States, MA, Plymouth
Joined Jan 2013
Mine came with 200s.
Arr0wHead is offline Find More Posts by Arr0wHead
Old Dec 29, 2015, 01:19 PM
BMueller777 is offline
Find More Posts by BMueller777
Bloomfield, New Jersey
Joined Dec 2009
Hey guys,
Just got this in the mail and it won't bind as per instructions. I plug in battery, leave it alone on level surface, it blinks a red light a few times, then a few times but more rapid and then back to a slower pace, I turn on the radio and it beeps a few times and then nothing. At this point the red light should be steady red but it's not.
Upon doing this several times at one point the right thimble actually had some control but it was in and out at best. It moved the blades forward and back a few times while rolling the thimble in a circle. The throttle has done nothing at this point and the LCD screen at the bottom indicates a full charge and all it's other functions. I've also tried this in mode 2 and a few other random ways but nothing has worked yet.
Thank you,
Brian
BMueller777 is offline Find More Posts by BMueller777
Article Helizone RC Thunderbird 2.4GHz Coaxial Helicopter Review DismayingObservation Beginner Training Area (Heli-Electric) 17 Dec 09, 2013 08:10 PM
Article Helizone RC Combat Fighter Helicopter 3.5 CH Review Michael Heer Coaxial Helicopters 25 Dec 27, 2012 10:04 AM
Article Review Axe CX Nano RTF Helicopter With Dual Counter-Rotating Blades Review Michael Heer Coaxial Helicopters 8 Jan 25, 2012 03:47 PM
Article Heli-Max Novus AH-1J SeaCobra RTF Nano-Sized Fixed Pitch Helicopter Review Michael Heer Micro Helis 35 Feb 18, 2011 12:18 PM
Article Helizone Firebird Mini Helicopter Review cadconversions Coaxial Helicopters 69 Jan 23, 2011 02:50 PM
