This thread is privately moderated by RSTEARMAN, who may elect to delete unwanted replies.
Old Nov 20, 2012, 11:29 PM
RSTEARMAN is offline
Find More Posts by RSTEARMAN
Trader Rating: 61
United States, WA, Puyallup
Joined Dec 2001
Trader Rating: 61
Sold
Water bottle gas tank fittings / bulkhead fuel line fittings
High quality 1/8 inch to 1/8 inch bulkhead fittings
Nickel plated
Tested to 120 psi
Use the same fitting tor the vent, simply remove the nipple on the threaded end
Made in USA
$2.85 each
$1.95 shipping for 1 to 15
Only six left
RSTEARMAN is offline Find More Posts by RSTEARMAN
Old Nov 20, 2012, 11:43 PM
PropsnWings is offline
Find More Posts by PropsnWings
Trader Rating: 45
Redwing RC Team Member
PropsnWings's Avatar
Joined Jun 2011
Trader Rating: 45
How does the nipple simply remove? Trying to see what you mean by the pictures.
Do these have a neoprene washer, or O-ring to seal when snugged?
PropsnWings is offline Find More Posts by PropsnWings
Old Nov 21, 2012, 12:00 AM
Trader Rating: 61
Joined Dec 2001
Trader Rating: 61
The nipple is made of nickel plated brass and is easily cut off with a hack saw. If you need some with just the threads on one end, I can made some up for you.
No O-ring,
Just be sure to drill the correct size hole so that the nipple threads into the plastic.
The plastic that the bottle is made of is a good gasket material.
Old Nov 21, 2012, 11:35 AM
Trader Rating: 61
Joined Dec 2001
Trader Rating: 61
All sold
Thank you
For Sale Large lot of fuel tanks for glo or gas Steve H. Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 31, 2012 11:30 PM
Sold Gas Fuel Tank Stopper, Aluminum Standoffs wolfcbr2003 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 27, 2012 02:02 PM
Question I don't understand... 1/8 fuel tube, sloppy fit on tank pipes? 30cc extra330sc build The knifes edge Engines 11 May 01, 2012 02:42 AM
For Sale 4TITUDE gas fuel tank with mount and line JackRC Aircraft - General - Miscellaneous (FS/W) 0 Oct 07, 2011 12:58 AM
Discussion Gas engine => fuel tank/line/engine set-up... Commplexxo Scale Sailplanes 7 Apr 24, 2011 09:26 PM
