Old Dec 08, 2012, 01:59 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
A couple FYI's
If you order a replacement motor= it does not come with heat-shrink.
If you order a replacement fuselage with electronics= it does not come with motor or anything showing you where to solder motor wires.
(Both the Night Vapor and Ember fuselage with electronics come with a motor).
I would think Horizon could do a lot better than this????
TODD
I R Irv is offline Find More Posts by I R Irv
Old Dec 10, 2012, 12:28 PM
davidTs is offline
Find More Posts by davidTs
Joined Nov 2012
Nice and usefull report I was waiting!
It is a pitty that new brick is just ~0.5 gr lighter.
Does someone try actuators on MV? With actuators you can easily get all RC below 1gr.
davidTs is offline Find More Posts by davidTs
Old Jan 02, 2013, 04:18 PM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Any more information about thrust and such? I figure the "classic" 10 grams of thrust that people measured with such a motor.
I'm doing research again since I want to build on my succes with a P40 walnut that I built for Plantraco equipment years ago. I want to make a same-sized T28 Trojan. However I doubt if I'm able to fly a 16" span, 15 gram aircraft with Mini Vapor equipment..
thanks Gordon, once again!
RNAF is offline Find More Posts by RNAF
Old Jan 03, 2013, 06:09 AM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
You could run a DT receiver and actuators on the MV airframe. But at that point, you might as well just build an airframe for the $43 it would cost for a MV replacement airframe. Expecially since that may not come with a motor and gearbox.
http://www.horizonhobby.com/products...or-PKZU1270#t1
Petefoss is offline Find More Posts by Petefoss
Old Jan 27, 2013, 12:41 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
3-Port Charger
I was hoping to make a 4 or 5 port one but the chargers were bigger than I'd hoped for. Used a 4AA battery holder with power switch from RadioShack($2.29) http://www.radioshack.com/product/in...ductId=2062253 and a 5pc USB chargers from Bidproducts($8.95). Can't find them now and there site is a joke to search for something. Anyways there's 3 charge settings 20, 40 and 60Mah. Took the battery charger plugs off my old PZ chargers and soldered them on the USB chargers then wired the chargers to the 4AA battery holder. Worked like a charm and I'm staying within the MV battery charge limit. Any USB charger will work if you can find them with a low enough charge rate.
TODD
Old Jan 31, 2013, 11:29 AM
Gabe_BigApple is online now
Find More Posts by Gabe_BigApple
Simple, Easy, Fun
Gabe_BigApple's Avatar
United States, NY, New York
Joined Jan 2013
MV charger charge rate
Is there anything special about the charger other than the lead hanging off?
The manual says 15-20 min charge time which would imply 100 mAh charge rate so I should be able to use it w/ any other UM charger.
Did anybody measure the output to check?
Cheers,
Gabe
Gabe_BigApple is online now Find More Posts by Gabe_BigApple
Latest blog entry: Single-stick Tx design thread
Old Feb 04, 2013, 08:52 PM
scharlach is offline
Find More Posts by scharlach
Joined Jan 2005
mini vapor servos
The 3mm mini vapor servos measure 16 ohms coil resistance. These little
servos put out nearly as much thrust as the AS2000 linear servos.
I hope HH will come out with servos using the 3mm motors and
mechanics - the servo weight should be around 1 gram wo/wires.
scharlach is offline Find More Posts by scharlach
Old Feb 04, 2013, 09:21 PM
Joined Jan 2005
replacement servo mechanics includes 3mm motor
Looks like the replacement servo mechanics includes the 3 mm motor>
http://www.amainhobbies.com/product_...ervo-Mechanics
Old Jul 09, 2013, 11:32 AM
kitetricks is offline
Find More Posts by kitetricks
Flying Object Crash Tester
United States, WA, Tacoma
Joined Jun 2013
Cheers,
Gabe
Measured mine after yesterday's purchase of BNF. Started charging the battery (after 5 minutes of flight) and got at 69mA, which went up for the next two minutes to 75mA. The rate of rising current had slowed considerably by then so I stopped my monitoring there. Considering a 30mAh, 25C battery, 75mA is a safe charge rate, and I don't believe it would have reached the 100mA calculated above. After all, the battery maybe have a 30mAh capacity, but you could never use it all even when flying to LVC. The only time I ever used all of a batteries capacity, was when my Champ was stuck in a tree for 9 days
kitetricks is offline Find More Posts by kitetricks
Old Jul 27, 2013, 11:27 AM
deltapilot is offline
Find More Posts by deltapilot
deltapilot's Avatar
United States, KY, Highland Heights
Joined Dec 2012
mini vapor brushless
Does anyone know if you can somehow splice the si gnal on the board and run a brushless motor?
deltapilot is offline Find More Posts by deltapilot
Old Jul 27, 2013, 12:10 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
If you can find the correct motor fet leg on the MV RX then you should be able to use one of these flashed ESC's.
http://astroid-designs.myshopify.com...shless-install
Old Jul 29, 2013, 07:32 AM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
Do the carbon fiber props from RC Foam produce more thrust than the stock prop for the Mini-Vapor? I presume the CF props are more durable.
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old Aug 02, 2013, 12:37 PM
winghead is offline
Find More Posts by winghead
N Cal
Joined Jun 2003
It sounds like there is a decent following of the mini Vapor. I still need to ask- should I buy one? Is the mini recommended?
winghead is offline Find More Posts by winghead
Old Aug 02, 2013, 12:39 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Probably:
http://www.horizonhobby.com/products...r-bnf-PKZU1280
Tim Wolff is offline Find More Posts by Tim Wolff
Old Aug 02, 2013, 12:59 PM
Petefoss is offline
Petefoss's Avatar
Joined Aug 1999
Holy *^^&() $30!
New Product Parkzone Mini Vapor Flyboy70 Micro Ready-to-Fly 1796 May 10, 2016 01:08 PM
New Product The New Mini-Vapor minimicrorc Micro Ready-to-Fly 1 Oct 28, 2012 01:26 PM
Discussion New ParkZone Vapor Mini- 8 inch ws Vapor Trails Atlanta Area RC 4 Oct 25, 2012 08:19 PM
Discussion Mini Ventus Ebay Specs triumph51 Sailplane Talk 1 May 11, 2012 09:04 PM
Discussion Mini Graphite Equipment? Cones Electric Sailplanes 2 Apr 06, 2012 10:51 AM
