Old Nov 25, 2012, 01:50 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The 14g Ares Moth seems to fly great with the short 6mm, so a regular vapor airframe should fly fine with one, too.
UNGN is offline Find More Posts by UNGN
Old Nov 25, 2012, 02:16 PM
derk is online now
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
looks like a mod i was thinking of doing when i got one Todd. be sure to post a video so we can see how well it works
derk is online now Find More Posts by derk
Old Nov 26, 2012, 04:16 AM
Camboui is offline
Find More Posts by Camboui
Brussels
Joined Jan 2011
How much weights the black plastic part on pz like batteries ? Is it worth to remove it ?
Camboui is offline Find More Posts by Camboui
Old Nov 26, 2012, 06:57 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
I do not believe it is worth removing. When compared to the weight of a plug at the end of some wire leads (the alternative) the weight is about the same.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Nov 27, 2012, 06:13 PM
Jim_Marconnet is offline
Find More Posts by Jim_Marconnet
Fly long and land softly
Jim_Marconnet's Avatar
Madison, Alabama USA
Joined Oct 2005
I read that the MV motor gets really hot fast. And that flight time is only around 5 minutes.
Does this tell us something about people flying it "wrong", sub-optimal hot-wind motor design, need for a motor heat sink (heavy!), need for a more flexible prop to give up pitch under high torque, need for something to increase air flow over the motor, questionable LiPo capacity selection, what?
Jim_Marconnet is offline Find More Posts by Jim_Marconnet
Old Nov 27, 2012, 07:41 PM
Boston, Mass
Joined May 2001
I think it depends on what kind of flying. I flew mine in our house again tonight and it got warm, but not "really hot". It's a tradeoff. Don't fly constantly at very high alpha for the entire flight and it should be fine. It does not require super high throttle settings for cruising around, and hence less heat. The thrust relative to weight is quite good, so most of the time lower throttle settings will be adequate.
I thought the flight time was more than adequate every time I fly mine. It's all about tradeoffs. Get more than one battery and swap more frequently as the price for lower weight.
Gordon
Old Nov 27, 2012, 07:53 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
I fly a 5 min flight timer tooling around the basement:
http://www.rcgroups.com/forums/showthread.php?t=1777199
Most of the time is spend around half throttle. It does not trip the LVC. The battery feels room temp. and the motor is only warm to the touch. I expect that both the battery and motor will last a while flown like this. Batteries are only $3.49 ea. The 4 batteries I ordered from Horizon on Black Friday arrived today.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Nov 27, 2012, 08:08 PM
Boston, Mass
Joined May 2001
My experience is the same as Tim's. I have to say that Horizon did a masterful job of reducing the weight on this plane. Less weight meant less thrust needed, means a lighter motor can be used, means a smaller battery can be used, and so on.
They really sweat the details. The center and side ribs on the wings are a new design. On the regular sized Vapor they are injection molded the entire length of the rib. On the MV there is a small plastic fitting that slides on the leading edge and trailing edge of the wing, CF rods plug into these, with a spacer that's slid on the top and bottom CF rods that form the rib. This results in a lighter rib. CF rod for the wing perimeter is smaller diameter than a full sized Vapor, the fuselage square CF rod is also smaller, and so on.
Kudos to Horizon for going through the plane and figuring out all the places to save weight. I'm sure we will figure out ways to lighten it a bit more. But, Horizon did a really good job on this plane and there's not much left to lighten.
Now the graphics are a different story ...
Gordon
Old Nov 27, 2012, 09:45 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
Thats how i think, its about flying style, dont do high alpha constant the whole flight.
Five minutes flight times seem perfect to me, but maybe im feeling the pain less than others becuase i bought two extra batteries!
HH did an AMAZING job with the airframe, they did absolutely the best that could ever be done.
Gettin rubbing alcohol for the graphics tomorrow. A great frame for lame graphics is just fine, the graphics can be changed. I dont mess with painting, so sharpieing her up is going to be a fun little bit of personalization i dont normally get, extremely excited.
airpower is offline Find More Posts by airpower
Old Dec 02, 2012, 04:22 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
My usual Vapor mods, ball-bearing gearbox with carbon fiber prop, raised the rudder and increased the throws. Got it flying so well I don't think I'll add the bigger wing. It can power itself through tight loops and chase it's own tail now. The graphics are kinda growing on me so there here to stay. Just weighed it and I'm getting 8.86grams with battery?
TODD
I R Irv is offline Find More Posts by I R Irv
Old Dec 02, 2012, 05:36 PM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
I R Irv, how did you do the BB gearbox? With the release of the 2.3 gram BB linear servo and its tiny bearings i would have expected HH to upgrade these bushing gearboxes to BB, maybe not the vapor for wieght, but atleast to the spitfire!
Whats the purpose of raising the rudder? Flatter turns?
Old Dec 02, 2012, 07:59 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Raising the rudder keeps it out of the Elevator. The Rudder limits elevator throw.
Old Dec 02, 2012, 08:03 PM
SuperBarlow is offline
Find More Posts by SuperBarlow
No place like cloud base......
SuperBarlow's Avatar
United States, VT
Joined Aug 2012
Where'd you get the CF prop?
SuperBarlow is offline Find More Posts by SuperBarlow
Old Dec 03, 2012, 12:32 AM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
Sounds good, i always just limited elevator throw to just barely miss the elevator, might try this.
Old Dec 03, 2012, 04:16 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
This isn't a quality production type gearbox, it's a hack job but works very well. I take out the Brass bushings and make sleeves that I glue on both ends of the gearbox, these will hold the 1x3x1mm bearings. 1 bearing and sleeve weighs less than one brass bushing so there is no weight penalty.
Carbon Fiber props http://www.rcfoam.com/product_info.p...ae1afe5590ce4a
Prop adapter=1st item http://www.homefly.com/products.asp?id=10&pg=2
If you use this prop be prepared for a quick little bastard.
Something I found out today is I can actually roll my MiniVapor, never got my modified original Vapor to roll for crap.
TODD
New Product Parkzone Mini Vapor Flyboy70 Micro Ready-to-Fly 1796 May 10, 2016 01:08 PM
New Product The New Mini-Vapor minimicrorc Micro Ready-to-Fly 1 Oct 28, 2012 01:26 PM
Discussion New ParkZone Vapor Mini- 8 inch ws Vapor Trails Atlanta Area RC 4 Oct 25, 2012 08:19 PM
Discussion Mini Ventus Ebay Specs triumph51 Sailplane Talk 1 May 11, 2012 09:04 PM
Discussion Mini Graphite Equipment? Cones Electric Sailplanes 2 Apr 06, 2012 10:51 AM
