Old Nov 20, 2012, 09:06 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Mini Vapor Equipment Specs
For those interested in the Mini Vapor equipment, here it is. The MV brick has a smaller footprint, uses smaller diameter 3mm motors, and weighs 2.85g with a 3-inch battery lead and plug. The original Vapor brick (with its stock lead and plug) weighs 3.3g, and uses 4mm motors.
I figured the only way to reduce the weight was to go to a smaller size motor in the brick. I had hoped for a bit more of a weight reduction, but guess about half a gram isn't bad.
The Propulsion system motor is as I suspected a 6x10mm rather than the 6x15mm that the regular Vapor uses. The gear ratio is the same as the regular Vapor, but the molding where the gearbox attaches to the fuselage is a bit different. So, my guess that they went with the shorter motor that the Ares Nano Stick uses is correct. Whether the wind on the motor is the same I don't know yet.
{edit}
Added first pass table on equipment weights. As can be seen, the Mini Vapor is 39% lighter than the original Vapor. The bulk of the weight reduction comes from the smaller battery as well as the smaller airframe. The next largest source of weight reduction came from a shorter 6mm motor and a smaller and lighter prop. Note the lack of a prop spinner on the MV to save weight. The smallest contribution to the overall reduction in weight came from the new Mini Vapor brick.
I will add more info to this table as I get it, such as thrust and amp draw from the new motor and prop combo.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Nov 20, 2012, 09:52 PM
356Jim is online now
Find More Posts by 356Jim
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Gordon,
You're like Dick Tracy on the case!! Good detective work.
I am torn between buying one or finishing my faux sorta-Vapor made from recycled micro planes with some homemade Vapor-like parts.
356Jim is online now Find More Posts by 356Jim
Old Nov 20, 2012, 10:01 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
3mm motors!! awesome! looks like the servo mechanics could possibly be installed into a stand alone unit like the aileron servo on the 4ch planes, that would make for an even lighter (lower torque) servo
i wonder how much force these smaller servos can produce?
*edit* i dont see a motor connector on the smaller brick, is it on the other side of the board?
derk is offline Find More Posts by derk
Old Nov 20, 2012, 11:13 PM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
The servo feedback pot is fused onto the PC board on these linear servo bricks from memory. The mechanics are just that - gears, threaded rod, motor and housing. Unfortunately you can't remove them easily to use separately.
jj604 is offline Find More Posts by jj604
Old Nov 20, 2012, 11:49 PM
derk is offline
derk's Avatar
Joined Dec 2003
not exactly what i meant, perhaps not worded well enough. i mean i wonder if we can lighten the existing 1.5 gram linear servos by changing out the 4mm motor drives for the 3mm motor ones. they look to be about the same travel (would need to verify first) so in theory, it could work, but the weight drop might not be worth all the effort. that would all depend on how much the new gear threaded rod and motor weigh.
Old Nov 20, 2012, 11:59 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
any chance of a photo of the backside?
nemoskull is offline Find More Posts by nemoskull
Old Nov 21, 2012, 12:00 AM
Pete P is offline
Find More Posts by Pete P
Micro Flyer, Big Poster
Pete P's Avatar
Joined Feb 2005
@derk - I attempted to lighten a normal Ember RX using super-short 4mm motors... Saved .15g each, not enough to matter to me very few of my models need much torque, the motors worked but I've since swapped them out after clipping the RX on a pole and kicking out the back of one of those poor tiny motors.
Pete P is offline Find More Posts by Pete P
Old Nov 21, 2012, 05:51 AM
Boston, Mass
Joined May 2001
The new linear servo mechanism is attached with three screws instead of the old four. So, at least one of the screws won't match up with a hole on the external servo board. In addition, I don't think the motor is included with a replacement servo mechanics. So, where to get the 3mm motor?
I'll get a picture of the back.
I see no solder pads for an external servo, BTW. I really wish they had gone that route. Horizon, are you listening?
Gordon
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
If you look close there mounted with 3 screw and the one at the motor is at a different location.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Nov 22, 2012, 08:54 AM
Boston, Mass
Joined May 2001
Done. I've added it to the first post in this thread.
Old Nov 22, 2012, 02:34 PM
derk is offline
derk's Avatar
Joined Dec 2003
thanks for that Gordon, so it looks like the motor wires get soldered between the servos on the bottom, right by the capacitor? i would add a connector there myself if thats the case, i really dont like repeated soldering and un-soldering like that.
Old Nov 22, 2012, 06:24 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The newer 2S bricks use topside servo wire soldering, too.
Wrap around the edge wiring is one of the first things i would have tried to eliminate on a clean sheet design.
I know this has lead to many warranty returns.
Those motors are tiny. The AS3X servo motors would be MONSTROUS in comparison.
Probably don't want to put this in anything over 22-25g.
UNGN is offline Find More Posts by UNGN
Old Nov 22, 2012, 06:33 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
If Short motors, saved .15g each, I'd go that route and get a 3.0g 5 Channel Green Dot with a plug in motor block.
A plug in motor and 2 channels is a lot to give up for .15g of weight savings.
A short 4mm has to have as much power as a 3mm. (which is probably just as short)
Old Nov 22, 2012, 06:40 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
Top side servo wires is great but motor wires soldered to bottom of brick???(I thought only Air-hogs did that) That must be one heck of a motor that never burns up, and if it does do they send you a new motor with a brick soldered to it.
TODD
Old Nov 22, 2012, 06:43 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
TODD
That is the way the Kyosho miniums still are. The replacement motors come with 2 pieces of heat shrink.
The typical Champ buyer's head would explode, if they saw that.
New Product Parkzone Mini Vapor Flyboy70 Micro Ready-to-Fly 1796 May 10, 2016 01:08 PM
New Product The New Mini-Vapor minimicrorc Micro Ready-to-Fly 1 Oct 28, 2012 01:26 PM
Discussion New ParkZone Vapor Mini- 8 inch ws Vapor Trails Atlanta Area RC 4 Oct 25, 2012 08:19 PM
Discussion Mini Ventus Ebay Specs triumph51 Sailplane Talk 1 May 11, 2012 09:04 PM
Discussion Mini Graphite Equipment? Cones Electric Sailplanes 2 Apr 06, 2012 10:51 AM
