Old Feb 21, 2013, 03:11 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
That is not what the manual says and DJI recommends. One poster here had a blade strike because he was trying to take off in ATTI. Be forewarned.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Feb 21, 2013, 03:25 PM
jhebbel is offline
Find More Posts by jhebbel
"Watch this!.... Oh crap"
jhebbel's Avatar
United States, FL, Seminole
Joined Jan 2012
he probably had set up incorrect or tried to operate right stick before in air. Ive been through 6 packs now no incidents, takes off straight up.
jhebbel is offline Find More Posts by jhebbel
Old Feb 21, 2013, 08:32 PM
badbill is offline
Find More Posts by badbill
Habitual Freeloader
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
I also suggest not to try this. We have a firmware update coming up, I would wait for it.
Bill Davenport
AMA 28141
badbill is offline Find More Posts by badbill
Old Feb 22, 2013, 06:44 AM
jhebbel is offline
jhebbel's Avatar
Joined Jan 2012
Bill Davenport
AMA 28141
Why not? I see no logical reason the ESC can not be run by the RX.
Old Feb 22, 2013, 07:52 AM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
One I thought that we were talking about semi-auto take off and landing. Two by having the esc connected to the Rx you are bypassing part of the control that the Naza uses for stability. It is your heli do what you want, but if you are going to not use the Naza as intended, why do you have one?
Site Sponsor
Old Feb 22, 2013, 08:09 AM
jhebbel is offline
jhebbel's Avatar
Joined Jan 2012
1) plugging ESC into rx makes semi auto takeoffs and landings possible
2) you are in fact NOT bypassing NAZA's stability as NAZA uses pitch to control height not throttle
3) I have a naza for the position hole, atti hold and amazing stability, none of which are being sacrificed by running throttle off the RX...
Old Feb 22, 2013, 08:12 AM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
I have a Castle ICE 100 on my T-Rex 500, which will be the test-bed for the Naza-H. I have governor mode with specific RPMs set up on the ESC. Should I disable those settings before connecting the ESC to the Naza-H? Or does the Naza simply ignore those settings?
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Feb 22, 2013, 08:16 AM
badbill is offline
Habitual Freeloader
badbill's Avatar
Joined Dec 2002
Mine is using the Castle governor mode and works fine.
Bill Davenport
AMA 28141
Old Feb 22, 2013, 08:17 AM
jhebbel is offline
jhebbel's Avatar
Joined Jan 2012
No need to disable, when esc is plugged into the NAZA the throttle acts as normal in manual mode, when you switch to ATTI or GPS the throttle position of the stick is locked at current position and all thats controlled at that point is pitch, so gov mode could actually be helpful here.
Old Feb 22, 2013, 08:23 AM
Mike_Then's Avatar
Joined Apr 2001
Bill Davenport
AMA 28141
Okay, so once again I am over-analyzing. Thanks for the replies; will leave the ESC settings alone.
Old Feb 24, 2013, 08:28 AM
jhebbel is offline
jhebbel's Avatar
Joined Jan 2012
Had a good video of a flight with the ESC plugged into my RX and not the NAZA, but a smack into a phone line running across my field corrupted my video lol. Try again next weekend lol.
Old Feb 24, 2013, 10:28 PM
Mike_Then's Avatar
Joined Apr 2001
Hi guys, I wanted to talk about external BECs vs. the BEC built into a Castle ICE 100. I know we talked about this a few pages back and I'm not trying to argue the point, but wanted to talk about the pros/cons of running one vs. not running one:
  • The power drain of the Naza-H is 300mA
  • The power drain of the Futaba 617FS receiver is 80mA
  • The power drain of the Futaba GY520 gyro is 20mA
Those three components are drawing 400mA, which isn't even 1/2 amp. Now I know that doesn't factor in the current drain of the three cyclic servos and the tail servo... I realize that. But my point is that the BEC built into the Castle ICE 100 is 5A. If I bought a CC BEC and ran it on 6s, I'd still only get 5A out of it. I just can't see the servos drawing 4.5 amps... especially for the kind of flying I do. I have neither the skills nor the desire to throw a helicopter around the sky.... and couldn't do that anyway with the Naza-H unless I'm in manual mode.
I'm really thinking the BEC built into the ESC in this case is sufficient. I can see the need for a separate and/or more powerful BEC for larger helis but I'm thinking I'm okay for a 500-class heli. I'm flying the heli with the BEC built into the ESC now and if I add the Naza-H I'm only adding 300mA to the total current draw... and probably a little less at that since the BEC is at 6V.
Thoughts? Opinions? Am I a reckless idiot?
Old Feb 24, 2013, 10:43 PM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
You have to consider Atti and GPS modes, the cyclic servos keep adjusting for leveling and maintaining altitude continuously; against the wind or attempting to level and drifting. Digital servos draw quite a lot of current; whey you are flying without any stabilization it is quite a different story.
http://www.hitecrcd.com/support/faqs...vos/index.html
Typically a digital servo can draw 2 amps under load.
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Feb 25, 2013, 06:57 AM
jhebbel is offline
jhebbel's Avatar
Joined Jan 2012
Thats 2A under MAX load! Even in 3D flight ive been well under 2A, during scale flight i rarely go above 1A with a FBL heli (FBL draws more load than fly-bared helies)
Old Feb 25, 2013, 07:44 AM
Mike_Then's Avatar
Joined Apr 2001
All good points. I'm not using GPS with mine so that will be one less thing to draw current from the BEC. I had a T-Rex 500 ESP in the past and was using the BEC built into the Align ESC which is only rated at 3A continuous/5A burst. The ESP kit came with 3 x digital cyclic servos and I added a GY-401 gyro and S9257 tail servo. And while I was learning to fly, I had installed an FMA Direct Co-Pilot II system. That system draws around 10mA. While that's less than the Naza-H technically I was working with two less amps unless I went into the burst area.
I can't believe that everyone who has a T-Rex 500 are using BECs like the CC BEC Pro which puts out 20A. I'm not a 3D stick-banger and even if I was, that's not the point of the Naza-H as you can't go over 45 degrees tilt unless you're in manual mode.
BTW I'm flybarred... I haven't gotten into this FBL craze. And get off my lawn!
Discussion DJI Naza vs DJI WK-M - What do you get for the extra $860?? brianshell Multirotor Talk 96 Jul 19, 2013 08:15 AM
Discussion NEW DJI Naza H hex junky Electric Heli Talk 0 Nov 20, 2012 08:30 PM
Discussion DJI Naza - DJI F450 or XAircraft X650? totality Multirotor Talk 14 Jun 25, 2012 01:59 AM
Discussion DJI F450 NAZA kit vs Witespy VC450 with NAZA kit MC21 Multirotor Talk 5 May 16, 2012 02:16 PM
