Old Nov 21, 2012, 07:08 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Originally Posted by robert_houdin View Post
.....In this design, the entire wing will be rotated, with the servo shaft attached directly to the spar, so I probably don't need to worry about the sloppiness to which you refer, but I'm just curious.
That will provide you with far too much pivoting travel. Past designs that utilize "wingerons" typically move the wing through about a 4 to 5 degree total travel.
To achieve this sort of travel reduction the common method is that the wings are set up so that they pivot on a joiner rod which acts as the load bearing center joiner and as the pivot rod. Brass tubing is then used as inner and outer bearings with a bit of oil or grease on the steel rod.
Note that the joiner rod/pivot must be at or VERY close to the 25% MAC position of the wing. Typicaly this is not where the spar is located. So you may want to alter the design to either add a little taper and sweep or some other trick so that the spar at the root portion of the wing is located where you can put the sleeve for the joiner/pivot rod between the spar caps.
The servos are then connected to stubs attached at the leading edge that sticks into the inside of the fuselage where the servos are arranged to move these stub pins up and down and achieve the total travel of around 5 degrees.
5 degrees doesn't sound like much but the one model I saw and got to fly briefly had about that much and it was VERY aerobatic for a glider.
BMatthews is offline Find More Posts by BMatthews
Old Nov 22, 2012, 04:01 AM
flyonline is online now
Find More Posts by flyonline
Twisted and Confused
flyonline's Avatar
Joined May 2003
Check out my onboard vid of my 2m Orca pitcheron for some idea of wing movements. Mine are a little more than suggested above, something like 20deg total if I remember rightly (plane is now dead ) but that is generally not all used excepting high speed rolls, and sharp turns. My records show that all my pitcherons (yet to seriously build a wingeron) are all at about that rate or slightly less, though it pays to have low rates set up for the first flight!!!!!!
Tail Cam - Orca pitcheron (3 min 23 sec)
I've also flown a largeish 2m pitcheron with the wingrod/pivot point @ 33%MAC and a wingloading of ~20oz/sq' without trouble but I had large powerful servos - I wouldn't do it again by choice though I never actually had trouble with it, but I wouldn't want to push it. Modern high speed airfoils with the thickest part at around 25-30% make it a lot easier to put the spar/joiner at that point, the SD7003 is a favourite partly for this reason.
One great and simple method of making a bellcrank is something like this, you can then clamp down on the drive pin in the wing making it nice and tight.
Steve
flyonline is online now Find More Posts by flyonline
Old Nov 22, 2012, 10:51 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Steve, your video actually matches what I saw and felt during that one day with that other guy's model. I noticed that even with minor roll inputs that your response is DARN quick. And the spots where you put in full travel it makes the world look like a washing machine window....
They wingeron model I tried was being set up for thermal soaring. So it didn't really need the same crazy roll rate you're getting.
Old Nov 22, 2012, 11:02 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Thank you very much to everyone for the responses. I now have a much better understanding of why servos are suited to RC aircraft applications.
Any chance you could post a quick sketch of the wing ?
Stuart
Stuart A is offline Find More Posts by Stuart A
Underthetire is offline
Find More Posts by Underthetire
Underthetire's Avatar
United States, CA, Brentwood
Joined Jun 2012
Originally Posted by pmackenzie View Post
Just like you would in a motion control application you can get around the feedback problem by doing an origin return on power up.
But not sure I would want that for a control surface application.
Pat MacKenzie
Zero return switches on a plane, now that's getting complicated. I can still see a loss step mid flight. That would be real bad to try and zero return mid flight. One hellava snap roll me thinks
Underthetire is offline Find More Posts by Underthetire
Old Nov 22, 2012, 11:44 PM
flyonline's Avatar
Joined May 2003
That's true for roll, but they're not normally known for a big elev response. I've got a high speed 60" model that I can't count the roll rate in real time with ease, and have to come out of a drill bit roll with caution so I can work out if I'm up, or down
Old Dec 21, 2012, 01:31 AM
--Oz-- is offline
Find More Posts by --Oz--
Quadaholic
--Oz--'s Avatar
United States, CA, Newport Beach
Joined Mar 2006
Vespa, "are you smoking crack" been around for ~40 years and your not seeing the reality of physics, Sorry bud
--Oz-- is offline Find More Posts by --Oz--
Discussion Using old servo control boards as actuator driver/motor ESC for PROPORTIONAL control EQMOD Electric Power Cars 13 Dec 30, 2014 05:51 AM
Discussion Why are servo motors instead of steppers used to actuate flight control surfaces? robert_houdin Radios 20 Nov 23, 2012 08:33 AM
Discussion Weakest servo, what control surface to use it for? ArizonaFun Electric Plane Talk 12 Sep 16, 2012 07:31 PM
Yippee! Stepper motor control using PWM signal from the apparatus RC Rumcajs Power Systems 5 Aug 07, 2012 04:28 PM
Discussion What Flight Controllers are YOU using on your Hex/Octo? .Joel Multirotor Talk 10 May 13, 2012 07:23 PM
