Old Nov 20, 2012, 06:36 PM
JohnVH is offline
Find More Posts by JohnVH
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
Help!
Setup and placement help
Maidened my hobbywireless 5.8g 200mw setup on my tri today. Range is hit and miss. A few times it would loose signal hovering next to me. Up in the air it was hard to get it to work.
It has to be a placement thing. As on the ground I can grab the groundstation and walk away and have great vid. Heck, even with my truck between it and me I have signal. You can see the VTX on the rear boom, antenna pointing up
Tips?
Description:
Description:
JohnVH is offline Find More Posts by JohnVH
Old Nov 20, 2012, 06:45 PM
DJO is offline
DJO
Find More Posts by DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Was the vTX ever powered up without an antenna?
Connections all solid?
Which channel are you on?
Antennas screwed in correctly?
Where'd you buy the vTX/RX/antennas from?
Could be many different things, try to give more info for us to diagnose this.
Dan
DJO is offline Find More Posts by DJO
Old Nov 20, 2012, 06:46 PM
JohnVH is offline
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
Dan
No
yes
whatever it came on, VRX shows 8
yes
Hobbywireless together in an plug and play combo packages
Like I said, when the tri isnt running I can walk away from it a ways (never walked out of range), but I cant hover next to myself without a problem, so must be interference?
Old Nov 20, 2012, 06:51 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Great, thanks!
Channel 8 conflicts with 2.4 GHz for control if you're using Spektrum, Futaba, etc. So switch it to Channel 1 to start. Not sure of the exact channels for the PNP package but normally it's the lowest channel that will NOT conflict with 2.4 GHz for control onboard. HobbyWireless carries good stuff and I've ordered lots from them.
Dan
Old Nov 20, 2012, 06:52 PM
JohnVH is offline
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
oh? I hope its that simple. I know how to change the VRX channels, have to find a manual on the VTX, nothing out there for help on the hobbywireless stuff.
Thanks!
Old Nov 20, 2012, 06:54 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
There's most likely a set of small switches or something on the vTX. Set the RX to channel 1 and then flip the switches until you get a perfect picture at least, that's what I do LOL.
This may not solve the whole issue but will probably help a little bit, if not a lot.
Dan
Old Nov 20, 2012, 07:05 PM
JohnVH is offline
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
ok, found this, got it to talk on ch1, video quality isnt as clear as ch8, but Im in the house. What other channels are good to use with 2.4?
Old Nov 20, 2012, 07:33 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Normally it's only the first channel or channel 2. But that's really all that I've found out so far. Of course, I was using ImmersionRC equipment too. Make sure that the RX and TX have the EXACT same channels, like 5.455 and 5.455 (just an example). A less clear picture = wrong channel or channel that isn't spot onto the frequency desired.
Dan
Old Nov 20, 2012, 07:37 PM
JohnVH is offline
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
ok, ran it up in the house, no dice, tried ch1 and 4, when I get throttle up it still looses video, even 4' from the Vrx... thoughts?
Old Nov 20, 2012, 07:38 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Sounds like the vTX is burned out.
Turn on the vTX and RX. Move/shake the vTX in your hand while it's transmitting. If the video goes out, then it's probably a burned out vTX.
Dan
Old Nov 20, 2012, 07:45 PM
JohnVH is offline
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
doesnt do it when I move or shake it, but if I rub the velcro, or the top of the thing where the antenna goes on I can make it go out.. is it a static thing?
Its brand new, never ran without an antenna... Dont get it
Old Nov 20, 2012, 08:26 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
RUB the VELCRO? I have no idea, LOL
Might be a loose connection in the vTX itself.
Dan
Old Nov 21, 2012, 12:15 AM
JohnVH is offline
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
Nobody else has had issues with their system?
Old Nov 21, 2012, 03:22 AM
ulkar is offline
Find More Posts by ulkar
Discovery
ulkar's Avatar
Joined Apr 2012
vtx is not burnt, there are known issues on this model for having wrong doc on the channel setting up.
I used channel 0 (or 1 can't remember) for both vtx and vrx but the switch setup wasn't the same on the 2 to achieve same channels.
Try those two things, all switches up on tx and all down on vrx, if that's no good
All switches down and tx and all up on vrx, I know one of the two is first channel (5705 mhz).
ulkar is offline Find More Posts by ulkar
Old Nov 21, 2012, 10:14 AM
JohnVH is offline
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
ok. The Vrx has a digital display showing the channel its on, so I know I have it correct. Ill keep searching. I emailed wobbywireless.com to see if they will help.
Help! Help me please! lol.. Trex 700e stretch kit bearing placement on TT??? rconway75 Electric Heli Talk 4 Sep 21, 2012 02:11 PM
Need help on wing placement for correct CG Flyinmonkey Sport Planes 3 Feb 11, 2003 01:55 AM
Looking for help with placement of aileron servos... DavidHyams Modeling Science 3 Aug 23, 2002 06:21 AM
Help with servo placement tenover Slope 7 May 02, 2002 08:54 PM
need help with servo placement in Zip HLG davidbogart Electric Sailplanes 3 Feb 19, 2002 11:05 AM
