This thread is privately moderated by truevine77, who may elect to delete unwanted replies.
Old Nov 20, 2012, 04:48 PM
truevine77 is offline
Find More Posts by truevine77
Trader Rating: 20
United States, FL, Fort Pierce
Joined Jan 2007
Trader Rating: 20
For Sale
Flyzone Acrowot MKII RTF
http://www3.towerhobbies.com/cgi-bin...&I=LXCHZG&P=ML
Flown 2x - nice package but I need something a little bigger - it's always very windy where I live. I upgraded the elevator servo to Towerpro MG90S metal servo - has nick in the battery compartment and slight hanger rash. This sells for $280.00 - asking $180.00.
This is the Brushless Electric Powered, 2.4GHz Radio Controlled,
Tx-R (Transmitter Ready) Acro-Wot MkII Sport Airplane from Flyzone.
This is the Tx-R (Transmitter Ready) version that includes servos,
an ESC and receiver.
With the AnyLink SLT 2.4GHz Radio Adapter (TACJ2000)
and the appropriate AnyLink cable
with compatible aircraft transmitter
4-channels or higher may be used to fly this airplane.
See http://www.tx-ready.com/anylink-chart.html
for full transmitter compatibility chart.
FEATURES: Construction: Aero-cell foam with carbon fiber-reinforced surfaces for greater rigidity and truer flight Wing: One-piece, installs with one bolt Motor: 30-24-920kV brushless outrunner Servos: Four micro Electronic Speed Control: 40A Propeller: 11x8, plastic Spinner: White plastic, 2" (51mm) diameter Landing Gear: Aluminum with 2.3" (59mm) diameter foam main wheels and 1.2" (31mm) tailwheel Tail Section: Self-aligning and fastens to fuselage with just one screw Warranty: Flyzone Inc. guarantees this kit to be free from defects in both material and workmanship at the date of purchase. This warranty does not cover any component parts damaged by use or modification.
INCLUDES: Tx-R Acro-Wot MkII Sport Airplane with Motor, four Servos, ESC, Propeller and Instruction Manual
REQUIRES: Transmitter: Tactic 2.4GHz transmitter w/at least 4 channels OR AnyLink and compatible 4-channel transmitter (Anylink NOT required with Tactic 2.4GHz transmitter) AA Batteries: 4 for transmitter Battery: 11.1V 1800mAh 20C LiPo, FLZA6024 Battery Charger: AC/DC powered with balancing capability, GPMM3318 if using battery listed above Pliers and phillips screwdriver to fasten wing and tail section to fuselage
SPECS: Wingspan: 49" (1245 mm) Wing Area: 410 inē (26.4 dmē) Length: 39.5" (1005 mm) Weight: 38 oz (1075 g) Center of Gravity (CG): 2-7/16" (62mm) back from the leading edge of the wing at the fuselage sides Control Throws: Low Rate High Rate Elevator: 11/32" (9mm) 10° 5/8" (16mm) 18° Rudder: 1-1/16" (27mm) 17° 1-5/8" (41mm) 27° Ailerons: 11/32" (9mm) 12° 1/2" (13mm) 18°
truevine77 is offline Find More Posts by truevine77
Old Nov 21, 2012, 12:20 AM
Reegor is offline
Find More Posts by Reegor
Trader Rating: 40
USA, CA, San Diego
Joined Apr 2007
Trader Rating: 40
I'm not clear on the version. Your photo shows the RTF version (with transmitter), and the tower hobbies link also is RTF.
But you specify TX-Ready version. http://www3.towerhobbies.com/cgi-bin...&I=LW2209&P=ML
Which is it? Thanks.
Reegor is offline Find More Posts by Reegor
Old Dec 05, 2012, 02:04 PM
skranish is offline
Find More Posts by skranish
Trader Rating: 16
From The Lab
Beverly, MA 01915 USA
Joined May 2001
Trader Rating: 16
Sold? Not Sold? Realistic to ship (is the stab glued in?)
thanks!
skranish is offline Find More Posts by skranish
Old Dec 05, 2012, 03:00 PM
Trader Rating: 20
Joined Jan 2007
Trader Rating: 20
Sorry I took so long to respond - somehow I missed your message in a flurry of e-mails. It's the RTF version.
Old Dec 05, 2012, 03:04 PM
Trader Rating: 20
Joined Jan 2007
Trader Rating: 20
thanks!
Those can be removed. However, I no longer have the outbox. Shipping is almost always high I'd say at least $30. I was trying to make it a good deal for LPU - It may be a good deal with shipping included - it would still be less than a new version - depending on where you live and total cost of shipping.
Old Sep 03, 2013, 10:32 AM
skered53 is offline
Find More Posts by skered53
Trader Rating: 3
United States, OR, Yamhill
Joined Aug 2013
Trader Rating: 3
sol or not ??
skered53 is offline Find More Posts by skered53
Article Flyzone Acro-Wot MkII Transmitter Ready Sport Plane Review Michael Heer Sport Planes 26 Jul 16, 2015 10:52 PM
Discussion Flyzone Acro-Wot MKII gulio Parkflyers 43 Aug 05, 2014 10:33 PM
Discussion Parkzone Radian RTF versus Flyzone Calypsco RTF? cj007 Electric Sailplanes 7 Jun 11, 2012 02:51 PM
Sold Speedwing MKII RTF dashunde Aircraft - Electric - Airplanes (FS/W) 3 Mar 07, 2012 06:04 PM
For Sale NEVER FLOWN Parkzone RTF Decathlon & Flyzone RTF Diablo...NIB! bighank13 Aircraft - Electric - Airplanes (FS/W) 2 Aug 29, 2008 08:53 AM
