Espritmodel.com Heli Air
Old Nov 20, 2012, 09:20 AM
Joined Nov 2012
Car data recorder and gps V4
Hi
I have a car date recorder and a GPS V4 and the GPS doesn't works
All look good in data recorder software my version is 10.08, recorder firmware 5.71
I can look to all data of other sensor (rpm, t°, throttle, steering, rx volts) but nothing from gps.
When I power on the light of the GPS flash 2 time and stop.
What could be my problem ?
Thanks for you help
Sorry for my poor english
speedmatt is offline Find More Posts by speedmatt
Old Nov 20, 2012, 03:13 PM
billpa's Avatar
Joined Nov 2003
Hi, if the GPS is flashing and then stops flashing, that could mean that it is getting a GPS fix (the LED stops flashing once a fix is attained). But, it may also mean that the GPS is shutting off for some reason.
Could you post a photo showing how you have things connected? Also, if you run PC live mode with USB, does the information in the lower lefthand corner of the PC software, say that a GPS is detected?
billpa is offline Find More Posts by billpa
Site Sponsor
Old Nov 21, 2012, 03:23 AM
Joined Nov 2012
Hi and thanks for your help.
I have test in live mode and in first I have : GPS Status : Acquiring GPS Fix, after some second GPS Status : GPS fix acquired num sats = 7, fix mode = 3D, HDOP =1.4
I have attach a jpg file
the car data recorder have the GPS extander V4 + a optical RPM sensor + a t° sensor and it's connected to a rx (smc16scan 40 Graupner)
Old Nov 21, 2012, 07:34 AM
Joined Nov 2012
Matthieu,
"If you wish to log GPS data, choose “Hardware, Choose Parameters to Log in the Recorder” in the app, and select “GPS Parameters”. This
indicates to the recorder that GPS data should be recorded. Note that you DO NOT need to record GPS data to see it live on the Seagull
Dashboard."
jerome
xenobus is offline Find More Posts by xenobus
Old Nov 21, 2012, 07:58 AM
Joined Nov 2012
No that's not my problem I have a look but it's ok
Old Nov 23, 2012, 02:54 AM
Joined Nov 2012
That doesn't work I need help please
Old Nov 23, 2012, 03:46 PM
billpa's Avatar
Joined Nov 2003
Hi, and sorry your problem continues. Can you confirm that if you log data for a while, and then download the data, and click "play" in the software, what message appears in the lower lefthand corner of the software?
Note that the recorder will not log data if USB is connected.
Site Sponsor
Old Nov 25, 2012, 07:59 AM
Joined Nov 2012
Hi Bill
I hope I have find the problem.
After some test that look like to work with a rx pack 5V when I use a 6V pack that doesn't work.
I will do some test tomorrow and say you if it's the problem or not.
Thanks for you help
Old Nov 26, 2012, 12:47 PM
billpa's Avatar
Joined Nov 2003
Hi Matt,
That is probably the issue. Is the voltage exactly 6V, or considerably over 6V? Sorry for the trouble.
Site Sponsor
Old Nov 27, 2012, 09:31 AM
Joined Nov 2012
Hi Bill
When the rx pack is full it's about 7V and that doesn't work.
With a lower tension that look like good.
Old Nov 28, 2012, 03:00 PM
billpa's Avatar
Joined Nov 2003
Hi, that's definitely the problem. The lower voltage should completely eliminate it.
Site Sponsor
Old Nov 29, 2012, 02:24 AM
Joined Nov 2012
For Sale *REDUCED*Eagle Tree Car Data Recorder $150!! inpieces Cars - Accessories (FS/W) 2 Oct 17, 2012 10:58 PM
Discussion Connecting Data Recorder to your elogger v4 jasalca Eagle Tree Systems 2 Feb 09, 2012 04:02 PM
Question eLogger V4 not recognized by Data Recorder ross_badger Eagle Tree Systems 3 Oct 15, 2011 04:32 PM
Help! GPS V4 Expander - how do you get UTC format when you load the data into Excel? Mikey G Eagle Tree Systems 2 Jul 13, 2010 11:12 AM
Discussion GPS Data compression in Data Recorder Effan Eagle Tree Systems 10 Apr 12, 2009 04:16 PM
